07-08-2017, 04:51 | #61 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
For detect a router in PC using bootpoint 1-solder a USB cable in router USB points 2-remove charger from router 3-connrct router USB cable to PC 4-short a testpoint of router using twezer 5-without disconnect tweezer from a boot point connect charger in router 6-pc detect a boot port PC ui boot 3g(now remove tweezer from boot points ) 7-write b310firmware 21.180.99.01.00 8-after firmware flash done ,then unlock a modem using unlock button on mkey software 9-write firmware 21.300.01.00.00 Done Br-balwinder27 Mkey-team | |
07-09-2017, 08:29 | #65 (permalink) | |
you need a short a tp of b310 then write this 1st firmware on boot mode B310s-927_21.180.99.01.00_BL_FW then unlock a modem write 2nd firmware B310s-927_21.300.01.00.00_FW done br-balwinder27 mkey-team | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
07-22-2017, 14:55 | #66 (permalink) |
Junior Member Join Date: Jul 2017 Age: 42
Member: 2738022 Status: Offline Thanks Meter: 0 | STC B310s-927 usb problem Hi! I have stc b310s-927 with firmware version 21.316.01.00.1304 , and i cannot get my computer to recognize it via usb, even on boot shot. i have changed usb cable twice, re-soldered each at least twice(i'm sure my soldering is good), tested it on two different laptops (windows 8.1 and windows 10), and it still cannot be recognized. I have already installed mobile partner and BOS solution registry file, and nothing changed. On some blog I've read they say, this is because of its firmware that prevents the modem from being connected via usb. Has anyone found a way to get around this usb detection problem? Kindly teach me if anybody has made any breakthrough with this kind of problem. Looking forward |
07-22-2017, 15:38 | #67 (permalink) | |
Better then you use windows 7 you not face this issue,which issue you face it is only windows 10 and 8 issue (firmware prevent stc b310 is latest security came without boot short router not detect using USB cable ,so boot short required a boot point ) Change your operating system to windows 7 then all problem resolve and b310 router detect in boot Br-balwinder27 Mkey-team | |
07-24-2017, 20:38 | #68 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2477644 Status: Offline Thanks Meter: 4 | Same problem happened 2 me....i hav soldering with 2 wire seperately..used 2 operating system windos 7 & xp...but not detecting...previously i thought..its router fault..but balwinder27 HELP ME THIS TIME .HE TOLD ME THE TRUTH...ITS FOR FIRMWARE UPDATE.. NOW WAITING FOR SOLUTION |
07-26-2017, 05:40 | #69 (permalink) | |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
11-30-2017, 10:59 | #72 (permalink) |
Freak Poster Join Date: Sep 2009
Member: 1123419 Status: Offline Thanks Meter: 4 | check image 15.20.04 : --------------- Read device information ----------------------- 15.20.06 : DEAD Mode Detected = True 15.20.07 : - No PACKAGE for Repair Found! 15.20.07 : ERROR Repair BOOTCORE! |
