11-18-2013, 11:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | Sony C1504 unlock problem [Solved] -------------------------------------------------------------------------------- Connecting to server...OK Username: Authorizing...OK Checking balance...OK Your balance: 20 credits. Octopus smart card is present. Checking smart card...OK Smart card activations: Medusa -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: 37bc0192 Device status: ACTIVE Reading info... Detected model name: C1504 Firmware version: 11.3.A.0.58 Kernel version: 3.4.0-perf IMEI: 35555805235 -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: Medusa Username: Authorizing...OK Checking balance... Checking operation...OK Your balance: 20 credits. To unlock C1504 you need to have 10 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: 37bc0192 Device status: ACTIVE Reading info... Detected model name: C1504 Firmware version: 11.3.A.0.58 Kernel version: 3.4.0-perf IMEI: 35555805235 Checking IMEI...OK Checking root access... Device is not rooted. Device will be rooted now. Please wait.. Press "Allow/Grant" button on the phone every time when superuser dialog appears! Checking root access... Root access garanted! Reading security area...OK Backup saved to "G:\Octoplus_Suite\BACKUP\Sony_C1504_355558052 35_ 18-11-2013_11-06-46.sec" Checking security area...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Rebooting device...OK Phone successfully unlocked! but show emergency call only no network......... Last edited by Octopus box; 11-20-2013 at 11:59. |
11-18-2013, 11:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Make Factory reset and then try to use different SIM cards. Also, please upload somewhere security backup "Sony_C1504_35555805235_18-11-2013_11-06-46.sec" and post here log; we will look where can be the problem. |
11-18-2013, 14:05 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please make security backup manually (Connect the phone and press "Read Security Backup" button in software) and upload received file. |
11-18-2013, 16:30 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please reflash the phone with any firmware from support area, then make Repair IMEI and Unlock. Also please contact us in Skype, Yahoo! Messenger, ICQ or write Your login in private message here, on forum. Last edited by Octopus box; 11-18-2013 at 17:03. |
11-20-2013, 09:11 | #9 (permalink) |
Member: 1150957 Status: Offline Thanks Meter: 60 | phone come from australia boost mobile, so i download C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(Bo ost Mobile,Australia).oct phone can not flash log: Welcome to Octoplus/Octopus Suite version 1.2.4 -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Opening "C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(B oost Mobile,Australia).oct"...OK Please, reconnect battery, hold "Vol-" key and connect USB cable...OK Reading info... Chipset: S1 MSM7225A IMEI: 355558-05-235426-1 Sending loader...Failed! -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Opening "C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(B oost Mobile,Australia).oct"...OK Please, reconnect battery, hold "Vol-" key and connect USB cable...OK Reading info... Chipset: S1 MSM7225A IMEI: 355558-05-235426-1 Sending loader...Failed! -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...Canceled. -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Octopus smart card is present. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...Canceled. -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Opening "C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(B oost Mobile,Australia).oct"...OK Please, reconnect battery, hold "Vol-" key and connect USB cable...OK Reading info... Chipset: S1 MSM7225A IMEI: 355558-05-235426-1 Sending loader...Failed! -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Opening "C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(B oost Mobile,Australia).oct"...OK Please, reconnect battery, hold "Vol-" key and connect USB cable...OK Reading info... Chipset: S1 MSM7225A IMEI: 355558-05-235426-1 Sending loader...Failed! -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Opening "C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(B oost Mobile,Australia).oct"...OK Please, reconnect battery, hold "Vol-" key and connect USB cable...OK Reading info... Chipset: S1 MSM7225A IMEI: 355558-05-235426-1 Sending loader...Failed! -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: C1504 Opening "C1504_11_3_A_0_58.FSP_NanHuSS_WORLD_a_1273_6378(B oost Mobile,Australia).oct"...OK Please, reconnect battery, hold "Vol-" key and connect USB cable...OK Reading info... Chipset: Unknown IMEI: Sending loader...Failed! all time show this message |
11-20-2013, 09:14 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please do the next: 1. Write back to your phone security backup "Sony_C1504_35555805235_18-11-2013_11-06-46.sec". 2. Re-flash the phone. 3. Make Unlock again. 4. Post here the result. |
