Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus/Octoplus Suite
Old 04-13-2012, 12:00   #1 (permalink)
turkcellgsm's Avatar
Member: 395431
Question X10İ NOT UNLOCK Calculating security on the server ?
Platform: SE Qualcomm
Selected model: X10i
Connecting to server...OK
Octopus smart card is present.
Checking smart card...OK
Smart card activations: LG, SE Unlimited
Authorizing...OK
Prepairing unlock operation...OK
Your balance: 0 credits.
To unlock X10i you need to have 0 credits.
Disconnect USB cable and power on the phone. Select menu
"Settings"->"Applications"->"Development"->"Enable USB debugging" and connect
USB cable...OK
Device serial number: CBXXXXXX
Device status: ACTIVE
Kernel version: 2.6.29
Firmware version:
Kernel version is supported
Checking root access...
Device is already rooted.
Initializing flash...OK
Checking security...OK
Reading SBL...OK
SBL type: Original, version: R8A013
Reading TA...OK
Backup saved to "F:\OCTOPUSBOX\Octopus_Suite\BACKUP\Sony Ericsson_X10i_
13-04-2012_13-51-57.BKP"
Checking TA...OK
IMEI: 359XXXXXXXXXX
Replacing SBL...OK
Calculating security on the server...
Old 04-13-2012, 13:11   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Hello.
Please try again now and post the result here.
Old 04-13-2012, 14:48   #3 (permalink)
Member: 395431
Connecting to server...Failed!
Your IP is in black list!
Welcome to Octopus Suite version 1.0.3
Username:
Authorizing...Failed!
Login error: Wrong username!
Authorizing...OK
USB cable...OK
Device serial number: CBxxxx
Firmware version:
Reading SBL...OK
Reading TA...OK
13-04-2012_16-49-54.BKP"
Checking TA...OK
IMEI: 359xxxxxxxxxxx
Replacing SBL...OK
Old 04-13-2012, 14:54   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please contact us to Sonork now, we will look where is the problem.
Old 04-13-2012, 16:17   #5 (permalink)
Member: 395431
thanks octobus team good work
Authorizing...OK
USB cable...OK
Device serial number: CBxxxxxxxxxx
Firmware version: 2.1.A.0.435
Device is not rooted.
Sending exploit...OK
Executing exploit...OK
Reconnecting device. Please wait...OK
Checking root access...OK
Root access garanted!
Reading SBL...OK
Reading TA...OK
13-04-2012_18-16-05.BKP"
Checking TA...OK
IMEI: 359xxxxxxx
Replacing SBL...OK
Sending TA to server...OK
Calculating. Please, wait...OK
Receiving TA...OK
Writing security area...OK
Finalizing...OK
Rebooting device...OK
Phone sucesfully unlocked!
Old 04-16-2012, 18:47   #6 (permalink)
Member: 381487
good ..... I am having the same problem and would like to know the possible solution
Selected model: U20i
Initializing Android Debug Bridge...OK
USB cable...OK
Device serial number: 43423531314D465xxxxx
Reading info...
Detected model name: U20i
Firmware version: 2.0.2.A.0.24
Operation: Repair IMEI
Authorizing...OK
Checking operation...OK
To Repair IMEI for U20i you need to have 0 credits.
USB cable...OK
Device serial number: 43423531314D4xxxxx
Reading info...
Reading Partition table...OK
Reading SBL...OK
SBL type: Original, version: R8A029
Reading TA...OK
Backup saved to "C:\Archivos de programa\GsmServer\Octopus_Suite\BACKUP
\Sony Ericsson_U20i_16-04-2012_13-44-03.BKP"
Checking TA...OK
Old IMEI: 012342-00-5674xxxx
New IMEI: 012342-00-567xxxx
Replacing SBL...OK
Old 04-17-2012, 07:55   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
@ alexis_01
Hello.
Please try again now. If the problem will be the same - contact us, we will look where is the problem remotely via Team Viewer.
Old 04-18-2012, 06:52   #8 (permalink)
Member: 395431
server problem try again try again after time 5 minute 15 minute 30 minute 1 hours
no problem unlock ok
thanks gsm server team
Old 04-20-2012, 19:31   #9 (permalink)
Member: 260694
i have the same probleme ...help plz gsmserver team
Old 04-20-2012, 19:32   #10 (permalink)
Member: 260694
Selected model: MT11i
Authorizing...OK
To unlock MT11i you need to have 0 credits.
Please, reconnect battery, attach testpoint and connect USB cable...Canceled.
Selected model: LT18i
Authorizing...OK
To unlock LT18i you need to have 0 credits.
Please, reconnect battery, attach testpoint and connect USB cable...OK
Sending preloader...OK
Please, disconnect testpoint.
Waiting for preloader...OK
Reading info...
Sending loader...OK
Reading info...OK
IMEI: 351870-05-772843-9
Reading security area...OK
\Sony Ericsson_LT18i_35187005772843_20-04-2012_20-14-54.BKP"
Checking TA...OK
Old 04-21-2012, 05:15   #11 (permalink)
Member: 1556436
i have same problem only that mine is SO-01C, it ends up at Calculating Security At server, now it keep saying my ip is in blacklist,
Old 04-21-2012, 06:02   #12 (permalink)
Member: 324705
you login 5 times ....
try after 30 minutes
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.32680 seconds with 11 queries
