10-01-2018, 13:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | E5573Cs-609 is it possible unlock ? Model : Huawei AuthVer 4 modem (New) IMEI : 868502035756960 Serial NR. : 5LL7S18822006076 Firmware : 21.329.63.00.284 Dashboard version : WEBUI_17.100.20.00.284_MRE5 Web UI version : WEBUI_17.100.20.00.284_MRE5 SIM Lock status : Locked (Card Lock) |
10-01-2018, 15:59 | #4 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
FREE SOLUTION AIRTEL E5573CS-609 21.329.63.00.284 LATEST VER https://drive.google.com/file/d/1No0...ew?usp=sharing | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
10-01-2018, 16:00 | #5 (permalink) | |
https://drive.google.com/file/d/1No0...ew?usp=sharing DETECT MODEM IN DC THEN GIVE AT^GODLOAD COMMND THEN RUN FILE AFTER FLASH DONE MODME WILL UNLOCK DONE | |
The Following 3 Users Say Thank You to balwinder27 For This Useful Post: |
10-01-2018, 16:13 | #6 (permalink) | ||
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
thanks a lot given solution has perfect my dongle unlocked done | ||
10-02-2018, 10:42 | #10 (permalink) | |
Junior Member Join Date: Dec 2017
Member: 2787805 Status: Offline Thanks Meter: 0 | Quote:
Found modem : E5573Cs-609 Model : Huawei AuthVer 4 modem (New) IMEI : 868502031046051 Serial NR. : 5LL7S18201004287 Firmware : 21.329.63.00.284 Dashboard version : WEBUI_17.100.15.01.284_MRE5 Web UI version : WEBUI_17.100.15.01.284_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 10 (unlock attempts left : 0) | |
10-02-2018, 10:50 | #11 (permalink) | |
Junior Member Join Date: Jul 2017 Age: 35
Member: 2741789 Status: Offline Thanks Meter: 4 | Quote:
https://drive.google.com/file/d/1Qb4...ew?usp=sharing please flash the file carefully | |
10-04-2018, 11:59 | #12 (permalink) | |
Member: 2787805 Status: Offline Thanks Meter: 0 | airtel 4g hotspot device is not working Quote: [QUOTE=mani_server;13346624]my airtel 4g hotspot device is not working but i saw in my device manger i saw one com port PC UI Interface only working beforei i flashing this same firmware version : 21.329.63.00.284 airtel e5573cs-609 my device is not working but i didn't see a both 2 light power buttom on please help me!!!! | |
10-04-2018, 14:07 | #13 (permalink) | |
Freak Poster Join Date: Feb 2015
Member: 2339305 Status: Offline Thanks Meter: 2 | Its working [QUOTE=jeethuvaz1781;13350124] Quote:
you flash wrong remove battety pres power button thrn connect usb then run file ok it will work | |
10-04-2018, 14:54 | #14 (permalink) |
Member: 2787805 Status: Offline Thanks Meter: 0 | my hotspot is not working [/QUOTE]i had already before i saw 2 com port application interface com port & PC UI Interface Port before i flashing a firmware direct i already flash that inside sim card jio sim but my hotspot router light on buttom i already remove battery and re-insert battery am trying switch the power that isn't working i already connect usb device on my hostpot router power light i didnt getting on power light but i saw one port working my windows 7 device manger port one working PC UI Interface i saw that one please help me!!![/QUOTE] |
