Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus/Octoplus Suite
Old 10-25-2011, 23:26   #1 (permalink)
Member: 1455412
Problem With IMEI
Welcome to Octopus Box SE Software version 1.0.1
Connecting to server...OK
Username: cilian19
Authorizing...OK
Checking balance...OK
Your balance: 26 credits.
Platform: SE Qualcomm
Selected model: E10a
Operation: Repair IMEI
Username: cilian19
Authorizing...OK
Octopus smart card is not present.
To Repair IMEI for E10a you need to have 13 credits.
Initializing Android Debug Bridge...OK
Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK
Device serial number: 43423531314E54525541
Device status: ACTIVE
Reading info...
Detected model name: E10a
Firmware version: 2.0.2.A.0.24
Kernel version: 2.6.29
Kernel version is supported
Checking root access...
Device is not rooted.
Sending exploit...OK
Executing exploit...OK
Reconnecting device. Please wait...OK
Checking root access...OK
Root access garanted!
Initializing flash...OK
Reading Partition table...OK
Reading SBL...OK
SBL type: Unknown
Reading TA...OK
Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\E10a_25-10-2011_16-57-34.BKP"
Checking TA...OK
Old IMEI: 012313-00-173938-5
New IMEI: 393736-09-738357-8
Unknown combination or Partition and SBL! Please, contact to support at: support@octopusbox.com
Username: cilian19
Authorizing...OK
Reading info...
Device is already rooted.
Reading SBL...OK
SBL type: Unknown
Reading TA...OK
Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\E10a_25-10-2011_16-58-30.BKP"
Checking TA...OK
Reading info...
Firmware version: 2.1.1.A.0.6
Username: cilian19
Authorizing...OK
Reading info...
Could not read SBL. Maybe, NAND MPU is enabled.
Disabling NAND MPU...OK
Reading info...
Reading SBL...OK
SBL type: Unknown
Reading TA...OK
Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\E10a_25-10-2011_17-16-59.BKP"
Checking TA...OK
e10.rar - 4shared.com - online file sharing and storage - download
Old 10-26-2011, 08:23   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Hello.
Please check your PM for new version of software.
Old 10-27-2011, 00:36   #3 (permalink)
Member: 1455412
after imei change not detect the SIM CARD, is TA Problem need HELP
Welcome to Octopus Box SE Software version 1.0.2
Username: cilian19
Authorizing...OK
Octopus smart card and DreamBox are not present.
Reading info...
Reading SBL...OK
SBL type: Original, version: R8A029, packed v2
Reading TA...OK
\E10a_26-10-2011_15-21-21.BKP"
Checking TA...OK
New IMEI: 379028-85-257484-1
Replacing SBL...OK
Calculating security on the server...
Sending TA to server...OK
Calculating. Please, wait...OK
Receiving TA...OK
Writing security area...OK
Finalizing...OK
Rebooting device...OK
IMEI sucesfully repaired!
Old 10-27-2011, 00:37   #4 (permalink)
Member: 1455412
E10a After Unlock not detect the SIM CARD
25/10/2011 19:51:45 > Welcome to Octopus Box SE Software version 1.0.1
25/10/2011 19:56:37 > --------------------------------------------------------------------------------
25/10/2011 19:56:37 > Connecting to server...25/10/2011 19:56:38 > OK
25/10/2011 19:56:38 > Username: cilian19
25/10/2011 19:56:38 > Authorizing...25/10/2011 19:56:39 > OK
25/10/2011 19:56:39 > Checking balance...25/10/2011 19:56:39 > OK
25/10/2011 19:56:39 > Your balance: 39 credits.
25/10/2011 19:56:48 > --------------------------------------------------------------------------------
25/10/2011 19:56:48 > Platform: SE Qualcomm
25/10/2011 19:56:48 > Selected model: E10a
25/10/2011 19:56:48 > Connecting to server...25/10/2011 19:56:49 > OK
25/10/2011 19:56:49 > Username: cilian19
25/10/2011 19:56:49 > Authorizing...25/10/2011 19:56:49 > OK
25/10/2011 19:56:49 > Octopus smart card is not present.
