12-03-2000, 02:17 | #1 (permalink) |
Insane Poster Join Date: May 2000 Location: CZ
Member: 1326 Status: Offline Thanks Meter: 0 | Philips SAVVY cable I can't find SAVVY cable schemantics, can anyone has it? Or can someone please send me hints for eeprom solution? I have TCD128/BB Thnx a lot in advance. ~ChM |
12-03-2000, 03:18 | #3 (permalink) |
Member: 1326 Status: Offline Thanks Meter: 0 | Hi, I was realy lamah. Now I hope it's better I urgently need to unlock Savvy 128/BB via cable. I can't get run Savvy Tools 1.5 Cracked by CyberPhreack. It still tells: "-" is not a valid integer value. and then wants to enter registration. Is there any other soft or is 128/BB unlockable only by eeprom solution? |
12-03-2000, 12:28 | #4 (permalink) |
Insane Poster Join Date: May 1999
Member: 109 Status: Offline Thanks Meter: 1 | pinout: KEYBOARD AT THE BOTTOM 12|11| |10|9|8|7|6|5|4|3|2| |1| 1 GND 4 TX 5 RX if oyu cannot get ca cable (like me) just do the following: take a standard fbus cable (gnd rx tx) and solder crocodile connectors to the ends of the cable (instead of a connector). just put steel nadles in the system connector and connect them to the crocodiles. beware: nadles mustn't connect each other. otherwise your phone will get damaged ! use savvy tools 1.5 cracked by cyberphreak to read NCK. then insert a wrong card and enter NCK. thats all. software can be downloaded at http://www.easynet.hu/~phonesoft/ good luck ! works! all tested ! greets from Squesch |
12-03-2000, 18:05 | #5 (permalink) |
Member: 1326 Status: Offline Thanks Meter: 0 | Thanx a lot for a guide. I finaly did that beast. Cable wasn't problem, but savvy tools 1.5 cracked by cyberphreak didn't worked for me. So I used Savvy 1.1 by Saras and read the phone. As I have 128/BB, I selected 128/BL and NCK works fine. That's all. P.S: I've tried All Philips Tool v1.01 too, it worked well, and it can read NCK code too. |
09-08-2023, 20:34 | #6 (permalink) | ||
Junior Member Join Date: Feb 2023 Location: KONYA
Member: 3031909 Status: Offline Sonork: 9899989 Thanks Meter: 0 | Quote:
Please | ||
philips savvy cable | Inovator | Philips | 1 | 10-21-2005 16:49 |
Philips Savvy cable with external power source | 75133 | Philips | 0 | 12-25-2001 23:22 |
Philips Savvy cable & pinsout | rhd | Philips | 2 | 11-02-2001 04:26 |
Cable shematic for Philips Savvy ? | talenat | Various | 0 | 08-05-2000 10:37 |
I need the Philip savvy unlocker by cable ( NOT DB) | Bert | Various | 0 | 03-17-2000 10:38 |
