02-18-2017, 09:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | huawei E5573s-320 problem battery and signal shows green stable lights no ip adress opening • RIM Virtual Serial Port v2 (COM14) • RIM Virtual Serial Port v2 (COM15) • HUAWEI Mobile Connect - 3G Application Interface (COM912) • HUAWEI Mobile Connect - 3G PC UI Interface (COM913) 13.51.12 : [Can't connect to server!] 13.51.12 : Software continued work in standalone mode . 13.53.07 : FhVers : E5573S-320 21.110.99.01.00 13.53.07 : IMEI : 860861030191633 13.53.08 : SwVers : 21.110.99.01.00 13.53.08 : IsoVers : WEBUI 13.53.08 : PrdName : E5573s-320 13.53.08 : DloadType : 0 13.53.09 : Auth.Vers: : 1 13.53.10 : New HiSi-TYPE 3 Identified. Sec. v4 13.53.10 : Security Status : UnLocked 13.53.11 : Security NV = [Open] 13.53.11 : ------------------- WiFi Router Settings ----------------------- 13.53.12 : WiFi SSID: "ZONG MBB-E5573-CA11" 13.53.13 : Web Site: "" 13.53.16 : --------------------------- E N D. -------------------------------- |
02-18-2017, 13:35 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
2 firmware use in this modem 1 use for unlock a modem 2nd for device turn on wifi webui etc | |
The Following 3 Users Say Thank You to balwinder27 For This Useful Post: |
02-18-2017, 16:30 | #3 (permalink) | |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
after flashing same ================================================== ========== 19.57.06 : DLOADVER : 2.0 19.57.06 : Model : ~žL~ 19.57.08 : IMEI : 123456789123456 19.57.08 : SwVers : 21.110.99.01.00 19.57.08 : IsoVers : WEBUI 19.57.08 : PrdName : BV7R11EU 19.57.08 : DloadType : 1 19.57.09 : Auth.Vers: : 1000 19.57.09 : New HiSi-TYPE 2 Identified. 19.57.12 : Open Flashing Protocol OK 19.57.34 : 19.57.45 : Verify download mode: 7200B--SKCBADZM 19.57.47 : Detected: [EHUAWEI BV7R11EU] 19.57.49 : HiSilicon CPU mode-3 Selected. 19.57.50 : Write Part1...[FastBoot] Ok 19.57.55 : Write Part2...[BOOT] Ok 19.58.00 : Write Part3...[PtableTail] Ok 19.58.06 : Write Part4...[Kernel] Ok 19.58.18 : Write Part5...[VxWorks] Ok 19.58.30 : Write Part6...[M3Image] Ok 19.58.35 : Write Part7...[DSP] Ok 19.58.43 : Write Part8...[NVTable Ok 19.58.50 : Write Part9...[System] Ok 19.59.19 : Write Part10...[CORE] Ok 20.00.28 : Restart modem OK 20.00.36 : All done ! 20.00.37 : - Flashing Completed! ================================================== ========== 20.04.27 : Model: E5573s-320 20.04.28 : Firmware: 21.110.99.01.00 20.04.28 : Sending Enable AutoRun... -ERROR!. ================================================== ========== • RIM Virtual Serial Port v2 (COM14) • RIM Virtual Serial Port v2 (COM15) • HUAWEI Mobile Connect - 3G Application Interface (COM969) • HUAWEI Mobile Connect - 3G PC UI Interface (COM970) 20.05.43 : Build: 20.05.43 : Init device...ERROR! ================================================== ========== 20.10.04 : DLOADVER : 2.0 20.10.05 : Model : E5573s-320 20.10.05 : FhVers : E5573S-320 21.110.99.01.00 20.10.06 : IMEI : 860861030191633 20.10.07 : SwVers : 21.110.99.01.00 20.10.07 : IsoVers : WEBUI 20.10.07 : PrdName : E5573s-320 20.10.07 : DloadType : 0 20.10.07 : Auth.Vers: : 1 20.10.08 : New HiSi-TYPE 3 Identified. Sec. v4 20.10.08 : Security Status : UnLocked 20.10.10 : Security NV = [Open] 20.10.10 : ------------------- WiFi Router Settings ----------------------- 20.10.10 : WiFi SSID: "ZONG MBB-E5573-CA11" 20.10.12 : Web Site: "" | |
02-19-2017, 06:21 | #5 (permalink) | |
already told you 2 firmwrae use in this mode 21.180.17.00.00 update this firmwrae on device | |
The Following 2 Users Say Thank You to balwinder27 For This Useful Post: |
02-19-2017, 11:23 | #6 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | i used this fw • RIM Virtual Serial Port v2 (COM14) • RIM Virtual Serial Port v2 (COM15) • HUAWEI Mobile Connect - 3G PC UI Interface (COM960) Load fw: E5573S_21.180.17.00.00_BL_FW.cbin 14.35.20 : --------------- Read device information ----------------------- 14.35.23 : DLOADVER : 2.0 14.35.23 : Model : ~žL~ 14.35.25 : IMEI : 123456789123456 14.35.25 : SwVers : 21.110.99.01.00 14.35.25 : IsoVers : WEBUI 14.35.25 : PrdName : BV7R11EU 14.35.25 : DloadType : 1 14.35.26 : Auth.Vers: : 1000 14.35.26 : New HiSi-TYPE 2 Identified. 14.35.29 : Open Flashing Protocol OK 14.35.51 : 14.35.59 : --------------- Flash-mode operations ------------------------ 14.36.02 : Verify download mode: 7200B--SKCBADZM 14.36.04 : Detected: [EHUAWEI BV7R11EU] 14.36.06 : HiSilicon CPU mode-3 Selected. 14.36.07 : Write Part1...[FastBoot] Ok 14.36.11 : Write Part2...[BOOT] Ok 14.36.17 : Write Part3...[PtableTail] Ok 14.36.22 : Write Part4...[Kernel] Ok 14.36.34 : Write Part5...[VxWorks] Ok 14.36.45 : Write Part6...[M3Image] Ok 14.36.51 : Write Part7...[DSP] Ok 14.36.58 : Write Part8...[NVTable Ok 14.37.05 : Write Part9...[System] Ok 14.37.34 : Write Part10...[CORE] Ok 14.38.44 : Restart modem OK 14.38.53 : All done ! 14.38.54 : - Flashing Completed! 14.38.55 : --------------------------- E N D. -------------------------------- i flashed fw as u said device connected ok but after 1 minut it auto disconnected Disconnected |
02-19-2017, 12:58 | #7 (permalink) | |
click connect button then internet work | |
