Why should i use Sim-emu 6.01 instead Sim-emu 4.10? Why should i use 256 eeprom card instead 64? I thank you very much for the answer and sorry for my bad english. Bye. Pierpippo. |
As all the new software versions, each one expect to be better than previous one. Read my page from the 5.00 version to the last 6.01 to see the enhances so you will be able to decide it. Regards |
And the card with 256k eeprom has more memory position? Wich is the benefit to use a 256k card? Tank you very much for the answer and for your works :) Bye Pierpippo. |
The 6.01 version has 10 positions for all the cards. The difference is the amount of ADN/SMS/FDN that you will have. Regards |
Some questions about "SIM Application" tab-menù. Hi SimEmu, The tab "allows to execute the SIM App" Ok but which is the benefit of this operation? Sorry if I can't see which is the utility....probably is there. Is possible to export any of original Sim App (important ones) into Sim Emu menù ? May be a new folder like "Operator App". Have You consider possibility to trasfer all configurator routines out the card in the present program and use this space for "Operator App"? It is only an idea... I don't know how many resources will take a command (something like an SMS I suppose) and how many space build-in configurator will leave. I don't Know also if build-in configurator is basic for simemu601's normal work. Regards (thank you for your work ! ! !) |
Using SIM-EMU, the "SIM App" is another way to Configure it, or to test a custom translation for example. The Configurator 1.0 uses the SIM-EMU application tool kit to make the configuration in a similar way the phone does it. Using original cards, is one way to navigate for all the menus without to pay any possible call or SMS. There is no way to read the SIM Application of the original cards. Regards |
New version 2.0 of the SIM-EMU 6.01 configurator program See details above. |
New version 2.0 of the SIM-EMU 6.01 configurator program Quote:
Sorry to be a pain Martin |
I',m sorry, but I have problems with my host site. Try with this link http://perso.wanadoo.es/djabif/SIM_E...1_CFG_v2.0.zip and insist until it works. If you can't download it, I can send you by email. Regards |
Thanks Quote:
Problems solved. My web site is working fully. Regards |
I have tryied simemu 4.10 and it works very well. The last simemu 6.01 every time doesn't work and the telefon say me that the card is not valid. Do you know why? tnx pierpippo. |
I suppose that you are not writting correctly the SIM-EMU 6.01 files. Which phone do you have ? Regards |
one little quastion whit which interface you read and write this card and if is any link about it:)! Thanx good people! |
The configurator uses Cardinal PlugIns for Phoenix and PC/SC interfaces. Regards |
