08-07-2015, 19:43 | #2 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: FRANCE
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | Quote:
Sent from my Z10 using Tapatalk | |
The Following User Says Thank You to invaderaze For This Useful Post: |
08-07-2015, 23:24 | #3 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1774666 Status: Offline Thanks Meter: 3 | Thank you for your answer. I have tried so may different ways on installing the software it works perfectly fine except when it comes to UART. I have an issue where it keep failing because the UART can't be recognizing the phone. I tried awhile ago to use NSPRO as alternative option to use the uart however my license expired on it and I don't find it smart to renew it just to use the UART. is there any way you can recommend to install the UART so it can be working fine? |
08-08-2015, 10:07 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | Hello. To fix the problem with connection via UART, You can try to do the next: 1. Re-install FTDI drivers: http://octoplusbox.com/files/drivers...rs_2.08.24.zip . 2. Use correct UART cable (Samsung C3300k/C3303k micro UART cable with 525-530kOm). 3. Block appropriate pin of phone's battery (You can check, whether this action is needed in Software manual of the phone, by pressing "Help" button). |
