06-05-2006, 12:13 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 53
Member: 91905 Status: Offline Thanks Meter: 3 | Philips Secret Codes PHILLIPS: *#06# -> Displays imei *#2254*# -> Status Register: C, BS, RR, MMI, CREAT *#2255*# -> Activate & Deactivate the "DEBUG CALL"- *#2558*# -> The time in days, hours & minutes you are connected to the net *#2562*# -> Not Clear; the phone reconnects to the net *#2565*# -> Not Clear; Warmstart? *#3333*# -> (NO) BLOCKING - list (15 Items) *#2377*# -> "BEER": not clear, the phone waits a random time and reconnects to the net, sometimes the phone makes a reset *#3377*# -> Init, Flags, SIM LCK *#3353*# -> Resets the (NO) BLOCKING - list *#7378*# -> Name, Length, SIM phase *#7489*# -> SECURITY CODE *#7693*# -> You can activate & deactivate the SLEEP MODE (when deactivated the battery will go down) *#7787*# -> Not clear: SPURIOUS INTERRUPT *#7948*# -> SWITCH OFF: not clear; it is a timer or something *#8463*# -> Some information about the SLEEP MODE Philips Genie (TCD838) *#2337*# -> Will activate the beep signal when the cellphone reconnected to the net |
10-11-2006, 08:38 | #6 (permalink) |
Freak Poster Join Date: Apr 2006 Location: turkey Age: 48
Member: 265087 Status: Offline Thanks Meter: 577 | -------------------------------------------------------------------------------- Service Codes Alcatel Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) ###728# - factory reset (with SIM) Alcatel 835 formating - **0102# Samsung *2767*3855# - FULL E2P RESET *2767*2878# - CUSTOM E2P RESET #*7337# - UNLOCK *2767*688# - UNLOCK *#0523# - CONTRAST *#9998*523# - CONTRAST *#8999*8378# - Service Menu (X100) Philips #20021208# ok - 630 without SIM (erase flash) *#7728*# - RSAV DONE *#3849*# - ??? reboot *#3851*# - ??? reboot Philips 568 *01763*737381# - reset Pantech *01763*737381# - master reset (user data, user code) without SIM *01763*8371# - SW version *01763*6371# - UNLOCK *01763*3641# - Menu Panasonic *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55.. *369#(*) - MENU 7, 4, 6, menu, menu - lock menu *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..) LG 2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...) 2945#(*)- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# Sony-Ericsson > * < < * < * - Service menu < * * < - Lock menu VK Mobile *#79# - SW version *#85*364# (*) - hold menu 855855# without SIM (VG107) 85558555#(*)-hold 4268#(*)-hold (VG207) Voxtel 0124 - master code 0718#(*)- hold - menu (ST11, SC10, V100 without SIM) 4268#(*)- hold - show code (ST11, SC10 without SIM) *789(#)- hold - menu (V50, V300, RX100 without SIM) Motorola (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on Nokia *#7370925538# (valet code reset) 6230 *#746025625# [*#sim0clock#] *#92702689# [*#war0anty#] Fly Bird S688 - #*301#02# send - with SIM menu: 7 - 10 - ok, #*8000#, #*3676# (reboot repair) V09, S1180 - *, 3 times down, 3 times up - service menu Enol *#987*00# - Service menu *#987*99# - Full reset *#900# - SW version Maxon *#9922# - menu, reset (without SIM) *#9900# - Software Version *#9901# - Software Version (PBatch) S60 Siries (SX1, 6600, N-Gage..) *#7780# - factory default *#7370# - full factory defaults (all user data reset) SX1 formating - * + # + power on 6600 formating - 3 + * + send + power on Sendo X1 formating - 5 + power on Mitsubishi *65512890 (*-hold) format FFS (Eclipse) * 3926 - (*-hold) test mode * 5806 - (*-hold) SW version *(hold) 787090 - trium 320 unlock menu Huawei (cdma) MASTER SECURITY CODE -309296 -3092 -9296 Pantech HX-550C (cdma) Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR, after reset - ##27732726 PWR and select "with uim" Best Regards, Pfeilmayer Robert |
10-26-2006, 12:23 | #7 (permalink) |
Junior Member Join Date: Aug 2006 Location: Russia Age: 51
Member: 335043 Status: Offline Thanks Meter: 0 | Philips Xenium 9@9D (CT2898) *#06# - IMEI *#2355*# - NetMonitor *#4732*# - "Downloading" SW 02530003 *#6837*# - "Version" SW 02530003 Pack_resid EastEurope Only this code from *#2000*# to *#8000*# was accepted by phone. |
10-10-2007, 22:15 | #12 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | this code may can u help........................... Service codes "Chinese" models: default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Factory mode: *#987# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Restore factory settings: *#987*99# LCD contrast: *#369# software version: *#800# software version: *#900# set default language: *#0000# Send set English language: *#0044# Send set English language (new firmware): *#001# Send thanks reaz |
Cable Finder + Secret Code + How to Enter Unlock Code V 1.6 Ready !!! | mughalG | Universal GSM Software | 17 | 11-04-2010 18:37 |
C139 handset codes... Secret Codes | gsm1999 | Motorola ODM | 13 | 04-28-2008 12:19 |
phone code for motorola by entering some secret code!!! | mikSer | Motorola Old Legacy (EMMI) | 0 | 09-12-2002 01:47 |
please help to find a secret code of phone (+) | magsat | Motorola Old Legacy (EMMI) | 2 | 01-31-2002 08:06 |
Siemens x35 secret codes listing - must see it ! | french_g | x1x to x45/x50 | 3 | 10-12-2000 08:33 |
