Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > 7ICE Team > Mkey - Modem Unlock Key
Old 11-02-2018, 17:51   #166 (permalink)
huaweitrick02's Avatar
Member: 2313239
Thanks Meter: 20
zte 920 v copy files from backup folder
Sent from my S9 plus
Old 03-14-2019, 04:17   #167 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
ZTE MF923 Can be Unlock/ Flash/ Imei repair and repar DEAD without JTAG NOw!Full Support is available.
05.06.09 : --------------- Read device information -----------------------
05.06.19 : Model: PVMF923Q
05.06.19 : IMEI: 869142-02-004756-9
05.06.19 : Version ID: PV_ATT_MF923V1.0.0B14
05.06.19 : Software ID: PV_ATT_MF923V1.0.0B12
05.06.19 : Firmware ID: MPSS.DI.2.0.C3-00101-M9625LAAAANAZM-1
05.06.19 : Build: JUN 30 201514:50:27JUN 30 201514:50:27*
05.06.19 : --------------- Flash-mode operations ------------------------
05.08.00 : Auth. DL..Ok
05.08.42 : Sending BootLoader.. Nprg mode OK
05.08.59 : Execute APP Loader... Ok
05.09.02 : Flash info: FM6BD4G2A
05.09.20 : Pbl:=False; Selected Normal mode.
05.09.32 : Write Part: Partition.. Ok
05.09.58 : Write Part: SBL.. Ok
05.10.25 : Write Part: SDI.. Ok
05.10.56 : Write Part: TZ.. Ok
05.11.21 : Write Part: RPM.. Ok
05.11.57 : Write Part: MBA.. Ok
05.12.22 : Write Part: QDSP.. Ok
05.13.26 : Write Part: ADSP.. Ok
05.14.54 : Write Part: APPSBL.. Ok
05.15.20 : Write Part: SYSTEM.. Ok
05.16.30 : Write Part: USERDATA.. Ok
05.18.21 : Write Part: ZTEDATA.. Ok
05.18.58 : Write Part: EFS2.. Ok
05.19.22 : Write Part: RECOVERY.. Ok
05.19.51 : Write Part: RECOVERYFS.. Ok
05.21.05 : Write Part: APPS.. Ok
05.23.09 : BetaFlasher - Working completed.
05.23.09 : - Flashing Completed!
Old 03-22-2019, 02:36   #168 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
SAMSUNG lc11 Dead mode repair withoit JTAG now is possible!
1. Use Boot-Point for swith LC11 in to 9008 port mode, akacaled qcom PBL repair mode.
2. Use writing fw 'LC11_9008_Mode_Repair_Dead-ONLY_[LC11.0.3.EC04].cbin' via Mkey software and ZTE-mode,
3. Run modem, make reset and go to local http://192.168.1.1/selectusbmode.html for enable comports.
4. Write NVM file if need repair calldate& network. LC11_VZ_[LC11.0.3.EC04].NVM
02.59.20 : Phone stay in Download MODE!
02.59.25 : Detected: PBL_DownloaderVER1
02.59.29 : Resp: 08-06-01-0100-90-00-00 | 0x0001
02.59.29 : Upload APP Loader... 0x40012000 OK
02.59.57 : Execute APP Loader... Ok
03.00.16 : Flash info: NAND01GR3B2CZA6 d
03.00.23 : Write Part0...[PARTITION] . Ok
03.00.29 : Write Part1...[DBL] Ok
03.00.39 : Write Part2...[FSBL] Ok
03.00.47 : Write Part3...[OSBL] Ok
03.00.59 : Write Part4...[AMSS] Ok
03.01.20 : Write Part5...[DSP1] Ok
03.01.44 : Write Part6...[DSP2] Ok
03.09.22 : SelfTest ... Filed
03.10.04 : - Flashing Completed!
The Following User Says Thank You to TestBox2 For This Useful Post:
Old 07-27-2019, 04:35   #169 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
Some info about E5836 Telcel
Use Setting Huawei_MDM - and Application Interface for Unlock.
Admin password: Telcel
03.01.47 : --------------- Read device information -----------------------
03.01.51 : Model: SNCAALZM
03.01.51 : IMEI: 35621 00300325 7-2
03.01.51 : Firmware ID: 7625A-SNCAALZM-13551150
03.01.51 : SW Version: 696.11.129.01.109
03.01.51 : PCB Version: WLC3GCPU
03.01.51 : Build: NOV 16 200916:05:33JUN 12 200905:00:00
03.01.52 : --------------- Begin analyse firmware ------------------------
03.01.52 : Unlocking device... OK
03.01.54 : Operation completed...OK
03.01.55 : --------------------------- E N D. --------------------------------
Old 07-29-2019, 19:51   #170 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
From now 2D NAND FLASH IC Supported on Mkey software for Normality Flashing and repair Half-Dead modems without JTAG!