25/10/2011 19:56:49 > Checking balance...25/10/2011 19:56:50 > OK
25/10/2011 19:56:50 > Your balance: 39 credits.
25/10/2011 19:56:50 > To unlock E10a you need to have 13 credits.
25/10/2011 19:56:50 > Initializing Android Debug Bridge...25/10/2011 19:56:51 > OK
25/10/2011 19:56:51 > Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...25/10/2011 19:56:52 > OK
25/10/2011 19:56:52 > Device serial number: 43423531314D58543147
25/10/2011 19:56:52 > Device status: ACTIVE
25/10/2011 19:56:52 > Reading info...
25/10/2011 19:56:53 > Detected model name: E10a
25/10/2011 19:56:53 > Firmware version: 2.1.1.A.0.6
25/10/2011 19:56:53 > Kernel version: 2.6.29
25/10/2011 19:56:53 > Kernel version is supported
25/10/2011 19:56:54 > Checking root access...
25/10/2011 19:56:54 > Device is not rooted.
25/10/2011 19:56:54 > Sending exploit...25/10/2011 19:56:54 > OK
25/10/2011 19:56:54 > Executing exploit...25/10/2011 19:56:55 > OK
25/10/2011 19:56:55 > Reconnecting device. Please wait...25/10/2011 19:57:02 > OK
25/10/2011 19:57:02 > Checking root access...25/10/2011 19:57:03 > OK
25/10/2011 19:57:03 > Root access garanted!
25/10/2011 19:57:03 > Initializing flash...25/10/2011 19:57:07 > OK
25/10/2011 19:57:08 > Reading Partition table...
25/10/2011 19:57:09 > Could not read SBL. Maybe, NAND MPU is enabled.
25/10/2011 19:57:09 > Disabling NAND MPU...25/10/2011 19:57:10 > OK
25/10/2011 19:57:10 > Reconnecting device. Please wait...25/10/2011 19:57:26 > OK
25/10/2011 19:57:26 > Initializing Android Debug Bridge...25/10/2011 19:57:27 > OK
25/10/2011 19:57:27 > Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...25/10/2011 19:57:28 > OK
25/10/2011 19:57:28 > Device serial number: 43423531314D58543147
25/10/2011 19:57:28 > Device status: ACTIVE
25/10/2011 19:57:28 > Reading info...
25/10/2011 19:57:29 > Detected model name: E10a
25/10/2011 19:57:29 > Firmware version: 2.1.1.A.0.6
25/10/2011 19:57:29 > Kernel version: 2.6.29
25/10/2011 19:57:29 > Kernel version is supported
25/10/2011 19:57:29 > Checking root access...
25/10/2011 19:57:30 > Device is not rooted.
25/10/2011 19:57:30 > Sending exploit...25/10/2011 19:57:30 > OK
25/10/2011 19:57:30 > Executing exploit...25/10/2011 19:57:31 > OK
25/10/2011 19:57:31 > Reconnecting device. Please wait...25/10/2011 19:57:38 > OK
25/10/2011 19:57:38 > Checking root access...25/10/2011 19:57:39 > OK
25/10/2011 19:57:39 > Root access garanted!
25/10/2011 19:57:39 > Initializing flash...25/10/2011 19:57:43 > OK
25/10/2011 19:57:44 > Reading Partition table...25/10/2011 19:57:45 > OK
25/10/2011 19:57:45 > Reading SBL...25/10/2011 19:57:46 > OK
25/10/2011 19:57:46 > SBL type: Original, version: R8A029
25/10/2011 19:57:46 > Reading TA...25/10/2011 19:57:52 > OK
25/10/2011 19:57:53 > Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\E10a_25-10-2011_19-57-46.BKP"
25/10/2011 19:57:53 > Checking TA...25/10/2011 19:57:53 > OK
25/10/2011 19:57:53 > IMEI: 012313-00-136181-8
25/10/2011 19:57:53 > Replacing SBL...25/10/2011 19:57:57 > OK
25/10/2011 19:57:57 > Calculating security on the server...
