12-16-2018, 17:42 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: GSM-Forum
Member: 2574306 Status: Offline Thanks Meter: 343 | E5372Ts-601 Unlock Firmware Need Found modem : E5372T Model : Huawei E5372 / MegaFon MR100-3 IMEI : 862554024048012 Serial NR. : P9HBY15316002898 Firmware : 21.270.05.00.76 Compile date / time : Feb 19 2014 15:08:56 Hardware ver. : CL1E5372TSM02 Dashboard version : WEBUI_13.100.10.00.76_E5_V7R1_V3R2 SIM Lock status : Locked (Card Lock) Wrong codes entered : 10 (unlock attempts left : 0) |
The Following User Says Thank You to K-B MOBILE For This Useful Post: |
12-16-2018, 23:03 | #2 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Hi, you can try this fw: E5372TS-601_21.270.09.00.00_FW |
The Following User Says Thank You to TestBox2 For This Useful Post: |
12-17-2018, 05:30 | #3 (permalink) | |
Freak Poster Join Date: Oct 2018 Location: GSMHOSTING
Member: 2869280 Status: Offline Thanks Meter: 112 | Quote:
12-17-2018, 07:50 | #5 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Egypt-Saudi Arabia
Member: 237354 Status: Offline Sonork: 100.1680909 Thanks Meter: 19 | I have 3 devices already unlocked but I will test the FW for TestBox2 If you do not have MKey and your device is locked on STC Saudi Arabia I can help with free solution |
12-18-2018, 11:08 | #8 (permalink) |
Member: 237354 Status: Offline Sonork: 100.1680909 Thanks Meter: 19 | Hi please follow the below to unlock 1 download huawei_flasher_1.6 from here download web UI from here download FW from here 2 turn off the device & press menu(first) + power bottom(second) at the same time to be like this install the web UI after finish turn off the device & press menu(first) + power bottom(second) again then check the ports and open ports.ini in the Huawei Flasher and flash the FW with it 3 open the web UI 192.168.1.1 you will find that the device requet the unlock code you can get it free from any site or tool |
The Following User Says Thank You to ahmed_vip For This Useful Post: |
07-02-2019, 01:28 | #11 (permalink) |
Junior Member Join Date: Mar 2009
Member: 987418 Status: Offline Thanks Meter: 2 | Salam to all, I'm facing the error "Error Code:17, The wireless terminal inserted is not E5372, Update Wizard can't continue" during unlock my Huawei E5372. Found modem : E5372T Model : Huawei E5372 / MegaFon MR100-3 IMEI : 862554023739611 Serial NR. : P9HBY15305002658 Firmware : 21.270.05.00.76 Compile date / time : Feb 19 2014 15:08:56 Hardware ver. : CL1E5372TSM02 Dashboard version : WEBUI_17.100.05.00.838 SIM Lock status : Locked (Card lock) Wrong codes entered : 10 (unlock attempts left : 0) |
