Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > 7ICE Team > Mkey - Modem Unlock Key
Old 04-23-2018, 12:03   #16 (permalink)
balwinder27's Avatar
Member: 2634133
Thanks Meter: 2,851
Originally Posted by scorpian1982 View Post
one more question sir, is that work on all old versions or just on same version????????????
work on these versions only
br-balwinder27
mkey-devolper
The Following User Says Thank You to balwinder27 For This Useful Post:
Old 04-23-2018, 13:13   #17 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 406
br-balwinder27
mkey-devolper
Here Is Error Sir
Need Help Plz
16.55.16 : DLOADVER 	: 2.0
 16.55.16 : Model    	: E8372
 16.55.18 : IMEI      	: 8664570234XXXXX
 16.55.18 : SwVers  	: 21.321.01.00.306
 16.55.18 : IsoVers  	: WEBUI
 16.55.18 : PrdName 	: E8372
 16.55.18 : DloadType 	: 0
 16.55.19 : Auth.Vers: 	: 2
 16.55.19 : New HiSi-TYPE 2 Identified.
 16.55.23 : Open Flashing Protocol OK..
 16.55.45 :
 16.55.52 : SignAuth = Done
 16.55.56 : Verify download mode: 7200B--SKCBADZM
 16.55.57 : Detected: [EHUAWEI BV7R11W__4]
 16.56.01 : HiSilicon CPU mode-3 Selected.
 16.56.01 : Write Part1...[FastBoot] Ok
 16.56.05 : Write Part2...[BOOT] Ok
 16.56.09 : Write Part3...[PtableTail] Ok
 16.56.12 : Write Part4...[Kernel] Ok
 16.56.20 : Write Part5...[VxWorks]
 16.56.23 : Init device...ERROR!
Old 04-23-2018, 13:36   #18 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 406
Originally Posted by shoaibrao View Post
Here Is Error Sir
Need Help Plz
 16.55.45 :
And Sir Plz Also Add
Original IMEI Restore Solution
17.26.11 : DLOADVER 	: 2.0
 17.26.12 : Model    	: E8372
 17.26.13 : IMEI      	: 3566480126XXXXX
 17.26.13 : SwVers  	: 21.318.01.01.306
 17.26.13 : IsoVers  	: WEBUI
 17.26.13 : PrdName 	: E8372
 17.26.13 : DloadType 	: 0
 17.26.14 : Auth.Vers: 	: 2
 17.26.14 : New HiSi-TYPE 2 Identified.
 17.26.16 : Security NV = [Closed]
 17.26.27 : This modem not supported R/W- SEC.
But With
Mkey_v8.3.6_Build_31.DEC.2016
I Can Restore Original IMEI
 16.09.09 : DLOADVER 	: 2.0
 16.09.10 : Model    	: E5573Cs-322
 16.09.10 : FhVers    	: E5573Cs-322 21.318.03.00.00
 16.09.11 : IMEI      	: 000000000000000
 16.09.11 : SwVers  	: 21.318.03.01.306
 16.09.11 : IsoVers  	: WEBUI
 16.09.11 : PrdName 	: E5573Cs-322
 16.09.11 : DloadType 	: 0
 16.09.12 : Auth.Vers: 	: 2
 16.09.13 : New HiSi-TYPE 3 Identified. Sec. v4
 16.09.14 : Security NV = [Closed]
 16.09.15 : Repair IMEI: 8617910340XXXXX - Done.
But Now I Cant Use Old Version Like
ETC
Old 04-23-2018, 15:16   #19 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 7,291
Patched fw used for same, current fw version.
Old 04-23-2018, 15:58   #20 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 406
 16.53.04 : DLOADVER 	: 2.0
 16.53.05 : Model    	: E8372
 16.53.06 : IMEI      	: 8664570234XXXXX
 16.53.07 : SwVers  	: 21.321.01.00.306
 16.53.07 : IsoVers  	: WEBUI
 16.53.07 : PrdName 	: E8372
 16.53.07 : DloadType 	: 0
 16.53.08 : Auth.Vers: 	: 2
 16.53.08 : New HiSi-TYPE 2 Identified.
