Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Philips
Old 07-23-2007, 10:35   #1 (permalink)
Member: 516151
philips 355 permenently blocked
philips 355 permenently blocked i am flasing multi box and unlock ,but same problem pls give me one answer.i waiting for ur answer plsssss
Old 07-27-2007, 20:33   #2 (permalink)
visionmaster20's Avatar
Member: 214200
I have one permenently blocked i need too solution
Old 07-27-2007, 21:20   #3 (permalink)
Ionel's Avatar
Member: 81232
Try with multibox , write full flash and unlock it .
Old 07-28-2007, 00:19   #4 (permalink)
octavyus's Avatar
Member: 242469
you resolved with full flash only
tool avaible for reapir
Red Box
Multi delok
Rvolume
Old 07-28-2007, 00:20   #5 (permalink)
octavyus's Avatar
Member: 242469
very important
after flash you need repeat unlock process, you can use pluto XP version Free
Old 08-03-2007, 10:17   #6 (permalink)
FZA
Member: 210174
Hello
I just wanted to find out which cable does phillip 355 use
thank you in advance
Old 08-03-2007, 23:35   #7 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Try to make a reset eeprom with Thunderstorm if You can or a fullflash.
Old 08-05-2007, 10:50   #8 (permalink)
Member: 516151
permenent blocked
i have a solution for philips 355 permenet block
i amread anather355 backup all flash and that file restorefrome backup, then set unlock set full ok
Old 08-05-2007, 10:51   #9 (permalink)
Member: 516151
philips 355 permenently blocked shanavastk Multi-Box 8 07-21-2008 11:03
philips 535 permenently blocked Moosani Multi-Box 5 02-06-2007 09:55
philips 535 permenently blocked celluniversal Philips 6 02-06-2007 07:49
Azalis loop permenly blocked . ? --==Dixon==-- Philips 14 10-04-2002 12:32
FISIO 311 permenly blocked read. --==Dixon==-- Philips 2 09-25-2002 08:31
Page generated in 0.38419 seconds with 11 queries
