12-01-2013, 05:15 | #1 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1891834 Status: Offline Thanks Meter: 0 | st21 no signal after repair imei Platform: SONY Qualcomm Selected model: ST21a Operation: Repair IMEI Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, Medusa Username: guaripolo2 Authorizing...OK Checking balance... Checking operation...OK Your balance: 10 credits. To Repair IMEI for ST21a you need to have 10 credits. Warning! After Repair IMEI operation, You need to make Factory Reset! Please backup your data! Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9104P29R Device status: ACTIVE Reading info... Detected model name: ST21a Firmware version: 11.0.A.4.22 Kernel version: 3.0.8-perf IMEI: 355874050906360 Checking IMEI...OK Checking root access...OK Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files\Octoplus\Octoplus_Suite\BACKUP\Sony_ST21a_35 5874050906360_30-11-2013_10-00-33.sec" Checking security area...OK Old IMEI: 355874-05-090636-0 New IMEI: 355587-05-094636-4 Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Rebooting device...OK IMEI successfully repaired! Make unlock with setool 5 days ago. Reading info on forum i see that this is the problem what can i do?? I have lost 10 credits? |
12-01-2013, 07:11 | #3 (permalink) |
Insane Poster Join Date: Mar 2012
Member: 1731300 Status: Offline Thanks Meter: 16 | Problem is in setool. You need to write backup readed before unlock with setool and make unlock with octopus. p.s. I have the same problem was. |
The Following User Says Thank You to canibbal For This Useful Post: |
12-01-2013, 07:14 | #5 (permalink) |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Backup saved to "C:\Program Files\Octoplus\Octoplus_Suite\BACKUP\Sony_ST21a_35 5874050906360_30-11-2013_10-00-33.sec" |
The Following User Says Thank You to unlock phones For This Useful Post: |
12-01-2013, 07:32 | #6 (permalink) | |
Member: 1891834 Status: Offline Thanks Meter: 0 | Quote:
Enviado desde mi iPhone con Tapatalk | |
