Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2010
Member: 1217503 Status: Offline Thanks: 0
| Free SimScan Tools Simmaster 2.0 6XSpeed Free SimScan Tools SimMaster 2.0 6XSpeed for COMP128V1 and CMCC V0 Free Download: http://www.520ppc.com/dispbbs.asp?boardid=33&Id=2207 http://simmaster.blog.163.com/ |
| The Following 2 Users Say Thank You to listBT For This Useful Post: |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2008 Location: karachi
Member: 867259 Status: Offline Sonork: 100.1595961 Thanks: 167
| TRy TO upload it AT rapidshare,4shared.com or megaupload THanx in ADvance |
| The Following User Says Thank You to nadim_mobiles For This Useful Post: |
| | #4 (permalink) |
| Junior Member ![]() ![]() Join Date: Oct 2006 Location: pakistan
Member: 380508 Status: Offline Thanks: 117
| Simmaster 2.0 Simmaster 2.0 The software is free software, only of learning to use, do not for illegal purposes! The software can be quickly cracked GSM V0 V1 card, configure the appropriate script file you can use any ordinary reader of domestic high-speed crack GSM V3 V3.5 V4 public telephone cards, business plane cards, phone cards and other special village card, which can installation of special numbers to ordinary mobile phone. Zhejiang, Hunan, Jiangsu, Anhui, Shandong, Guizhou, Tang speed of around 30 000 times or more per hour. Guangxi, Hubei, Hebei, Xinjiang and other places in the grip of Qi Card speed of 70,000 times. China the fastest speed, fast and reliable software. Welcome free of charge from the software and special cards break the script file. Technical support: QQ: 762.56261 million QQ group: 62819128 357,306,207,893,257 detailed help file, please visit: Home: simmaster SIM KI scanner SimMaster 2.0 Introduction 1, scanning speed, this method of adding enhanced communication and reduce communication latency, to further tap the card CPU running ability, while the original method of communication time to become the bottleneck of the speed, the speed increase is very obvious, sometimes the card can be improved rate of 1-6 times! Picture this topic are as follows: pu.jpg ![]() 2, cpu occupancy rate is low, only 1-2%. 3, to provide 8 scan mode, to improve the success rate of stuck. 3, in the history of the Rand to KI strongest features. 4, supports the full card KI solution. 5, in the history of the strongest Strong KI Card Solutions card (better than SimMaster1.1). 6, the strongest in the history of KI projection algorithm, down from a group known to calculate the entire KI KI only 366 scans. 7, support the PSCS reader. 8, USBTOCOM, COM also supports reverse convention card reader (ATR as 3F at the beginning of the card). 9, super error correction, even in the SIM card in the reader out of a second again and again and back into position, able to automatically resume scanning. 10, the software does not require registration to use all the features and convenient player. Explanation 1, first install the card reader, and drivers, Simmaster 2.0 to support USB-COM port card reader and PC / SC reader. 2, open the software, select the corresponding card reader and the port and speed. Because Simmaster2.0 specify COM8 port, COM port when using USB card reader transfer when the corresponding COM port after installation is not COM8 need to adjust the settings manager to use USB-COM port reader COM8. 3, Simmaster 2.0 adds enhanced reader mode. Adding enhanced communication methods to reduce communication latency, and further excavation card CPU running ability, while the original method of communication time to become the bottleneck of the speed, the speed increase is very obvious, sometimes the card can improve the speed, maximum speed can improve the 1 - 6 times. The use of enhanced reader mode check box by the Turbo 6X Turbo 12X hand-chosen, when the card support, choose Turbo 12X is the fastest. However, little support for Turbo 12X cards, if the Turbo 12X does not support a reduced level of this method using Turbo 6x sim cards support most, if not support, clear the check mark, do not use enhanced reader. Note: Sometimes after using the enhanced communication reader unstable, easy to stop, then should reduce the level of enhanced communications to ensure the reader stability. Download |
| | #5 (permalink) | |
| Junior Member ![]() Join Date: Mar 2009
Member: 991008 Status: Offline Thanks: 10
| plz help Quote:
| The Following User Says Thank You to janibhutta For This Useful Post: |
| | #13 (permalink) |
| Junior Member Join Date: Oct 2010 Location: Philippines
Member: 1417625 Status: Offline Thanks: 0
| THANKS! is it possible to clone over a used sim? i mean, overwrite the contents of a sim? my purpose is to back up my sim from an old sim so i will not buy a new blank sim, no vendors sell blank sim in my country. thanks! |
| | #14 (permalink) | |
| Quote:
is it possible to clone over a used sim? i mean, overwrite the contents of a sim? my purpose is to back up my sim from an old sim so i will not buy a new blank sim, no vendors sell blank sim in my country. thanks! | |
| The Following User Says Thank You to iskalonication For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Free Samasung Tool FST v4.0.2 | AswanX | Trident/AGERE Platform | 23 | 08-17-2008 04:41 |
| S40 Tool v.2.0.0 by Mary Jane security key ? | munkeynuts | Programs Keys & H/W finger prints | 0 | 01-02-2003 06:05 |
| free S40 Tool v 1.0.1 | spako | NON Siemens Brand (ODM Phones) | 37 | 06-30-2002 00:16 |
