06-03-2015, 09:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: all device sell hear
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | z130 cert write fail [Solved] Selected port: COM544 Selected model: SM-Z130H Selected file: C:\Users\babu\Desktop\New folder\Cert_SM-Z130H_357395061478825.cert Select Certificate2... Selected file: C:\Users\babu\Desktop\New folder\Cert_SM-Z130H_357394061478828.cert Searching for a phone. Please wait... Found phone on COM544 Reading info... SW version: Z130HDDU0AOA2/Z130HBNG0AOA2/Z130HDDU0ANL8/Z130HDDU0AOA2 HW Version: SM-Z130HWRDBNG Phone IMEI A: 35`111111111888 Phone IMEI B: 355555555555555 Phone SN: R51G20CX44 Checking Certificate file... Certificate file successfully checked Writing Certificate failed Last edited by Octopus box; 06-04-2015 at 08:17. |
06-03-2015, 10:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please try to do the next: 1. Re-flash the phone with "special_z130hddu0bob2_z130hodd0bob2_z130hddu0anl8 " firmware from the Support Area. 2. Download and install test Software version, which we've sent You in PM. 3. Try to perform "Write Cert" operation with test Software version. Post here results and full Software logs of these actions. |
06-03-2015, 14:20 | #3 (permalink) |
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.6 ----------------------------------------------------------------------------------- To connect SM-Z130H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Enter "*#0808#" number. 3. Select "USB Configuration". 4. Select "USB-Phone(Modem) Chip". 5. Press Home button. 6. Enter "*#0808#" number. 7. Select "Qualcomm USB Configuration". 8. Select "USB-MTP-SDB". 9. Press Home button. ----------------------------------------------------------------------------------- Platform: Samsung Tizen Selected port: COM544 Selected model: SM-Z130H Selected file: C:\Users\babu\Desktop\New folder\Cert_SM-Z130H_ 357395061478825.cert Select Certificate2... Selected file: C:\Users\babu\Desktop\New folder\Cert_SM-Z130H_ 357394061478828.cert Searching for a phone. Please wait... Found phone on COM544 Reading info... SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BO B2 HW Version: SM-Z130HWRDINS Phone IMEI A: 3578765555536-1 Phone IMEI B: 35333333333 Phone SN: Checking Certificate file... Certificate file successfully checked Writing Certificate failed same problem Last edited by !!!_babu_!!!; 06-03-2015 at 14:29. |
06-03-2015, 14:28 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Open Windows Task Manager (ctrl-shift-esc) and end "sdb.exe" process. After these actions try to install test Software version again and repeat "Write Cert" operation with test Software. Post results here. |
06-04-2015, 06:42 | #6 (permalink) |
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | To connect SM-Z130H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Enter "*#0808#" number. 3. Select "USB Configuration". 4. Select "USB-Phone(Modem) Chip". 5. Press Home button. 6. Enter "*#0808#" number. 7. Select "Qualcomm USB Configuration". 8. Select "USB-MTP-SDB". 9. Press Home button. ----------------------------------------------------------------------------------- Platform: Samsung Tizen Selected port: COM1 Selected model: SM-Z130H Selected file: F:\zH_35728.cert Select Certificate2... Selected file: F:\rt Searching for a phone. Please wait... Found phone on COM5 Reading info... SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 HW Version: SM-Z130HWRDINS Phone IMEI A: 357 Phone IMEI B: 3 Phone SN: Checking Certificate file... Certificate file successfully checked Checking certificate compatibility... Certificate is compatible Writing Certificate1... Checking Certificate file... Certificate file successfully checked Checking certificate compatibility... Certificate is compatible Writing Certificate2... Certificate has been written successfully Please, restart the phone to apply changes done |
The Following User Says Thank You to !!!_babu_!!! For This Useful Post: |
08-12-2015, 07:46 | #8 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2310475 Status: Offline Thanks Meter: 64 | plz help sm-z130h write cert faild Welcome to Octoplus/Octopus Box Samsung software version 2.0.3 ----------------------------------------------------------------------------------- To connect SM-Z130H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Enter "*#0808#" number. 3. Select "USB Configuration". 4. Select "USB-Phone(Modem) Chip". 5. Press Home button. 6. Enter "*#0808#" number. 7. Select "Qualcomm USB Configuration". 8. Select "USB-MTP-SDB". 9. Press Home button. Selected firmware file: special_z130hddu0bob2_z130hodd0bob2 _z130hddu0anl8.oct Please put the phone into Download Mode and connect USB cable. To put SM-Z130H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SBOOT section... SBOOT section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing ROOTFS section... ROOTFS section has been written successfully. Writing RAMDISK section... RAMDISK section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing DSP section... DSP section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing FIXNV2 section... FIXNV2 section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Tizen Selected port: COM1 Selected model: SM-Z130H Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_ 357394061478828.cert Select Certificate2... Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_ 357395061478825.cert Searching for a phone. Please wait... Found phone on COM154 Reading info... SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BO B2 HW Version: SM-Z130HZWDINS Phone IMEI A: 357394-06-869380-9 Phone IMEI B: 357395-06-869380-6 Phone SN: RZ1G52QBPQ Checking Certificate file... Certificate file successfully checked Writing Certificate failed |
