Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Mkey - Modem Unlock Key
Old 08-17-2011, 08:03   #1 (permalink)
Member: 1302128
Arrow Tutorial Mkey
need All tutorial from mkey
Old 08-17-2011, 11:31   #2 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Hi by All.
Before use MKEY Software need understand some small info:
1. You need first select neded brand like :
Aiko - for Aiko modems
Alcatel_MDM - for Alcatel modems
Huawei_E2XX - Older huawei modems only E219 E220
Huawei_MDM - New huawei modems from E160 to ... 2012 year models.
Huawei_ROUTER - E5830 and similar
Icon_2XX - Icon 2XX series modem
Micromax - Micromax modem
Mywave - Mywave modem
Novatel - Old novatel modems
Onda - Onda modems
Option - Option aka GT modems
Pantech - Pantech modems
Sierra - OLD Sierra modems like U881 and similar
Toshiba - Toshiba modems (logger)
ZTE - ZTE modems in Qualcomm CPU
ZTE_Icera - ZTE modems in ICERA CPU like MF190B MF190J MF192 MF591 MF652 MF691 .....
CDMA_SPC - CDMA MODEMS COCTAIL (Press CUSOMIZED BUTTON for opening extended menu)
2. After select brand, you need select comport (This need because each time when you select brand - comport list are renew)
3. When you complett two previouse setings, you can press read info button for see about comports are reply on software request and connection fine.
4. Do Job what you wish.
-------------------------- SMARTFLASHER SETTINGS ------------------------------------
IMPORTANT! IN COMPUTER MUST BE INSERTED ONLY 1 MODEM WHEN USED REFLASH or ICERA CPU Modems UNLOCKING!
BECAUSE COMPORTS NUMBERS ARE CHANGED IN PROCESS! And Mkey software find comports by name mask!!!
ALSO INTERNET MUST BE FROM WiFi or ADSL !!! REQUARED FOR Server options!!!!!!!!
All first 3 steps are same. but next you own click button customize for opening extended menu,
next loading flash file by double click on green text, and do flashig.
On ZTE modems request 2 mode :
MSM mode : for all zte exept MF150 and MF170.
QSC mode : for QSC CPU series modems, this is two only MF150 and MF170.
Rebuild EFS : - This option used for fully repair modems with renew All, better set to enabled if not know compatible firmware or not.
If after flashing zte modem lose imei , then repair imei , write nvm /backup/backup.nvm , or download from support, and reflash now with enabled Rebuild EFS.
Here You can use video-manuals and seen how the working
Index of /video
To be continue ...
The Following 3 Users Say Thank You to TestBox2 For This Useful Post:
Old 09-12-2011, 20:36   #3 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Personaly for lazy users how to calculate Alcatel modems unlock code by 4 step
Tutorial for Unlock Alcatel modems with disabled insert NCK in dashboard .
This small programm we resent as is;
And you can do unlock your alcatel modem if you know valid NCK code.
Instructon:
1. Connect modem to pc with not accepted simcard.
2. Wait until loading modem dashboard and after close modem manager software.
3. Select Modem comport in aplication.
4. Insert your NCK code [replace defoult nck 01234567890 with your valid code].
5. Press Do Job button.
How to get NCK Unlock code:
1. Run Mkey - Modem Unlock Key software and select Alcatel.
2. Insert 15 digits of your imei and press buton [Unlock]
3. Programm calculate codes for old modems [X020, X030] and all other rest is NEW.
Any questions or technical help:
Icq: 333-414-824
Sonork 100.69222
That all.
File Type: zip Alcatel_MODEMS_NCK_Inserter_v1.0.0.zip (249.1 KB, 4358 views)
The Following 8 Users Say Thank You to TestBox2 For This Useful Post:
can any one send me a perfect tutorial on siemens flashing sidharthaharish x1x to x45/x50 0 12-30-2001 07:51
partial flash tutorial pilcris Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-05-2001 12:11
New Site, Flash Files, Manuals, Logos, Tones, Tutorials etc simbirley GSM Mobile Links 2 09-14-2001 14:28
Flasher Tutorials BigPoppa Old Ericsson Phones & Sony Phones 0 08-02-2001 16:47
Who can send me Alcatel DB tutorial ? nightxyz Alcatel & TCL Old Models 0 01-15-2001 05:12
Page generated in 0.23463 seconds with 12 queries