Cmotech + Franklin models U250/U300/U301/U600/U602
21.25.42 : --------------- Read device information -----------------------
21.25.43 : Establish communication in repair mode...OK
21.25.43 : --------------- Flash-mode operations ------------------------
21.25.44 : Verify download mode: Q6085-OEMSBL-U600-10
21.25.44 : Upload APP Loader... OK
21.25.55 : Execute APP Loader... Ok
21.26.12 : Flash info: samsung_k521f12acbd
21.26.14 : Smart SBL mode Selected.
21.26.14 : Write Part0...[PARTITION] . Ok
21.26.19 : Write Part1...[QCSBLHD_CFGDATA] Ok
21.26.25 : Write Part2...[QCSBL] Ok
21.26.31 : Write Part3...[OEMSBLHD] . Ok
21.26.33 : Write Part4...[OEMSBL] Ok
21.26.39 : Write Part5...[AMSSHD] . Ok
21.26.41 : Write Part6...[AMSS] Ok
21.29.33 : - Flashing Completed!
21.29.35 : --------------------------- E N D. --------------------------------
Old 12-17-2019, 16:26   #171 (permalink)
Member: 196365
Thanks Meter: 35
E5577Cs-603_21.200.07.00.00_FW - I can confirm that this file works fine, thank You.
I have software damaged device.
 13.34.53 : --------------- Read device information -----------------------
 13.34.56 : DLOADVER 	: 2.0
 13.34.57 : Model    	: E5577Cs-603
 13.34.59 : IMEI      	: 86...
 13.34.59 : SwVers  	: 21.200.07.06.1151
 13.34.59 : IsoVers  	: WEBUI
 13.34.59 : PrdName 	: E5577Cs-603
 13.34.59 : DloadType 	: 0
 13.35.00 : Auth.Vers: 	: 2
 13.35.00 : New HiSi-TYPE 2 Identified.
 13.35.02 : Security NV = [Closed]
 13.35.03 : ------------------- WiFi Router Settings -----------------------
 13.35.03 : WiFi SSID: 	"BOLT!Super4G..."
 13.35.05 : Web Site: 	""
 13.35.08 : --------------------------- E N D. --------------------------------
Device turns ON, unlocked already, but sim not recognised, can't log in to 192.168.1.1 or 192.168.8.1, just blank page while loading. I understand that someone damaged it by unlock attempt with 3rd party unreliable solutions.
File: E5577Cs-603_21.200.07.00.00_FW repaired all problems straight away.
 13.35.25 : --------------- Read device information -----------------------
 13.35.28 : Set SFMmode .. Ok
 13.35.30 : DLOADVER 	: 2.0
 13.35.31 : Model    	: E5577Cs-603
 13.35.33 : IMEI      	: 86...
 13.35.33 : SwVers  	: 21.200.07.06.1151
 13.35.33 : IsoVers  	: WEBUI
 13.35.33 : PrdName 	: E5577Cs-603
 13.35.33 : DloadType 	: 0
 13.35.34 : Auth.Vers: 	: 2
 13.35.34 : New HiSi-TYPE 2 Identified.
 13.35.39 : Open Flashing Protocol OK..
 13.36.01 :
 13.36.44 : --------------- Flash-mode operations ------------------------
 13.36.59 : Verify download mode: 7200B--SKCBADZM
 13.37.19 : Detected: [EHUAWEI BV7R11EC4]
 13.37.32 : HiSilicon CPU mode-3 Selected.
 13.37.43 : Write Part1...[FastBoot] Ok
 13.38.18 : Write Part2...[BOOT] Ok
 13.39.04 : Write Part3...[PtableTail] Ok
 13.39.46 : Write Part4...[Kernel] Ok
 13.40.47 : Write Part5...[VxWorks] Ok
 13.41.51 : Write Part6...[M3Image] Ok
 13.42.32 : Write Part7...[DSP] Ok
 13.43.32 : Write Part8...[NVTable] Ok
 13.44.20 : Write Part9...[System] Ok
 13.45.52 : Write Part10...[CORE] Ok
 13.46.32 : Write Part11...[IsoHDR] Ok
 13.47.05 : Write Part12...[CDROMISO] Ok
 13.48.31 : Write Part13...[WEBUI] Ok
 13.52.42 : Restart modem OK
 13.52.51 : All done !
