Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 12-31-2014, 10:26   #1 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
what is best step for unlock i9505 ?
hi all,
I see many peopel have probleme with unlocking this cell phone,
So what is best solutioin for unlocking the i9505 with out loosing the network and flashing phone ?
Best Regards,
JAVA Good.
Old 12-31-2014, 10:43   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 24,862
To make Unlock, perfrom all the steps :rom Software manual ("Help" button in the Software):
1. Install the latest Software version (Software).
2. Install necessary driver.
3. Root your phone manually.
4. Write firmware "GT-i9505_for_Unlock_and_IMEI_repair" from the Support Area (at first try without writing this frimware, maybe modem firmware in your phone allows to make Unlock).
5. Connect powered-on phone to PC via Micro USB cable.
6. Click "Unlock" button.
7. Follow software instructions (prompts).
Also, look here:
http://forum.gsmhosting.com/vbb/f684.../#post10675173,
Octoplus Samsung Software v1.6.9 - Once again we represent World's First solutions!,
http://forum.gsmhosting.com/vbb/f684...l#post10534714,
GT-I9505 VERS. 4.4.2 with NEW FW "I9505XXUGNF1", IMEI REPAIRED SUCCESS, 3G/4G OK,
Samsung GT-I9505 no service [Solved].
Old 12-31-2014, 10:44   #3 (permalink)
Cheater -Don't Deal with him-
Member: 1965371
Thanks Meter: 440
Galaxy S4 GT-i9505 Read Codes Done "Tested"
Old 12-31-2014, 11:16   #4 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
tks for all for help and reply,
but I need exactely step ?
like,
0808 = DM
9090 = USB
Root with CF-Auto-Root-jflte-jfltexx-gti9505
write or no the file : GT-I9505_for_Unlock_and_IMEI_repair.oct
how to get like this log
I have probleme in this last step :
Repairing NVM for GT-I9505 phone...
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
and to get this log with 00000000 unlocking code ?
Best Regards,
JAVA Good.
Old 12-31-2014, 11:19   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Perform all steps 1-6 and post here full Software log with all of these actions.
Old 12-31-2014, 11:33   #6 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
ok, so exactely step, next time when have one I come back on this thread, tks for all,
and pls how to know if the phone is hold or new security pls ?
Best Regards,
JAVA Good.
Old 12-31-2014, 11:49   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to make Read Codes (not Unlock). If the device has old Security type, then unlocking codes will be read out. It is not possible to read out codes in the phone with new Security type.
Old 12-31-2014, 12:07   #8 (permalink)
Member: 2284783
Sonork: 100.1661528
Thanks Meter: 4
the best way for unlok i9505
1. Phone must be powered on.
2. Type *#0808# and choose, CP install drivers if needed.
3. Type *#9090# and choose DM\DUM over HS-USB.
4. Reboot phone.
5. Connect USB cable, install drivers.
6. Select diagnostic port in port settings.
7. Press "Unlock" button.
Old 01-01-2015, 12:55   #9 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
@ Octopus box
about hold security no probbleme, so Can't read code on new security ?
@ [email protected]
I teste this step next time, so you no root the phone ? and activate debuging ?
Best Regards,
JAVA Good.
Old 01-01-2015, 13:26   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Yes, "Read Codes" works only for devices with "old" security type.
Old 01-01-2015, 13:47   #11 (permalink)
Member: 2295062
Originally Posted by JAVA Good View Post
hi all,
Best Regards,
JAVA Good.
octoplus/octopus is the best for unlocking GT-I9505.i have done with this.
The Following User Says Thank You to cellsolutionbd For This Useful Post:
Old 01-04-2015, 20:08   #12 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
you have 5 post my friend, stop publicity and spam
Page generated in 0.30153 seconds with 7 queries
