07-22-2017, 16:29 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | Z200y Please enable SDB and Root the device [Solved] Please check log and need help urgent... To connect SM-Z200F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. On dial pad type *#84936# to enable Developer Option. 3. Go to Settings -> Developer Options. 5. Turn on "USB Debugging" option. Selected firmware file: SM-Z200F_ROOT.oct Please put the phone into Download Mode and connect USB cable. To put SM-Z200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ROOTFS section... ROOTFS section has been written successfully. Firmware writing successfully completed. Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Tizen Selected port: COM10 Selected model: SM-Z200F Searching for a phone. Please wait... Found phone on COM186 Reading info... SW version: Z200FDDU0API2/Z200YOJV0BQC3/Z200YXXU0BPI2/Z200FDDU0AP I2 HW Version: SM-Z200YZDAXFV Phone IMEI B: FFFFFFFFFFFFFF0 Phone SN: unknown Connecting to SDB daemon.. Please enable SDB and Root the device! Write IMEI failed Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- To connect SM-Z200Y phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. On dial pad type *#84936# to enable Developer Option. 3. Go to Settings -> Developer Options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Tizen Selected port: COM186 Selected model: SM-Z200Y Searching for a phone. Please wait... Found phone on COM186 Reading info... SW version: Z200FDDU0API2/Z200YOJV0BQC3/Z200YXXU0BPI2/Z200FDDU0API2 HW Version: SM-Z200YZDAXFV Phone IMEI B: FFFFFFFFFFFFFF0 Phone SN: unknown Connecting to SDB daemon.. Please enable SDB and Root the device! Write IMEI failed Performed by 2.5.6 Software version. Sent from my D5803 using Tapatalk Last edited by Octopus box; 07-24-2017 at 08:04. |