 13.52.52 :  - Flashing Completed!
 13.52.54 : --------------------------- E N D. --------------------------------
so I get now fully working device:
 13.55.09 : --------------- Read device information -----------------------
 13.55.13 : DLOADVER 	: 2.0
 13.55.14 : Model    	: E5577Cs-603
 13.55.15 : IMEI      	: 86...
 13.55.15 : SwVers  	: 21.200.07.00.00
 13.55.15 : IsoVers  	: WEBUI
 13.55.15 : PrdName 	: E5577Cs-603
 13.55.15 : DloadType 	: 0
 13.55.16 : Auth.Vers: 	: 2
 13.55.16 : New HiSi-TYPE 2 Identified.
 13.55.18 : Security NV = [Closed]
 13.55.19 : ------------------- WiFi Router Settings -----------------------
 13.55.19 : WiFi SSID: 	"BOLT!Super4G..."
 13.55.20 : Web Site: 	""
 13.55.24 : --------------------------- E N D. --------------------------------
This file won't help to unlock but it will repair any software problems if device is still booting up.
 13.55.47 : --------------- Read device information -----------------------
 13.55.50 : DLOADVER 	: 2.0
 13.55.51 : Model    	: E5577Cs-603
 13.55.52 : IMEI      	: 86...
 13.55.53 : SwVers  	: 21.200.07.00.00
 13.55.53 : IsoVers  	: WEBUI
 13.55.53 : PrdName 	: E5577Cs-603
 13.55.53 : DloadType 	: 0
 13.55.54 : Auth.Vers: 	: 2
 13.55.54 : New HiSi-TYPE 2 Identified.
 13.56.10 : Security Status :2
 13.56.11 :  - Unlocking modem... Failed
 13.56.15 : --------------------------- E N D. --------------------------------
Thank You MKEY Team for providing this file.
The Following User Says Thank You to mahcin For This Useful Post:
Old 12-21-2019, 07:30   #172 (permalink)
binshad's Avatar
Member: 1297123
Sonork: 100.1609506
Thanks Meter: 11
Airtel e5573c unlocked successfully with mkey
11.38.38 : --------------- Read device information -----------------------
11.38.41 : Set SFMmode .. Ok
11.38.43 : DLOADVER : 2.0
11.38.44 : Model : E5573CS-609
11.38.44 : FhVers : E5573CS-609 21.318.99.03.00
11.38.45 : IMEI : 861350037216485
11.38.45 : SwVers : 21.318.99.03.00
11.38.45 : IsoVers : WEBUI
11.38.45 : PrdName : E5573CS-609
11.38.45 : DloadType : 0
11.38.46 : Auth.Vers: : 2
11.38.47 : New HiSi-TYPE 3 Identified. Sec. v4
11.38.51 : Open Flashing Protocol OK..
11.39.13 :
11.39.26 : --------------- Flash-mode operations ------------------------
11.39.30 : Verify download mode: 7200B--SKCBADZM
11.39.34 : Detected: [EHUAWEI BV7R11EU8]
11.39.39 : HiSilicon CPU mode-3 Selected.
11.39.41 : Write Part1...[FastBoot] Ok
11.39.49 : Write Part2...[BOOT] Ok
11.39.58 : Write Part3...[PtableTail] Ok
11.40.08 : Write Part4...[Kernel] Ok
11.40.22 : Write Part5...[VxWorks] Ok
11.40.36 : Write Part6...[M3Image] Ok
11.40.47 : Write Part7...[DSP] Ok
11.41.00 : Write Part8...[NVTable Ok
11.41.11 : Write Part9...[System] Ok
11.41.35 : Write Part10...[Kernel] Ok
11.41.53 : Write Part11...[CORE] Ok
11.43.34 : Restart modem OK
11.43.42 : All done !
11.43.44 : - Flashing Completed!
