12-03-2018, 11:20
#1 (permalink)
Member: 2669781
Thanks Meter: 1,839 | SE E10I_{Network Lock}_Successfully Removed.... Full logs of the operation/ Quote: Full Flash to Fix:Error code: PQR1237B23 Code: -------------------------------------------------------------------------------------------
Platform: SE Qualcomm
Selected model: E10i
Opening "E10i_2.1.1.A.0.6_CUST_UA_WORLD.oct"...OK
Please, reconnect battery, hold "back" key and connect USB cable...OK
Reading info...
Chipset: S1 MSM7227
IMEI: 012312-00-878946-8
MSN: CB511LRW9M
Sending loader...OK
Writing Firmware...
Writing AMSS...OK
Writing AMSS_FS...OK
Writing CACHE...OK
Writing FOTA0...OK
Writing FOTA1...OK
Writing KERNEL...OK
Writing SYSTEM...OK
Writing USERDATA...OK
Shutting down...OK
------------------------------------------------------------------------------------------- Network Lock Removal: Code: Initializing Android Debug Bridge...OK
Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...OK
Device serial number: 43423531314C5257394D
Device status: ACTIVE
Reading info...
Detected model name: E10i
Firmware version: 2.1.1.A.0.6
Kernel version: 2.6.29
Kernel version is supported
Checking root access...
Device is not rooted.
Sending exploit...OK
Executing exploit...OK
Reconnecting device. Please wait...OK
Checking root access...OK
Root access garanted!
Initializing flash...OK
Reading Partition table...OK
Reading SBL...OK
SBL type: Original, version: R8A029
Reading TA...OK
Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP\Sony Ericsson_E10i_03-12-2018_11-15-09.BKP"
Checking TA...OK
Replacing SBL...OK
Calculating security on the server...
Sending TA to server...OK
Calculating. Please, wait...OK
Receiving TA...OK
Writing security area...OK
Finalizing...OK
Checking bootloaders...
Check succesfully completed!
Checking TA...
Rebooting device...OK
Phone successfully unlocked! |