08-12-2015, 08:47 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please upload *.log and *.logx files of "Write Cert" operation, from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder and post here download link. We will check, where can be the problem. |
08-12-2015, 12:25 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please open Windows Task Manager (ctrl-shift-esc) and end "sdb.exe" process (Right Cliack -> End Process). After these actions repeat "Write Cert" operation and post here result. |
08-12-2015, 13:10 | #12 (permalink) |
Member: 2310475 Status: Offline Thanks Meter: 64 | Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\12-08-2015_17-20-40.log" created (8/12/2015 5:20:43 PM). ERROR : 8/12/2015 5:20:44 PM > Access violation at address 0095278C in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 8/12/2015 5:20:45 PM > Set up system language English (file: English.ini) INFO : 8/12/2015 5:20:45 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.0.2 INFO : 8/12/2015 5:20:45 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:20:45 PM > To connect SM-Z130H phone you have to perform the following steps: INFO : 8/12/2015 5:20:45 PM > 1. Disconnect USB cable from phone. INFO : 8/12/2015 5:20:45 PM > 2. Enter "*#0808#" number. INFO : 8/12/2015 5:20:45 PM > 3. Select "USB Configuration". INFO : 8/12/2015 5:20:45 PM > 4. Select "USB-Phone(Modem) Chip". INFO : 8/12/2015 5:20:45 PM > 5. Press Home button. INFO : 8/12/2015 5:20:45 PM > 6. Enter "*#0808#" number. INFO : 8/12/2015 5:20:45 PM > 7. Select "Qualcomm USB Configuration". INFO : 8/12/2015 5:20:45 PM > 8. Select "USB-MTP-SDB". INFO : 8/12/2015 5:20:45 PM > 9. Press Home button. INFO : 8/12/2015 5:23:43 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:23:43 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:23:43 PM > Selected port: COM154 INFO : 8/12/2015 5:23:43 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:24:03 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:24:03 PM > Select Certificate2... INFO : 8/12/2015 5:24:05 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:24:05 PM > Searching for a phone. Please wait... INFO : 8/12/2015 5:24:17 PM > Found phone on COM154 INFO : 8/12/2015 5:24:17 PM > Reading info... INFO : 8/12/2015 5:24:19 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:24:19 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:24:19 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:24:22 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:24:24 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:24:24 PM > Checking Certificate file... INFO : 8/12/2015 5:24:24 PM > Certificate file successfully checked ERROR : 8/12/2015 5:24:30 PM > Writing Certificate failed INFO : 8/12/2015 5:24:45 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:24:46 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:24:46 PM > Selected port: COM154 INFO : 8/12/2015 5:24:46 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:24:48 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:24:48 PM > Select Certificate2... INFO : 8/12/2015 5:24:52 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:24:52 PM > Searching for a phone. Please wait... INFO : 8/12/2015 5:25:04 PM > Found phone on COM154 INFO : 8/12/2015 5:25:04 PM > Reading info... INFO : 8/12/2015 5:25:06 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:25:06 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:25:06 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:25:08 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:25:11 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:25:11 PM > Checking Certificate file... INFO : 8/12/2015 5:25:11 PM > Certificate file successfully checked ERROR : 8/12/2015 5:25:16 PM > Writing Certificate failed INFO : 8/12/2015 5:26:08 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:26:08 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:26:09 PM > Selected port: COM154 INFO : 8/12/2015 5:26:09 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:26:42 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:26:42 PM > Select Certificate2... INFO : 8/12/2015 5:26:44 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:26:44 PM > Searching for a phone. Please wait... INFO : 8/12/2015 5:26:56 PM > Found phone on COM154 INFO : 8/12/2015 5:26:56 PM > Reading info... INFO : 8/12/2015 5:26:58 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:26:58 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:26:58 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:27:00 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:27:02 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:27:02 PM > Checking Certificate file... INFO : 8/12/2015 5:27:02 PM > Certificate file successfully checked ERROR : 8/12/2015 5:27:08 PM > Writing