10-01-2003, 08:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 60
Member: 27037 Status: Offline Thanks Meter: 2 | Delok Soft And Ultralogic Box From Multicom I have bought 3 month ago PHILIPS DELOK Software to use with CHINA UNIBOX V 4.0. IMPOSSIBLE TO ENTER IN TAT MODE WITH XENIUM, AZALIS ETC... IMPOSSIBLE TO CONNECT WITH FISIO 62X/82X. AS THEY SAID IN THEIR MANUAL THEY HAVE TEST ALSO THEIR SOFT WITH UNIBOX V3.0 FROM GSM-TECHNOLOGY. SO IN THIS WAY I HAVE BOUGHT ULTRALOGIC BOX FROM MULTI-COM OWNER OF GSM-TECHNOLOGY. NOW TAT MODE IS OK FOR XENIUM BUT SOFT IS NOT ABLE TO READ CORRECT IMEI, MOST FUNCTION DON'T WORK. AFTER CHECKING WITH DELOK, HEREAFTER WHAT THEY SUGGEST TO ME : Its still cable problem! PC read data from phone with lot of noise. This problem can be solved in easy way. You need 1.5kOm resistor and solder iron. 1. Disassemble phone connector. 2. Solder one wire of resistor to pin 4. 3. If you use universal box, then try to find contact with +5V power supply (using voltmeter). Solder another wire of resistor to founded +5V wire. Please do it and all will be ok. AFTER CHECKING PINOUTS FROM MY SIDE I HAVE FOUND AS FOLLOWS : RJ45 PINOUT OF ULTRALOGIC BOX 1 VCC I DO NOT KNOW IF ULTRALOGIC USE MAX 3232 OR 232 SO DO NOT KNOW IF IT SUPPLY +3VOLTS OR +5 VOLTS 4 RX 5 TX 7 GND PINOUT OF SAVVY CABLE FOR ULTRALOGIC BOX 1 GND 4 TX 5 RX PINOUT OF FISIO CABLE FOR ULTRALOGIC BOX 1 GND 4 TX----1kOm----VCC 5 RX----1kOm----VCC HERE WHAT I HAVE WITH FISIO 62X/82X : Ready... Waiting for ignition... Loading boot.......OK?????????? Read Flash ID error! Flash ID read error! ADN FOR XENIUM Ready... Waiting for ignition... Detecting phone version... Phone TAT ID: 99042302 Type: PHILIPS-Xenium9@9 17/04/2001 IMEI: 34BEDC-FD-BCE67F ?????????????????????????????????????????????????? ?? SIM Lock status: NCK : 00007107000485 - OPEN - 9C:C3 NSCK: 000407** - ERROR! - C7:FF SPCK: 0034**** - OPEN - 3B:E8 CCK : 00****** - OPEN - BD:75 PCK : 0034**** - OPEN - 99:39 Warning! Lang.Pack signature missing! Ready... Setting SIM Lock data...OK SIM Lock init...OK Reading SIM Lock data...OK Setting new IMEI...OK IMEI: 449684-51-272394 SIM Lock status: NCK : 00007107000485 - OPEN - 9C:C3 NSCK: 000407** - OPEN - C7:FF SPCK: 0034**** - OPEN - 3B:E8 CCK : 00****** - OPEN - BD:75 PCK : 0034**** - OPEN - 99:39 Warning! Lang.Pack signature missing! Ready... Setting SIM Lock data...OK SIM Lock init...OK Reading SIM Lock data...OK IMEI: 981204-59-743655 SIM Lock status: NCK : 00007107000485 - OPEN - 9C:C3 NSCK: 000407** - OPEN - C7:FF SPCK: 0034**** - OPEN - 3B:E8 CCK : 00****** - OPEN - BD:75 PCK : 0034**** - OPEN - 99:39 Warning! Lang.Pack signature missing! Ready... Software never , never read the good IMEI from Gsm. I can't reset wap, factory setting, init setup data etc ...... Most of GSM are not recognise. As you said I tried to backup the flash to send to you. You will find hereafter log done with the SAME GSM. Never the same IMEI !!!!!!!!!!!! impossible to read flash and so on.........not the same locks status. It is the same problem with many and many xenium, fisio 120 etc.... Ready... Waiting for ignition... Detecting phone version... Phone TAT ID: 99042302 Type: PHILIPS-Xenium9@9 17/04/2001 IMEI: 34BEDC-FD-BCE67F SIM Lock status: NCK : 00000000000000000000000000000000 - OPEN - 00:00 NSCK: 00000000000000000000000000000000 - OPEN - 00:00 SPCK: 00000000000000000000000000000000 - OPEN - 00:00 CCK : 00000000000000000000000000000000 - OPEN - 00:00 PCK : 00000000000000000000000000000000 - OPEN - 00:00 Warning! Lang.Pack signature missing! Ready... Waiting for ignition... Loading boot......OK Flash ID:404A213E - Unkn.Vendor Possible Flash size 4Mb Ready... Reading Flash...Error! Reading ACK error at 00200000 ALL THESE HAVE BEEN RESULT WITHOUT ANY MODS ON ULTRALOGIC CABLES. WILL POST RESULT WHEN MADE MODS AS PER THEIR SUGGESTION |