25/10/2011 19:57:57 > Sending TA to server...25/10/2011 19:58:00 > OK
25/10/2011 19:58:00 > Calculating. Please, wait...25/10/2011 19:58:00 > OK
25/10/2011 19:58:00 > Receiving TA...25/10/2011 19:58:03 > OK
25/10/2011 19:58:03 > Writing security area...25/10/2011 19:58:04 > OK
25/10/2011 19:58:04 > Finalizing...25/10/2011 19:58:07 > OK
25/10/2011 19:58:07 > Rebooting device...25/10/2011 19:58:07 > OK
25/10/2011 19:58:07 > Phone sucesfully unlocked!
25/10/2011 19:58:36 > --------------------------------------------------------------------------------
Old 10-27-2011, 00:44   #5 (permalink)
Member: 1455412
R800 Afer Unlock & IMEI Change not detect the SIM CARD
25/10/2011 11:00:59 > Welcome to Octopus Box SE Software version 1.0.1
25/10/2011 11:02:00 > --------------------------------------------------------------------------------
25/10/2011 11:02:00 > Connecting to server...25/10/2011 11:02:01 > OK
25/10/2011 11:02:01 > Username: cilian19
25/10/2011 11:02:01 > Authorizing...25/10/2011 11:02:01 > OK
25/10/2011 11:02:01 > Checking balance...25/10/2011 11:02:02 > OK
25/10/2011 11:02:02 > Your balance: 59 credits.
25/10/2011 11:05:34 > --------------------------------------------------------------------------------
25/10/2011 11:05:34 > Platform: SE Qualcomm
25/10/2011 11:05:34 > Selected model: R800
25/10/2011 11:05:34 > Connecting to server...25/10/2011 11:05:35 > OK
25/10/2011 11:05:35 > Username: cilian19
25/10/2011 11:05:35 > Authorizing...25/10/2011 11:05:35 > OK
25/10/2011 11:05:35 > Octopus smart card is present.
25/10/2011 11:05:35 > Checking smart card...25/10/2011 11:05:38 > OK
25/10/2011 11:05:38 > Checking balance...25/10/2011 11:05:39 > OK
25/10/2011 11:05:39 > Your balance: 59 credits.
25/10/2011 11:05:39 > To unlock R800 you need to have 10 credits.
25/10/2011 11:05:39 > --------------------------------------------------------------------------------
25/10/2011 11:05:39 > Platform: SE Qualcomm
25/10/2011 11:05:39 > Selected model: R800
25/10/2011 11:05:39 > Please, attach testpoint and connect USB cable...25/10/2011 11:23:59 > OK
25/10/2011 11:23:59 > Now You can disconnect testpoint.
25/10/2011 11:23:59 > Sending preloader...25/10/2011 11:23:59 > OK
25/10/2011 11:23:59 > Waiting for preloader...25/10/2011 11:24:01 > OK
25/10/2011 11:24:01 > Reading info...
25/10/2011 11:24:01 > Sending loader...25/10/2011 11:24:05 > OK
25/10/2011 11:24:05 > Reading info...25/10/2011 11:24:05 > OK
25/10/2011 11:24:05 > IMEI: 357302-04-276709-4
25/10/2011 11:24:06 > Checking security...25/10/2011 11:24:07 > OK
25/10/2011 11:24:07 > Reading security area...25/10/2011 11:24:07 > OK
25/10/2011 11:24:07 > Backup saved to "H:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\R800_35730204 276709_25-10-2011_11-24-07.BKP"
25/10/2011 11:24:07 > Checking TA...25/10/2011 11:24:07 > OK
25/10/2011 11:24:07 > IMEI: 357302-04-276709-4
25/10/2011 11:24:07 > Calculating security on the server...
25/10/2011 11:24:07 > Sending TA to server...25/10/2011 11:24:10 > OK
25/10/2011 11:24:10 > Calculating. Please, wait...25/10/2011 11:24:11 > OK
25/10/2011 11:24:11 > Receiving TA...25/10/2011 11:24:15 > OK
25/10/2011 11:24:15 > Checking security area...
