08-29-2014, 19:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 39
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | sony st21a no signal after repair imei [Solved] I made hard reset and every mobile several times and not just sign up .... I have not tried to flash but I thought ... -------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST21a Operation: Repair IMEIOK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited, Medusa Authorizing...OK Username: alexis_alvarez14 Authorizing...OK Checking balance... Checking operation...OK Your balance: 15 credits. To Repair IMEI for ST21a you need to have 6 credits. Warning! After Repair IMEI operation, You need to make Factory Reset! Please backup your data! Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT90035B2S Device status: ACTIVE Reading info... Detected model name: ST21a Firmware version: 11.0.A.0.16 Kernel version: 3.0.8-perf IMEI: 35380805515 Checking IMEI...OK Checking root access...OK Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files\Octoplus\Octoplus_Suite\BACKUP \Sony_ST21a_353808055151939_29-08-2014_14-20-32.sec" Checking security area...OK Old IMEI: 353808-05-515 New IMEI: 353808-05-614250-7 Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Rebooting device...OK IMEI successfully repaired! To complete the operation, please make Factory Reset (select menu "Settings"->"Backup & reset"->"Factory data reset", press "Reset phone" and "Erase everything" buttons. Last edited by Octopus box; 09-01-2014 at 16:27. |
08-29-2014, 19:27 | #2 (permalink) |
No Life Poster Join Date: Sep 2012 Location: UK
Member: 1816005 Status: Offline Thanks Meter: 299 | To complete the operation, please make Factory Reset (select menu "Settings"->"Backup & reset"->"Factory data reset", press "Reset phone" and "Erase everything" buttons. if this didn't worked than flash phone |
08-29-2014, 23:20 | #4 (permalink) |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | I have done repair and repair safety when I restarted network locked up, now I'm trying to unlock and throws me error: Platform: SONY Qualcomm Selected model: ST21aOK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited, Medusa Authorizing...OK Username: alexis_alvarez14 Authorizing...OK Checking balance... Checking operation...OK Your balance: 9 credits. To unlock ST21a you need to have 4 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT90035B2S Device status: ACTIVE Reading info... Detected model name: ST21a Firmware version: 11.0.A.0.16 Kernel version: 3.0.8-perf IMEI: 353808056142507 Checking IMEI...OK Checking root access...OK Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files\Octoplus\Octoplus_Suite\BACKUP\Sony_ST21a_35 3808056142507_29-08-2014_18-53-25.sec" Checking security area...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! |
08-30-2014, 07:26 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. Please upload somewhere the first Security backup file "Sony_ST21a_353808055151939_29-08-2014_14-20-32.sec" and post here the link, we will check, maybe your phone was unlocked by other tool before You have performed the Repair IMEI operation. In this case, after repairing IMEI, network will be unavailable. Also, look here: http://forum.gsmhosting.com/vbb/f699.../#post10379574. |
08-30-2014, 16:15 | #6 (permalink) | |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | Quote:
Sony_ST21a_353808055151939_29-08-2014_14-20-32 - Download - 4shared | |
08-31-2014, 12:14 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | @ alexis_01 We have researched your Security backup You have uploaded above - your device was unlocked by third party tool, so after repairing IMEI, network is unavailable. We have refunded 6 credits to your "alexis_alvarez14" account, please check your balance. If You want to make Repair IMEI and have network active, do the next: 1. Make Repair Security. 2. Make Factory data reset. 3. Perform the Unlock operation. 4. Make Factory data reset. 5. Perform the Repair IMEI operation. 6. Make Factory data reset. |
09-01-2014, 16:21 | #11 (permalink) | |
The Following User Says Thank You to alexis_01 For This Useful Post: |
