06-14-2005, 18:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Europe Age: 39
Member: 51989 Status: Offline Sonork: 1575109 Thanks Meter: 145 | Big problem...? :o |
06-15-2005, 11:55 | #3 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Getting it to work is easy... making it do the things you want is another thing. Age: 22
Member: 9824 Status: Offline Thanks Meter: 79 | Your card is not communicating with the program. It might happen that you can WRITE on a card, but because of timing errors or not enough power etc. you can NOT read from your card. Check again the device settings in IC-PROG. Use external power (not from usb/serial) to supply your programmer. If all of this won't work, try different computer (better not Laptop if you are using a RS232 programmer because power is usualy too low on them) Are you sure you have written ANYTHING on your silvercard yet? Follow exactly the instructions as given on the site of Devian (Simemu) Ch@in |
06-15-2005, 16:31 | #5 (permalink) |
Member: 51989 Status: Offline Sonork: 1575109 Thanks Meter: 145 | I use external power suply.... I using this programator from this page...http://sat.riga.lv/jonis/images/jon122bsch.GIF I'am using not laptop. i using perconal computer.... I think tha t i write in silver card, when i write pic it write ok, and i can read it, but i can not write eeprom. It can be what my silver card are damaget, i want say that my silver card pic is ok, but eeprom are damaged? Daes anybody know program with witch i can test my silver card...Eeprom and pic? |
06-15-2005, 22:45 | #6 (permalink) |
Member: 9824 Status: Offline Thanks Meter: 79 | you can write a loader on your silver card from a different source like the sat cards, and try to upload an eprom with a phoenix device. Like that you could test your card. search in google for " DS9, silvercard, IRDETO, HEX " .... and it will give you results. good luclk |
06-16-2005, 11:44 | #7 (permalink) |
Member: 51989 Status: Offline Sonork: 1575109 Thanks Meter: 145 | Problem solved.....Was driver and Icprog congfig problem...Today i sucefull program smy silver card... Thanks all peaple what help me... |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
1112 inset sim BIG PROBLEM BIG BIG BIG | mr_suspend | Nokia Hardware & Hardware Repair | 4 | 09-01-2008 06:12 |
big big big big big problem with server | software zone | FuriousGold | 1 | 01-16-2008 17:25 |
big big big big problem 3510i keyboard | Chawkiz_gsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 27 | 02-17-2007 06:18 |
*** Big BIg big big problem...pls see all ******** | sunnyc | Nokia Hardware & Hardware Repair | 8 | 10-07-2005 04:53 |