Certificate failed INFO : 8/12/2015 5:27:21 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:27:21 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:27:21 PM > Selected port: COM154 INFO : 8/12/2015 5:27:22 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:27:24 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:27:25 PM > Select Certificate2... INFO : 8/12/2015 5:27:29 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:27:29 PM > Searching for a phone. Please wait... INFO : 8/12/2015 5:27:41 PM > Found phone on COM154 INFO : 8/12/2015 5:27:41 PM > Reading info... INFO : 8/12/2015 5:27:43 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:27:43 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:27:43 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:27:45 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:27:47 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:27:47 PM > Checking Certificate file... INFO : 8/12/2015 5:27:47 PM > Certificate file successfully checked ERROR : 8/12/2015 5:27:53 PM > Writing Certificate failed INFO : 8/12/2015 5:29:01 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:29:01 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:29:01 PM > Selected port: COM154 INFO : 8/12/2015 5:29:01 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:29:15 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:29:15 PM > Select Certificate2... INFO : 8/12/2015 5:29:17 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:29:17 PM > Searching for a phone. Please wait... ERROR : 8/12/2015 5:31:49 PM > Writing Certificate failed INFO : 8/12/2015 5:31:58 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:31:58 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:31:58 PM > Selected port: COM154 INFO : 8/12/2015 5:31:58 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:31:58 PM > Reading info, please wait... INFO : 8/12/2015 5:32:10 PM > Found phone on COM154 INFO : 8/12/2015 5:32:12 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:32:12 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:32:12 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:32:15 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:32:17 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:32:21 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:32:22 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:32:22 PM > Selected port: COM154 INFO : 8/12/2015 5:32:22 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:32:25 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:32:25 PM > Select Certificate2... INFO : 8/12/2015 5:32:28 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:32:28 PM > Searching for a phone. Please wait... INFO : 8/12/2015 5:32:40 PM > Found phone on COM154 INFO : 8/12/2015 5:32:40 PM > Reading info... INFO : 8/12/2015 5:32:42 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:32:42 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:32:42 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:32:45 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:32:47 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:32:47 PM > Checking Certificate file... INFO : 8/12/2015 5:32:47 PM > Certificate file successfully checked ERROR : 8/12/2015 5:32:53 PM > Writing Certificate failed INFO : 8/12/2015 5:33:26 PM > ----------------------------------------------------------------------------------- INFO : 8/12/2015 5:33:27 PM > Platform: Samsung Tizen INFO : 8/12/2015 5:33:27 PM > Selected port: COM154 INFO : 8/12/2015 5:33:27 PM > Selected model: SM-Z130H INFO : 8/12/2015 5:33:30 PM > Selected file: C:\Users\ideal institute\Downloads\Cert_SM-Z130H_357394061478828.cert INFO : 8/12/2015 5:33:30 PM > Select Certificate2... INFO : 8/12/2015 5:33:35 PM > Selected file: C:\Users\ideal institute\Downloads\New folder\Cert_SM-Z130H_357395061478825.cert INFO : 8/12/2015 5:33:35 PM > Searching for a phone. Please wait... INFO : 8/12/2015 5:33:47 PM > Found phone on COM154 INFO : 8/12/2015 5:33:47 PM > Reading info... INFO : 8/12/2015 5:33:49 PM > SW version: Z130HDDU0BOB2/Z130HODD0BOB2/Z130HDDU0ANL8/Z130HDDU0BOB2 INFO : 8/12/2015 5:33:49 PM > HW Version: SM-Z130HZWDINS INFO : 8/12/2015 5:33:49 PM > Phone IMEI A: 357394-06-869380-9 INFO : 8/12/2015 5:33:51 PM > Phone IMEI B: 357395-06-869380-6 INFO : 8/12/2015 5:33:54 PM > Phone SN: RZ1G52QBPQ INFO : 8/12/2015 5:33:54 PM > Checking Certificate file... INFO : 8/12/2015 5:33:54 PM > Certificate file successfully checked ERROR : 8/12/2015 5:33:59 PM > Writing Certificate failed |
08-12-2015, 14:00 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please make Factory Reset and reflash the phone with "special_z130hddu0bob2_z130hodd0bob2_z130hddu0anl8 .oct" firmware again, then repeat "Write Cert" operation. If problem will remain the same - upload latest *.log and *.logx files of performed operations. Also, read out phone's Security ("Read Security" button) and upload it. Post here download links, we will check the files. |
08-13-2015, 14:00 | #15 (permalink) |
Member: 2310475 Status: Offline Thanks Meter: 64 | sir i make Factory Reset and reflash the phone with "special_z130hddu0bob2_z130hodd0bob2_z130hddu0 anl8 .oct" firmware again, then repeat "Write Cert" operation, but same write cert faild ............................... |