25/10/2011 11:24:15 > Writing security area...25/10/2011 11:24:15 > OK
25/10/2011 11:24:15 > Shutting down...25/10/2011 11:24:15 > OK
25/10/2011 11:24:15 > Phone sucesfully unlocked!
25/10/2011 11:24:38 > --------------------------------------------------------------------------------
25/10/2011 11:28:21 > Welcome to Octopus Box SE Software version 1.0.1
25/10/2011 11:28:21 > --------------------------------------------------------------------------------
25/10/2011 11:28:21 > Platform: SE Qualcomm
25/10/2011 11:28:21 > Selected model: R800
25/10/2011 11:28:21 > Operation: Repair IMEI
25/10/2011 11:28:21 > Connecting to server...25/10/2011 11:28:22 > OK
25/10/2011 11:28:22 > Username: cilian19
25/10/2011 11:28:22 > Authorizing...25/10/2011 11:28:22 > OK
25/10/2011 11:28:22 > Octopus smart card is present.
25/10/2011 11:28:22 > Checking smart card...25/10/2011 11:28:25 > OK
25/10/2011 11:28:25 > Checking balance...25/10/2011 11:28:26 > OK
25/10/2011 11:28:26 > Your balance: 49 credits.
25/10/2011 11:28:26 > To Repair IMEI for R800 you need to have 10 credits.
25/10/2011 11:28:26 > --------------------------------------------------------------------------------
25/10/2011 11:28:26 > Platform: SE Qualcomm
25/10/2011 11:28:26 > Selected model: R800
25/10/2011 11:28:26 > Please, attach testpoint and connect USB cable...25/10/2011 11:28:35 > OK
25/10/2011 11:28:35 > Now You can disconnect testpoint.
25/10/2011 11:28:35 > Sending preloader...25/10/2011 11:28:35 > OK
25/10/2011 11:28:35 > Waiting for preloader...25/10/2011 11:28:37 > OK
25/10/2011 11:28:37 > Reading info...
25/10/2011 11:28:37 > Sending loader...25/10/2011 11:28:42 > OK
25/10/2011 11:28:42 > Reading info...25/10/2011 11:28:42 > OK
25/10/2011 11:28:42 > IMEI: 357302-04-276709-4
25/10/2011 11:28:42 > Checking security...25/10/2011 11:28:44 > OK
25/10/2011 11:28:44 > Reading security area...25/10/2011 11:28:44 > OK
25/10/2011 11:28:44 > Backup saved to "H:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\R800_35730204 276709_25-10-2011_11-28-44.BKP"
25/10/2011 11:28:44 > Checking TA...25/10/2011 11:28:44 > OK
25/10/2011 11:28:44 > Old IMEI: 357302-04-276709-4
25/10/2011 11:28:44 > New IMEI: 350338-35-365255-5
25/10/2011 11:28:44 > Calculating security on the server...
25/10/2011 11:28:44 > Sending TA to server...25/10/2011 11:28:46 > OK
25/10/2011 11:28:46 > Calculating. Please, wait...25/10/2011 11:28:47 > OK
25/10/2011 11:28:47 > Receiving TA...25/10/2011 11:28:50 > OK
25/10/2011 11:28:50 > Checking security area...
25/10/2011 11:28:50 > Writing security area...25/10/2011 11:28:50 > OK
25/10/2011 11:28:50 > Shutting down...25/10/2011 11:28:50 > OK
25/10/2011 11:28:50 > IMEI sucesfully repaired!
Old 10-27-2011, 16:54   #6 (permalink)
Member: 1455412
Any data for My problem?????
Old 11-01-2011, 14:27   #7 (permalink)
Member: 1455412
full solution, repair all phone! thanks excellent support
Old 11-03-2011, 18:15   #8 (permalink)
Member: 421331
How do you repair all your phones?, please tell us
Old 11-04-2011, 08:55   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
Fixed on the server side. You only need to make unlock the phone again.
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.35399 seconds with 11 queries
