Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Philips
Old 04-03-2001, 12:48   #1 (permalink)
Member: 3637
Angry Dead Savvy, help!
I have a dead savvy 128 & tried to flash it without success.
1) I flash it with Tcd_flash & 128 flash, but after 100% program says "Exiting..." and nothing happens.
Battery was full, but I tried even with an external power... all without success. Still completely dead.
Is there any way to make it alive?
Thanx.
Old 04-03-2001, 21:00   #2 (permalink)
Member: 858
Post
try to flash it some more time , i had such a problem and i flashed it about 5 times and it helped .
good luck
best reagard
darek
Old 04-04-2001, 14:17   #3 (permalink)
Member: 3637
Post
Thanx, Darek, but I've tried for about 15 times and it was always the same: "Exiting..." and... nothing!
Old 04-04-2001, 14:34   #4 (permalink)
HFP
HFP's Avatar
Member: 3529
Post
Hi! May be bad EEPROM! Rewrite EEpROM and flash phone.
Regards.
Peter
[ 04 April 2001 15:36: Message edited by: HFP ]
Old 04-06-2001, 09:53   #5 (permalink)
Member: 3637
Post
How to rewrite EEPROM?
With the same program, or with something else?
D.
Old 04-06-2001, 13:55   #6 (permalink)
HFP
HFP's Avatar
Member: 3529
Post
With PonyProg!!!
Old 08-15-2004, 07:04   #7 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
ohh can we write in savvy with any other program and savvy cable?
Old 08-15-2004, 13:30   #8 (permalink)
kone's Avatar
Member: 17753
Cool Savy 100% working solution
You can write the eeprom with this soft and this eeprom
I have repaired many savy phones with this !
If you can not write the eeprom with this you must use ponyprog and write the eeprom if you need the eeprom for pony prog i can send you
You have to rename the file eepromOK original 128 cable from .doc to .rar and the unpack it original extension is .bin
File Type: doc eepromOK original 128 cable.doc (910 Bytes, 49 views)
Old 08-15-2004, 19:02   #9 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
and which software to use to flash a savvy?
help
Old 08-16-2004, 08:19   #10 (permalink)
kone's Avatar
Member: 17753
with this sw
If you dont have contact me
I will send you
DEAD SL75 help help help help... dogeatdog S-Gold Based Phones 15 07-26-2008 13:07
a dead savvy t128/bc after trying to flash with SWUP chowdary Philips 1 05-13-2006 22:47
Dead Savvy !!! Help !!! mobile-bits Philips 0 07-01-2002 06:45
Philips Savvy Vogue 188 W1 - dead, please help mobitech Philips 0 05-15-2001 10:41
need savvy help marksarahtom Philips 0 03-30-2001 22:36
Page generated in 0.24179 seconds with 10 queries
