Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus/Octoplus Suite
Old 02-16-2012, 23:09   #1 (permalink)
Braycel's Avatar
Member: 813309
Xperia X8 Dead After Unlock
Hi
Any Solution Phone Is Dead Not Boot ????? Why ???
> Platform: SE Qualcomm
16/02/2012 12:30:11 > Selected model: E15a
16/02/2012 12:30:11 > Connecting to server...16/02/2012 12:30:11 > OK
16/02/2012 12:30:11 > Username: xxxxxxxxx
16/02/2012 12:30:11 > Authorizing...16/02/2012 12:30:12 > OK
16/02/2012 12:30:12 > Octopus smart card is present.
16/02/2012 12:30:12 > Checking smart card...16/02/2012 12:30:15 > OK
16/02/2012 12:30:15 > Checking balance...16/02/2012 12:30:16 > OK
16/02/2012 12:30:16 > Your balance: 25 credits.
16/02/2012 12:30:16 > To unlock E15a you need to have 5 credits.
16/02/2012 12:30:16 > Initializing Android Debug Bridge...16/02/2012 12:30:17 > OK
16/02/2012 12:30:17 > Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...16/02/2012 12:30:17 > OK
16/02/2012 12:30:17 > Device serial number: 42583930324A374C4658
16/02/2012 12:30:17 > Device status: ACTIVE
16/02/2012 12:30:17 > Reading info...
16/02/2012 12:30:18 > Detected model name: E15a
16/02/2012 12:30:18 > Firmware version: 2.0.1.A.0.47
16/02/2012 12:30:18 > Kernel version: 2.6.29
16/02/2012 12:30:18 > Kernel version is supported
16/02/2012 12:30:18 > Checking root access...
16/02/2012 12:30:19 > Device is already rooted.
16/02/2012 12:30:19 > Initializing flash...16/02/2012 12:30:19 > OK
16/02/2012 12:30:21 > Checking security...16/02/2012 12:30:22 > OK
16/02/2012 12:30:22 > Reading Partition table...
16/02/2012 12:30:23 > Could not read SBL. Maybe, NAND MPU is enabled.
16/02/2012 12:30:23 > Disabling NAND MPU...16/02/2012 12:30:24 > OK
16/02/2012 12:30:24 > Reconnecting device. Please wait...16/02/2012 12:30:54 > OK
16/02/2012 12:30:54 > Initializing Android Debug Bridge...16/02/2012 12:30:55 > OK
16/02/2012 12:30:55 > Disconnect USB cable and power on the phone. Select menu "Settings"->"Applications"->"Development"->"Enable USB debugging" and connect USB cable...16/02/2012 12:30:55 > OK
16/02/2012 12:30:55 > Device serial number: 42583930324A374C4658
16/02/2012 12:30:55 > Device status: ACTIVE
16/02/2012 12:30:55 > Reading info...
16/02/2012 12:30:56 > Detected model name: E15a
16/02/2012 12:30:56 > Firmware version: 2.0.1.A.0.47
16/02/2012 12:30:56 > Kernel version: 2.6.29
16/02/2012 12:30:56 > Kernel version is supported
16/02/2012 12:30:56 > Checking root access...
16/02/2012 12:30:57 > Device is not rooted.
16/02/2012 12:30:57 > Sending exploit...16/02/2012 12:30:57 > OK
16/02/2012 12:30:57 > Executing exploit...16/02/2012 12:30:58 > OK
16/02/2012 12:30:58 > Reconnecting device. Please wait...16/02/2012 12:31:13 > OK
16/02/2012 12:31:13 > Checking root access...16/02/2012 12:31:13 > OK
16/02/2012 12:31:13 > Root access garanted!
16/02/2012 12:31:13 > Initializing flash...16/02/2012 12:31:18 > OK
16/02/2012 12:31:19 > Reading Partition table...16/02/2012 12:31:19 > OK
16/02/2012 12:31:20 > Reading SBL...16/02/2012 12:31:20 > OK
16/02/2012 12:31:20 > SBL type: Original, version: R8A029
16/02/2012 12:31:21 > Reading TA...16/02/2012 12:31:26 > OK
16/02/2012 12:31:26 > Backup saved to "C:\Archivos de programa\GsmServer\Octopus_SE\BACKUP\E15a_16-02-2012_12-31-20.BKP"
16/02/2012 12:31:26 > Checking TA...16/02/2012 12:31:26 > OK
16/02/2012 12:31:26 > IMEI: 358452-04-118088-7
16/02/2012 12:31:26 > Replacing SBL...16/02/2012 12:31:29 > OK
16/02/2012 12:31:29 > Calculating security on the server...
16/02/2012 12:31:29 > Sending TA to server...16/02/2012 12:31:34 > OK
16/02/2012 12:31:34 > Calculating. Please, wait...16/02/2012 12:31:34 > OK
16/02/2012 12:31:34 > Receiving TA...16/02/2012 12:31:37 > OK
16/02/2012 12:31:37 > Writing security area...16/02/2012 12:31:39 > OK
16/02/2012 12:31:39 > Finalizing...16/02/2012 12:31:41 > OK
16/02/2012 12:31:41 > Checking bootloaders...
16/02/2012 12:31:42 > Check succesfully completed!
16/02/2012 12:31:42 > Checking TA...
16/02/2012 12:31:47 > Check succesfully completed!
16/02/2012 12:31:47 > Rebooting device...16/02/2012 12:31:48 > OK
16/02/2012 12:31:48 > Phone sucesfully unlocked!
The Following User Says Thank You to Braycel For This Useful Post:
Old 02-16-2012, 23:18   #2 (permalink)
Member: 765909
Sonork: 100.1608098
Originally Posted by Braycel View Post
Hi
Check Bettry if same try to flash with latest version
Old 02-16-2012, 23:23   #3 (permalink)
Braycel's Avatar
Member: 813309
Not Is Not Battery And No Detect By Pc
Old 02-17-2012, 07:01   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Hello.
Please fully charge phone's battery, put the phone into Download mode and re-flash it with the firmware from the support area. If the problem will be the same, please contact us, we will look where is the problem with your phone.
Old 02-17-2012, 17:52   #5 (permalink)
Braycel's Avatar
Member: 813309
Originally Posted by Octopus box View Post
Hello.
Phone Boot Is Dead Not Conect To Pc No On Green Led
Old 02-17-2012, 19:42   #6 (permalink)
Member: 765909
Sonork: 100.1608098
Finally repair damage boot with jtag
And reflash again
Old 02-18-2012, 21:44   #7 (permalink)
Braycel's Avatar
Member: 813309
And reflash again
Ok Is Not Problem My Question Is Why Dead ???? All Is Ok In Process
Old 02-19-2012, 17:39   #8 (permalink)
Braycel's Avatar
Member: 813309
Is Not Detect By Jtag
Old 02-20-2012, 15:11   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
Very strange, if your E15a doesn't connect even via Jtag, it can be HW problem.
Old 02-20-2012, 22:01   #10 (permalink)
Braycel's Avatar
Member: 813309
But Before Unlock Phone Work Full
Old 03-03-2012, 03:58   #11 (permalink)
Registered User
Member: 559439
repair TA,trying ? ok men
Old 03-03-2012, 04:20   #12 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
if it's dead by software problem or unlock or anything else then it's must detected by jtag..............
if jtag is not able to detect your phone then sure it's hardware problem .........
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.34361 seconds with 11 queries
