Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: Mars
Member: 87284 Status: Offline Thanks: 10
| HELP!! U20a Dead After Unlock hi i unlocked a Sony Ericsson u20a with octopus-se tool the phone doesnt turn on, doesnt charge, doesnt even blink any led, phone was working 100% before procedure, please help hereīs my log. Platform: SE Qualcomm Selected model: U20a Connecting to server...OK Username: hugovs100_01 Authorizing...OK Octopus smart card is present. Checking smart card...OK Checking balance...OK Your balance: 10 credits. To unlock U20a you need to have 10 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: xxxxxxxxxxxxxxxxxxxx Device status: ACTIVE Reading info... Detected model name: U20a Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Checking security...OK Reading Partition table... Could not read SBL. Maybe, NAND MPU is enabled. Disabling NAND MPU...OK Reconnecting device. Please wait...OK Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK Device serial number: xxxxxxxxxxxxxxxxxxxx Device status: ACTIVE Reading info... Detected model name: U20a Firmware version: 2.1.1.A.0.6 Kernel version: 2.6.29 Kernel version is supported Checking root access... Device is not rooted. Sending exploit...OK Executing exploit...OK Reconnecting device. Please wait...OK Checking root access...OK Root access garanted! Initializing flash...OK Reading Partition table...OK Reading SBL...OK SBL type: Original, version: R8A029 Reading TA...OK Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP \U20a_03-11-2011_13-20-35.BKP" Checking TA...OK IMEI: 012343-xx-xxxxxx-x Replacing SBL...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Finalizing...OK Rebooting device...OK Phone sucesfully unlocked! Last edited by yozh; 11-03-2011 at 20:33. Reason: edited imei and sn from post |
| | #2 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Dec 2009
Member: 1178625 Status: Offline Thanks: 7
| Bug for unlocking is fixed in Qualcomm MSM7227. Repair with Riff, restore backup. Give it back to customer or unlock via IMEI. |
| The Following User Says Thank You to Siechits For This Useful Post: |
| | #3 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks: 3,606
| Quote:
You need to write back to phone original SBL and TA ("U20a_03-11-2011_13-20-35.BKP"). You can't write Octopus Box SE software backup file with RIFF box. You need to contact us and give us backup file. Then we will prepare "*.bin" file which you can write to your phone with Jtag tool that You have. Last edited by Octopus box; 11-04-2011 at 10:55. | |
| | #4 (permalink) |
| hello ill upload my backup, but i dont have any jtag tool, i didnt knew there was a risk that this could happend, if there were i wouldnt even try, i thought your tool was fully tested as theres no warning... thats why i didnt try with other tools as they indeed warn people. anyways, im in big trouble with *******r now so thats the solution you can give me? i basically paid to kill my phone |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008 Location: P@Ki$t@n Age: 30
Member: 777415 Status: Offline Sonork: 1589702 Thanks: 284
| Quote:
We have faced one unpredictable problem that can't be fixed at the moment. It turns out that some of the latest Sony Ericsson MSM7227 CPU based cell phones (E10i, E15i, U20i, E10a, E15a, U20a) have fixed BOOTROM, which leads to certain problems with those mobiles. If you choose to Unlock or Repair IMEI you will most certainly kill your phone. Unfortunately, for the moment there is no possible way to be sure whether the phone has fixed BOOTROM or not. So, please, do all operations with Sony Ericsson MSM7227 CPU based cell phones at your own risk. Since it's not our fault the credits for operations that lead to phone malfunction will not be returned! If you've killed your phone with Unlock or Repair IMEI operation, you can resurrect it with JTAG Box only, using "*.BKP" file from "C:\Program Files\GsmServer\Octopus_SE\BACKUP\". Backup file contains original phone's SBL and TA. | |
| | #6 (permalink) |
| i did my phone yesterday with v1.0.3, v1.0.4 was released today, there were no warning back then.... but thanks please people try not to jump into my threat i really need support to give some kind of solution |
| | #8 (permalink) | |
| Insane Poster ![]() ![]() ![]() Join Date: Jul 2005 Age: 43
Member: 166398 Status: Offline Thanks: 1,049
| It inform us Quote:
Attention to all Octopus SE users! We have faced one unpredictable problem that can't be fixed at the moment. It turns out that some of the latest Sony Ericsson MSM7227 CPU based cell phones (E10i, E15i, U20i, E10a, E15a, U20a) have fixed BOOTROM, which leads to certain problems with those mobiles. If you choose to Unlock or Repair IMEI you will most certainly kill your phone. Unfortunately, for the moment there is no possible way to be sure whether the phone has fixed BOOTROM or not. So, please, do all operations with Sony Ericsson MSM7227 CPU based cell phones at your own risk. Since it's not our fault the credits for operations that lead to phone malfunction will not be returned! If you've killed your phone with Unlock or Repair IMEI operation, you can resurrect it with JTAG Box only, using "*.BKP" file from "C:\Program Files\GsmServer\Octopus_SE\BACKUP\". Backup file contains original phone's SBL and TA. | |
| | #9 (permalink) | |
| Quote:
thanks tho... | |
| | #10 (permalink) |
| If You have no any Jtag tool and have no friends which have Jtag tool You can send us your phone. We will repair it and send it back to You. You should pay only for delivery. Also we have already took back to You 10 credits. |
| | #11 (permalink) |
| Major Poster ![]() ![]() Join Date: Dec 2007 Location: Argentina
Member: 665103 Status: Offline Thanks: 7
| Hi, I also killed one U20a using this method. Does anybody has U20a PINOUT and what method should I use to resurrect with RIFF box? I have the .BKP file. Any help will be appreciated. |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2010 Location: Pinas
Member: 1243303 Status: Offline Sonork: 1591167 Thanks: 203
| always\late loi WARNING killing samsung phone/sony erricson repair by medusa box |
| | #13 (permalink) |
| Ok but that's not helpful. Right now I have RIFF BOX + U20a DEAD. I can connect U20a to riff box, I tried to repair boot but it didn't work. I can only choose x10 mini model since RIFF box doesn't have x10mini pro model, but it should work. Can anyone tell me how to restore SBL + TA from .BAK file using RIFF BOX? That'd be very helpful. Since I consider myself a n00b, I need specific instructions. I need the address and what options to tick or untick. I hope you understand, Thanks. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Eeprom dump lost, help needed. | CAMILO | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:04 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
