01-20-2015, 14:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | what is wrong with the flashing of this i9300 and how to do it? Welcome to Octoplus/Octopus Box Samsung software version 1.8.0 ----------------------------------------------------------------------------------- To connect SGH-T959 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. Selected firmware file: I9300XXUGMJ9_I9300OXAGMJ9 _I9300XXUGMJ9_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... Writing Firmware Failed |
01-20-2015, 15:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Fully charge phone's battery and try to write different firmwares from the Support Area. Try to write firmware with PIT. If problem will be the same - this can be HW problem, with phone's flash chip. Last edited by Octopus box; 01-20-2015 at 15:40. |
