12-11-2018, 17:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | ST23i calculating problem [Solved] Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"->"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9100UXFP Device status: ACTIVE Reading info... Detected model name: ST23i Firmware version: 11.0.A.5.8 Kernel version: 3.0.8-perf IMEI: 354390052874333 Checking IMEI...OK Checking root access...OK Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP\Sony_ST23i_35 4390052874333_11-12-2018_16-22-08.sec" Checking security area...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...Failed! Last edited by Octopus box; 12-15-2018 at 09:00. |
12-11-2018, 19:20 | #2 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Hi sir, Try to flash one of the firmware available at support area, then repeat the operation ... Good luck |
The Following User Says Thank You to lyes_albert For This Useful Post: |
12-12-2018, 12:54 | #4 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Hi again, Try to flash the following firmware, a small downgrade shall occur, from 11.0.A.5.8 to 11.0.A.5.5. Then repeat the unlock operation... https://androidfilehost.com/?fid=24572330218881170 Please, know, that i have personally tried this several times, without any problems, but still, you can take the risk, i'm not responsible for any damage.... Good luck.. |
12-14-2018, 22:09 | #7 (permalink) |
Member: 2548753 Status: Offline Thanks Meter: 256 | done thanks teaam Welcome to Octoplus Suite version 1.5.8 ------------------------------------------------------------------------------------------- Platform: SONY Qualcomm Selected model: ST23i Connecting to server...OK Octopus smart card is present. Checking smart card...OK Smart card activations: LG, Samsung, SE Unlimited, Medusa Username: medoffiiciel Authorizing...OK Checking balance... Checking operation...OK Your balance: 0 credits. To unlock ST23i you need to have 0 credits. Initializing Android Debug Bridge...OK Disconnect USB cable and power on the phone. Select menu "Settings"- >"Developer options"->"Enable USB debugging" and connect USB cable...OK Device serial number: YT9100UXFP Device status: ACTIVE Reading info... Detected model name: ST23i Firmware version: 11.0.A.5.8 Kernel version: 3.0.8-perf IMEI: 354390052874333 Checking IMEI...OK Checking root access...OK Device is already rooted. Reading security area...OK Backup saved to "C:\Program Files (x86)\Octoplus\Octoplus_Suite\BACKUP \Sony_ST23i_354390052874333_14-12-2018_21-08-53.sec" Checking security area...OK Calculating security on the server... Sending TA to server...OK Calculating. Please, wait...OK Receiving TA...OK Writing security area...OK Rebooting device...OK Phone successfully unlocked! |
The Following 2 Users Say Thank You to Medofficiel For This Useful Post: |
