Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Philips
Old 06-05-2006, 12:13   #1 (permalink)
Member: 91905
Thanks Meter: 3
Philips Secret Codes
PHILIPS SECRET CODES
PHILLIPS:
*#06# -> Displays imei
*#2254*# -> Status Register: C, BS, RR, MMI, CREAT
*#2255*# -> Activate & Deactivate the "DEBUG CALL"-
*#2558*# -> The time in days, hours & minutes you are connected to the net
*#2562*# -> Not Clear; the phone reconnects to the net
*#2565*# -> Not Clear; Warmstart?
*#3333*# -> (NO) BLOCKING - list (15 Items)
*#2377*# -> "BEER": not clear, the phone waits a random time and reconnects to the net,
sometimes the phone makes a reset
*#3377*# -> Init, Flags, SIM LCK
*#3353*# -> Resets the (NO) BLOCKING - list
*#7378*# -> Name, Length, SIM phase
*#7489*# -> SECURITY CODE
*#7693*# -> You can activate & deactivate the SLEEP MODE
(when deactivated the battery will go down)
*#7787*# -> Not clear: SPURIOUS INTERRUPT
*#7948*# -> SWITCH OFF: not clear; it is a timer or something
*#8463*# -> Some information about the SLEEP MODE
Philips Genie (TCD838)
*#2337*# -> Will activate the beep signal when the cellphone reconnected to the net
Old 06-05-2006, 18:59   #2 (permalink)
gsmlab4u's Avatar
Member: 86003
Thanks Meter: 5
goood???????????do somethin better!!!!!!!
gsmlab4u
Old 06-07-2006, 11:10   #3 (permalink)
Temporary banned !!
sajib_ngage's Avatar
Member: 243500
Sonork: 100.1590322
Thanks Meter: 584
philips 568 phone code locked!
please helpe me.
Old 10-10-2006, 15:40   #4 (permalink)
Member: 253021
Sonork: 1585469
Thanks Meter: 75
pls purchage a unlock dongle, then unlock it, if not then quit from this job
Old 10-10-2006, 19:18   #5 (permalink)
Member: 175146
Thanks Meter: 6
HERE is a list with Service codes for a few mobile phones ...
Old 10-11-2006, 08:38   #6 (permalink)
ufuktakiadam's Avatar
Member: 265087
Thanks Meter: 577
Service Codes
Alcatel
Master Codes
- 25228352
- 25228353
- 83227423 (***/4,BH4,BF5,BG3,BF3/4..)
###337*07# - master reset (with SIM)
###847# - factory reset (with SIM)
###728# - factory reset (with SIM)
Alcatel 835 formating - **0102#
Samsung
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
*#8999*8378# - Service Menu (X100)
Philips
#20021208# ok - 630 without SIM (erase flash)
*#7728*# - RSAV DONE
*#3849*# - ??? reboot
*#3851*# - ??? reboot
Philips 568 *01763*737381# - reset
Pantech
*01763*737381# - master reset (user data, user code) without SIM
*01763*8371# - SW version
*01763*6371# - UNLOCK
*01763*3641# - Menu
Panasonic
*01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55..
*369#(*) - MENU
7, 4, 6, menu, menu - lock menu
*#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..)
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
Sony-Ericsson
> * < < * < * - Service menu
< * * < - Lock menu
VK Mobile
*#79# - SW version
*#85*364# (*) - hold menu
855855# without SIM (VG107)
85558555#(*)-hold
4268#(*)-hold (VG207)
Voxtel
0124 - master code
0718#(*)- hold - menu (ST11, SC10, V100 without SIM)
4268#(*)- hold - show code (ST11, SC10 without SIM)
*789(#)- hold - menu (V50, V300, RX100 without SIM)
Motorola
(T190, T191, T205) master code
- 19980722
- 20010903
P2K test menu:
*#06#, menu, menu, 048263*
Test comands:
32*116*1*0*0 - read phone code
32*118*1*0*0 - read security code
18*0 - factory reset, phone code off
18*1 - master reset
54*18*1 - full phone reset
10*0*6 - select 900/1800
32*279*1*0*8 - model
32*383*1*0*0 - flex version
Hard reset MPX200, MPX220 - blue button + power on
Nokia
*#7370925538# (valet code reset) 6230
*#746025625# [*#sim0clock#]
*#92702689# [*#war0anty#]
Fly Bird
S688 - #*301#02# send - with SIM
menu:
7 - 10 - ok,
#*8000#, #*3676# (reboot repair)
V09, S1180 - *, 3 times down, 3 times up - service menu
Enol
*#987*00# - Service menu
*#987*99# - Full reset
*#900# - SW version
Maxon
*#9922# - menu, reset (without SIM)
*#9900# - Software Version
*#9901# - Software Version (PBatch)
S60 Siries (SX1, 6600, N-Gage..)
*#7780# - factory default
*#7370# - full factory defaults (all user data reset)
SX1 formating - * + # + power on
6600 formating - 3 + * + send + power on
Sendo X1 formating - 5 + power on
Mitsubishi
*65512890 (*-hold) format FFS (Eclipse)
* 3926 - (*-hold) test mode
* 5806 - (*-hold) SW version
*(hold) 787090 - trium 320 unlock menu
Huawei (cdma)
MASTER SECURITY CODE
-309296
-3092
-9296
Pantech HX-550C (cdma)
Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR,
after reset - ##27732726 PWR and select "with uim"
Best Regards,
Pfeilmayer Robert
Old 10-26-2006, 12:23   #7 (permalink)
Member: 335043
Philips Xenium 9@9D (CT2898)
*#06# - IMEI
*#2355*# - NetMonitor
*#4732*# - "Downloading" SW 02530003
*#6837*# - "Version" SW 02530003 Pack_resid EastEurope
Only this code from *#2000*# to *#8000*# was accepted by phone.
Old 11-03-2006, 09:31   #8 (permalink)
rpbongp's Avatar
Member: 144043
Thanks Meter: 12
@ufuktakiadam thank you very much your the man.
Old 09-10-2007, 07:02   #9 (permalink)
Member: 455439
Thanks Meter: 14
Cect master coad plz
Old 09-10-2007, 11:54   #10 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
thank for information ;keep share
Old 09-29-2007, 15:55   #11 (permalink)
Member: 464341
Thanks Meter: 11
hellow az -liton
use infinity box for unlock cect
Old 10-10-2007, 22:15   #12 (permalink)
Member: 310155
Thanks Meter: 1,313
this code may can u help...........................
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
thanks
reaz
Old 10-11-2007, 00:19   #13 (permalink)
espoir1's Avatar
Member: 7599
Thanks Meter: 14
thank for this codes ;keep share
Old 10-11-2007, 03:18   #14 (permalink)
Member: 28889
Thanks Meter: 16
thanks for the codes
Old 11-17-2007, 08:18   #15 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
bords, how to used this code?with sim?w/out sim?
Cable Finder + Secret Code + How to Enter Unlock Code V 1.6 Ready !!! mughalG Universal GSM Software 17 11-04-2010 18:37
C139 handset codes... Secret Codes gsm1999 Motorola ODM 13 04-28-2008 12:19
phone code for motorola by entering some secret code!!! mikSer Motorola Old Legacy (EMMI) 0 09-12-2002 01:47
please help to find a secret code of phone (+) magsat Motorola Old Legacy (EMMI) 2 01-31-2002 08:06
Siemens x35 secret codes listing - must see it ! french_g x1x to x45/x50 3 10-12-2000 08:33
Page generated in 0.23294 seconds with 10 queries
