02-12-2011, 10:40 | #1 (permalink) |
Crazy Poster Join Date: Jan 2011
Member: 1495902 Status: Offline Thanks Meter: 2 | IMSI Change |
03-02-2011, 07:37 | #3 (permalink) |
No Life Poster Join Date: Aug 2002
Member: 15073 Status: Offline Thanks Meter: 12 | Hi, The IMSI is diferent to IMEI. The first are in the SIM and the other in the device. You can only change the IMSI in card like SIMEMU... Regards, Sir Graham w w w . e n d o r a s o f t . com |
08-20-2013, 15:23 | #4 (permalink) | |
Freak Poster Join Date: May 2010 Location: pokhara,nepal
Member: 1314041 Status: Offline Thanks Meter: 43 | Imsi Quote:
09-01-2013, 15:39 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | the Test IMSI is an IMSI number that you should create follwoing the pattern 08091010xxxxxxxxxx. A SIM card with an IMSI such as that will not be blocked by the iPhone BB. To create a test IMSI SIM card, you need to get a SIM card whose IMSI can be changed, a normal SIM card will not allow such change, there are some SIM cards that allow this such as Super SIM 16 in 1 Super Sim Card Backup, Copy, Duplicate, Clone, Reader, Writer Kit at Vavolo.com Mr. Dill Huang suggests that first you insert you carrier SIM card, because its blocked you will only be able to make emergency calls, so dial 112 for emergency call, after 2 seconds hang up and switch to airplane mode, remove your carrier SIM card and insert your test SIM card which you create with the Test IMSI, switch off your airplane mode and the phone should go back to your carrier service, the BB will not block as the Test IMSI is unblocked by the BB (even if it is a locked BB, because this is a test IMSI). Mr. Dill even displays this on YouTube, check it here iPhone 4 SIM Unlock: Test IMSI and 112 Exploit - YouTube Even if the technique works, the iPhone will at some point in time (not sure about the timers) to refresh the IMSI and encryption keys from the SIM card, at which point it will not be able to get the correct original IMSI and encryption keys, so you will need to keep doing this, not to mention dialing the 112 number which could get answered! You can find this and more information at the following "unofficial" FAQ by Mr. Dill himself here Singularity: Unofficial Gevey FAQ Source (test sim imsi - JailbreakQA ) |
The Following 2 Users Say Thank You to zishhaider For This Useful Post: |
09-24-2013, 20:09 | #9 (permalink) |
Freak Poster Join Date: Aug 2012 Location: here and olny here
Member: 1798073 Status: Offline Thanks Meter: 7 | i dont know .... it is seems to me that the change of the imsi is imposible because if you will change the imsi ., foe example , to the same namber of your friemd sim card so all your calls will be on his acaunt because the carier is recognize the acaunt by the imsi so ....... for all the members that want to change the imsi i sugess to rethink best regards |
07-03-2017, 09:17 | #12 (permalink) |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | Check RSIM !!!! take a look at ebay... at the moment are avaible to buy "R-SIM 11" sim layer which give You possibility to put any IMSI code.... this same way .... any simcards will work without loosing waranty ! Take a Look ==> Unlock iPhone 6S/6/5S/5C/5/4S iOS7 with R-SIM,support IOS 5.0~8.0!RSIM R-SIM Offical Website RSIM 10+,RSIM9+,RSIM 9 PRO mini air,R-SIM8+,SAMSIM,3G,R-SIM5+,R-SIM6,RSIM5+,RSIM6,RSIM7,R-SIM7+?Unlock,iPhone5,iPhone4S,Firmware,Any version, No jailbreak |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Can anybody help me with solution to change 51/61/3210 IMEI? | soff | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-08-2011 15:28 |
Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-20-1999 16:56 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