10-01-2003, 11:15 | #3 (permalink) |
No Life Poster Join Date: Apr 2001 Location: on the beach
Member: 4160 Status: Offline Thanks Meter: 1 | Hi, Use a normal data cable with some modifications (on Delok CD,you will found a txt or Adobe file and all is explained about the modifications) after that you must power the cable with 3,5/3,7v maxi and it work perfectly BR |
10-02-2003, 00:09 | #4 (permalink) |
Member: 27037 Status: Offline Thanks Meter: 2 | 999999999999% READY MADE CABLE Hello, Does anybody sell 999999999999% READY MADE CABLES TO USE WITH PHILIKS DELOK SOFTWARE ???????? I HAVE SOLDERED ONE WIRE OF R1.5kOm to PIN 4 (TX) and other wire to +5volt . and I still have same trouble. Unable to read the good IMEI. I am fedup with this software. Looking perhaps to buy SAnchez Soft with include cables sets. |
10-02-2003, 04:44 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: england Age: 65
Member: 24552 Status: Offline Thanks Meter: 13 | sanchez cables work fine on his soft but if you use on delok you need external power .sanchez provide the cable with the program. those uni box things not to good |
10-04-2003, 12:12 | #6 (permalink) |
No Life Poster Join Date: Jun 2003 Location: kinshasa, D.R.C. Age: 59
Member: 31246 Status: Offline Thanks Meter: 54 | i have also a trouble with the same soft of DELOK. I install it and run in windows xp and millenium, but it doesn't work and they ask me to run it in windows 98 SE. Why this soft doesn't run with the news versions windows ? |
10-04-2003, 12:19 | #7 (permalink) |
Member: 24552 Status: Offline Thanks Meter: 13 | did you buy from delok or other soft that looks like delok that is the most unstable i ever saw. Delok works but look alike stuff with usb dongle may as well through away i have one of these free to anybody who wants and i have had no takers |
10-04-2003, 12:43 | #10 (permalink) |
Member: 31246 Status: Offline Thanks Meter: 54 | For me, it's not a cabvle problem, but the soft doesn't run in windows millenium or Xp and they ask me to try it in 98SE. I don't know if it will work. |
11-05-2003, 17:09 | #12 (permalink) | |
No Life Poster Join Date: Nov 2000 Location: Boro Age: 37
Member: 2461 Status: Offline Thanks Meter: 22 | Quote:
Can I have this free dongle I love the words FREE.! Rgds John... | |
11-05-2003, 18:08 | #13 (permalink) |
Member: 4160 Status: Offline Thanks Meter: 1 | Hi Philips by Delok work fine on Millenium and 98 ( on my AMD 800). Or you've a problem on your cable or if your PC is powerfull , sometimes it doesn't work . BR |
Need Sendo Delok Soft And Flash | Siemens man | DELOK DONGLE | 11 | 04-07-2007 14:22 |
Ultralogic Box And Sagmaster Dongle [used]. | YUSUFF A.B. | Sell ur Old and Used Stuff | 0 | 05-17-2006 13:18 |
Question about upgrade Twister from MultiCom | fingusio | Twisterflasher | 3 | 04-10-2005 19:28 |
Twister Cables And Ultralogic Box | domantas | Twisterflasher | 1 | 01-30-2005 19:40 |
UltraLogic Box - All in one !!!! | B.Przemek | Main Sales Section | 0 | 09-12-2003 20:59 |