 16.53.09 : Security NV = [Closed]
 16.53.10 : ------------------- WiFi Router Settings -----------------------
 16.53.10 : WiFi SSID: 	"ZONG MBB-E8372-D374"
 16.53.11 : WiFi key: 	"LTE",62,55,181,24
 16.53.11 : Web Site: 	""
 16.55.45 :
Old 04-23-2018, 16:42   #21 (permalink)
Member: 2634133
Thanks Meter: 2,851
Here Is Error Sir
Need Help Plz
 16.55.45 :
please try this firmware
https://www.sendspace.com/file/0sgbc5
br-balwinder27
mkey-devolper
Old 04-24-2018, 14:55   #22 (permalink)
Member: 86994
Sonork: 100.1584487
Thanks Meter: 124
Still having error, any solution plzzzz
18.36.31 : --------------- Read device information -----------------------
18.36.36 : DLOADVER : 2.0
18.36.37 : Model : ~žL~
18.36.38 : IMEI : 123456789123456
18.36.38 : SwVers : 21.318.01.01.306
18.36.38 : IsoVers : WEBUI
18.36.38 : PrdName : BV7R11W__4
18.36.38 : DloadType : 1
18.36.39 : Auth.Vers: : 1000
18.36.39 : New HiSi-TYPE 2 Identified.
18.36.43 : Open Flashing Protocol OK..
18.37.05 :
18.37.12 : SignAuth = Done
18.37.13 : --------------- Flash-mode operations ------------------------
18.37.15 : Verify download mode: 7200B--SKCBADZM
18.37.17 : Detected: [EHUAWEI BV7R11W__4]
18.37.20 : HiSilicon CPU mode-3 Selected.
18.37.21 : Write Part1...[FastBoot] Ok
18.37.24 : Write Part2...[BOOT] Ok
18.37.28 : Write Part3...[PtableTail] Ok
18.37.31 : Write Part4...[Kernel] Ok
18.37.40 : Write Part5...[VxWorks]
18.37.42 : Init device...ERROR!
Old 04-24-2018, 15:53   #23 (permalink)
Member: 2634133
Thanks Meter: 2,851
18.36.37 : Model : ~ěL~
18.37.05 :
please wait problem in mkey softwrae for write firmware
testbox work for fix this issue
br-balwinder27
mkey-devolper
Old 04-24-2018, 15:55   #24 (permalink)
Member: 2634133
Thanks Meter: 2,851
18.37.05 :
br-balwinder27
mkey-devolper
Old 04-24-2018, 16:08   #25 (permalink)
Member: 86994
Sonork: 100.1584487
Thanks Meter: 124
br-balwinder27
mkey-devolper
tried the same firmware which y0u have shared
Old 04-25-2018, 06:24   #26 (permalink)
Member: 2503560
Sonork: sawood_10
Thanks Meter: 2
successful unlock done zong e8372h
Old 04-27-2018, 20:16   #27 (permalink)
Member: 2832692
Sir link firmware .................................................. .................................................. .................................................. .................................................. .......................
Old 04-27-2018, 20:30   #28 (permalink)
Member: 2832692
zong e5573s-320 direct unlock without unscew
zong e5573cs-322 direct unlock without unscrew
zong e8372h-153 direct unlock without unscew
telenor e8372h-608 direct unlock without unscrw
telenor e5573cs-609 direct unlock without unscrw
Link Send me sir these all firmware.
Old 04-28-2018, 04:45   #29 (permalink)
Member: 2634133
Thanks Meter: 2,851
https://www.sendspace.com/file/gvloov
link
Old 05-03-2018, 07:37   #30 (permalink)
Member: 307225
Thanks Meter: 43
This Device Possible For Unlock ?
Device name:	E5577s-321
IMEI:	860782031XXXXXX
IMSI :	Unknown
My number:	Unknown
Hardware version:	CL1E5573SM02
Software version:	21.200.07.02.1367
Web UI version:	17.100.11.03.1367
LAN MAC address:	F8:23:B2:03:95:2E
WAN IP Address:	Unknown
Page generated in 0.42226 seconds with 7 queries