11.43.45 : --------------------------- E N D. --------------------------------
Old 01-02-2020, 00:10   #173 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
ZTE MF927U UNLOCK MTN Nigeria
02.03.31 : --------------- Read device information -----------------------
02.03.33 : Firmware :BD_MTNZAMF927U4V1.0.1B01
02.03.35 : Version : BD_MTNZAMF927UV1.0.0B02
02.03.35 : Found :7520V1.0.0B09P25_L01-V3
02.03.36 : MDM Vers : BD_MTNZAMF927UV1.0.0B02
02.03.36 : Firmware :BD_MTNZAMF927U4V1.0.1B01
02.03.37 : Dashboard :BD_MTNZAMF927UV1.0.0B02
02.03.38 : WiFi Key :+CME ERROR: 8012
02.03.39 : Device IMEI :867738030798935
02.03.39 : MAC S/N : 601466A19109
02.03.40 : Board ID : 722784305612
02.03.40 : Nck attempts : 5
02.03.41 : Locklevel: : Locked
02.03.41 : Battery Level :100%
02.03.50 : Unlocking... Ok
02.04.12 : --------------------------- E N D. --------------------------------
AFTER UNLOCK LOG
02.08.34 : --------------- Read device information -----------------------
02.08.35 : MDM: 7520V1.0.0B09P25_L01-V3
02.08.35 : Version: +CGMR: BD_MTNZAMF927UV1.0.0B02
02.08.36 : Firmware: BD_MTNZAMF927U4V1.0.1B01
02.08.36 : Dashboard: BD_MTNZAMF927UV1.0.0B02
02.08.38 : WiFi Key :+CME ERROR: 8012
02.08.38 : Device IMEI :867738030798935
02.08.39 : MAC S/N : 601466A19109
02.08.39 : Board ID : 722784305612
02.08.40 : Locklevel: : Never Locked
02.08.40 : Battery Level :100%
02.08.44 : --------------------------- E N D. --------------------------------
Old 01-02-2020, 23:09   #174 (permalink)
Crazy Poster
Member: 587029
Thanks Meter: 8
Mf927u unlocked
19.18.18 : MDM: 7520V1.0.0B09P25-V3
19.18.18 : Version: +CGMR: BD_MTNNGMF927UV1.0.0B03
19.18.19 : Firmware: BD_MTNNGMF927U4V1.0.0B03
19.18.19 : Dashboard: BD_MTNNGMF927UV1.0.0B03
19.18.21 : WiFi Key :+CME ERROR: 8012
19.18.22 : Device IMEI :867738030801499
19.18.22 : MAC S/N : 601466A19209
19.18.23 : Board ID : 722784302148
19.18.23 : Nck attempts : 5
19.18.23 : Locklevel: : Locked
19.18.24 : Battery Level :58%
19.20.02 : Firmware :BD_MTNNGMF927U4V1.0.0B03
19.20.05 : Version : BD_MTNNGMF927UV1.0.0B03
19.20.05 : Found :7520V1.0.0B09P25-V3
19.20.06 : MDM Vers : BD_MTNNGMF927UV1.0.0B03
19.20.06 : Firmware :BD_MTNNGMF927U4V1.0.0B03
19.20.07 : Dashboard :BD_MTNNGMF927UV1.0.0B03
19.20.08 : WiFi Key :+CME ERROR: 8012
19.20.09 : Device IMEI :867738030801499
19.20.09 : MAC S/N : 601466A19209
19.20.10 : Board ID : 722784302148
19.20.10 : Nck attempts : 5
19.20.10 : Locklevel: : Locked
19.20.11 : Battery Level :61%
19.20.20 : Unlocking... Ok
Old 04-25-2020, 22:23   #175 (permalink)
Member: 196365
Thanks Meter: 35
Option iCON431:
Unlock = successful
Flash = failed
Unlock:
06.29.32 : --------------- Read device information -----------------------
06.29.34 : Model: SLCAAVZM
06.29.34 : IMEI: 002661-63-74xxxx-x
06.29.34 : Firmware ID: 1.4.7.0HD
06.29.34 : Build: OCT 15 200815:29:15APR 29 200812:00:00
06.29.34 : --------------- Flash-mode operations ------------------------
06.29.34 : Unlocking device... OK.
06.29.39 : --------------------------- E N D. --------------------------------
it read wrong IMEI number, but unlock OK
Device upgraded via operators upgrade, then tried flash here for my own knowledge.
Flash:
13.02.53 : --------------- Read device information -----------------------
13.02.55 : Model: SLCTAVZM
13.02.55 : IMEI: 002661-63-747024-6
13.02.55 : Firmware ID: 2.12.0.0HD
13.02.55 : Build: OCT 29 200910:02:08OCT 03 200900:00:00
13.03.15 : --------------- Flash-mode operations ------------------------
13.03.15 : Verify download mode: 76XXM-3530-SLCTAVZM
13.03.15 : Boot version: GI0431-11403 2.12.0.0HD
13.03.15 : Upload APP Loader... OK
13.03.17 : Execute APP Loader... Ok
13.03.35 : Can't Get - download protocol targ!
