07-12-2017, 22:07 | #1 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2735212 Status: Offline Thanks Meter: 0 | Huawei E5172 BRICKED!! After trying to change the firmware from E5172, iīve bricked the router. In upgrade, the 4G strengh LEDS stopped in 4th. After reset, all LEDs come up. Tried press reset button + wps + wifi, nothing changes. After connecting the serial port and USB port directly in module, I have this logs: Booting without pressing space: Code: ▒ onchip NF_boot! UnSec_bo v?l?space?%s start addr:0x%x size:0x%x first step second step thred step DDR exam right !!!!!!!!!!!!!!!!!!!!!!! press space key to enter bootrom: Start from: vxWorks Kernel. >>loading: VxWorks ... >>loading: FastBoot ... FAIL!!. save boot ver err! hw main id:00000401, sub id:00000001Starting from entry: 0x30004000 Code: press space key to enter bootrom: IMAGE_BOOTROM load from:0x00340000>>loading: BootRom ... try inflate. image length: FFFFFFFF ram_inflate_addr: 34FE7959FAIL!!. ▒ onchip USB_boot! Thereīs a way to unbrick this router? Last edited by comdek; 07-12-2017 at 22:17. |
07-12-2017, 22:32 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
Br-balwinder27 Mkey-team | |
07-12-2017, 22:33 | #3 (permalink) |
Member: 2735212 Status: Offline Thanks Meter: 0 | When trying using WPS+Wifi+Reset button pressed. Code: ▒ onchip NF_boot! UnSec_bo v?l?space?write magic succsse!%x 24680138%s start addr:0x%x size:0x%x first step second step thred step DDR exam right !!!!!!!!!!!!!!!!!!!!!!! enter load backup IMAGE_BOOTROM load from:0x00340000>>loading: BootRom ... try inflate. image length: FFFFFFFF ram_inflate_addr: 34FE7959FAIL!!. ▒ onchip USB_boot! |
07-12-2017, 22:44 | #4 (permalink) | |
I asking you you have mkey dongle or not ?? Br-balwinder27 Mkey-team | |
07-13-2017, 05:34 | #5 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: Huawei Router/Modem Developer Age: 33
Member: 2562113 Status: Offline Sonork: alirazamanzoor Thanks Meter: 89 | Quote:
and write fw with mkey dongel simple.if you have any isshue then pm me. | |
07-14-2017, 13:46 | #6 (permalink) |
Member: 2735212 Status: Offline Thanks Meter: 0 | Hi all, I donīt have mkey dongle. I tried to use b953 usbloader and it boots, but presents some errors. Anyone have the E5172e usbloader bin? I have a good knowlegde in VxWorks RTOS. |
11-13-2017, 18:45 | #9 (permalink) | |
Solution only in mkey You using (balong flash exe free tools which not support e5172 flashing Mkey support all e5172 dead and flashing Your issue only resolve mkey only Br-balwinder27 Mkey-team | |
11-13-2017, 23:22 | #10 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Dear user, our solution work only with Mkey dongle, and if you dont have. Mkey , then you cant use our software. And all our files are compatible only for Mkey software ! |
The Following User Says Thank You to TestBox2 For This Useful Post: |
11-14-2017, 11:52 | #11 (permalink) | |
Member: 2562113 Status: Offline Sonork: alirazamanzoor Thanks Meter: 89 | dddddddd Quote:
11-20-2017, 23:35 | #12 (permalink) | |
Total 270usd Br-balwinder27 Mkey-team Last edited by balwinder27; 11-20-2017 at 23:44. | |