Device is still fully working, just wanted flash it for own knowledge.
File used: Option_Icon_431-461_GI04X1_128MB
Thank You for unlock possibility, I'm very happy :-)
Old 05-15-2020, 01:24   #176 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
MF927U Jazz Unlock Done!
Old 06-14-2020, 17:35   #177 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
ZTE MF253S Flashing / Downgrade / IMEI Repair - Done!
16.43.40 : --------------- Read device information -----------------------
16.43.43 : Version :MF253S_VOIP_SLTV1.0.0B03
16.43.43 : Found : 7510MV2.5.0B04P06
16.43.44 : Firmware : MF253S_VOIP_SLTV1.0.0B03
16.43.44 : Dashboard :
16.43.45 : WiFi CCID :
16.43.46 : WiFi Key :
16.43.46 : Device IMEI : 8687840........
16.43.46 : Battery Level : 0%
16.43.48 : Boot-Interface : Found!
16.44.01 : Write Part1...[uBoot] Ok
16.44.04 : Write Part2...[zLoader] Ok
16.44.08 : Write Part3...[proc-lp] Ok
16.44.11 : Write Part4...[proc-ps] Ok
16.44.18 : Write Part5...[proc-phy] Ok
16.44.23 : Write Part6...[proc-zsp] Ok
16.44.26 : Write Part7...[proc-app] Ok
16.44.31 : Write Part8...[userdata] Ok
16.44.39 : Write Part9...[fota-update] Ok
16.44.43 : Write Part10...[recovery] Ok
16.44.47 : Write Part11...[proc-lp] Ok Ok
16.46.02 : All Done!.
16.46.04 : --------------------------- E N D. --------------------------------
Old 10-31-2020, 21:31   #178 (permalink)
Member: 1412506
Thanks Meter: 3
ZTE MF927U MTN Zambia Unlocked
12.55.47 : Version : BD_MF927UV1.0.0B01
12.55.48 : Found : 7520V1.0.0B09P25_L01-V3
12.55.48 : MDM Vers : BD_MF927UV1.0.0B01
12.55.48 : Firmware :BD_MTNZMMF927U4TLV1.0.0B01
12.55.49 : Dashboard : BD_MF927UV1.0.0B01
12.55.50 : WiFi Key : +CME ERROR: 8012
12.55.51 : Device IMEI : 867738031122010
12.55.51 : MAC S/N : 601466C98D4B
12.55.52 : Board ID : 723834807527
12.55.52 : Nck attempts : 5
12.55.53 : Locklevel: : Locked
12.55.53 : Battery Level : 77%
12.56.01 : Unlocking... Ok
12.56.22 : --------------------------- E N D. --------------------------------
Old 05-22-2021, 22:40   #179 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
MF283U World First Unlock!
19.04.26 : Version : BD_MTNZMMF283UV1.0.0B01
19.04.27 : Found : 7520V1.0.0B09P30_U04-V3
19.04.27 : MDM Vers : BD_MTNZMMF283UV1.0.0B01
19.04.28 : Firmware :BD_MTNZMMF283UV1.0.0B01
19.04.28 : Dashboard : BD_MTNZMMF283UV1.0.0B01
19.04.30 : WiFi Key : +CME ERROR: 8012
19.04.30 : Device IMEI : 86809804*****
19.04.30 : MAC S/N : B41C30ADAF6D
19.04.31 : Board ID : 728968503374
19.04.31 : Nck attempts : 5
19.04.32 : Locklevel: : Locked
19.04.40 : Unlocking... Ok
Old 05-28-2021, 14:34   #180 (permalink)
Member: 1412506
Thanks Meter: 3
15.31.04 : --------------- Read device information -----------------------
15.31.08 : Version : BD_MTNZMMF283UV1.0.0B03
15.31.09 : Found : 7520V3V1.01.01.09P35U14
15.31.09 : MDM Vers : BD_MTNZMMF283UV1.0.0B03
15.31.09 : Firmware :BD_MTNZMMF283UV1.0.0B04
15.31.10 : Dashboard : BD_MTNZMMF283UV1.0.0B03
15.31.11 : WiFi Key : +CME ERROR: 8012
15.31.12 : Device IMEI : 868098041714788
15.31.12 : MAC S/N : B41C30FC40CA
15.31.13 : Board ID : 731710505371
15.31.13 : Nck attempts : 5
15.31.13 : Locklevel: : Locked
15.31.23 : Unlocking... Ok
15.31.40 : --------------------------- E N D. --------------------------------
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.27675 seconds with 10 queries
