Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 03-16-2005, 14:27   #76 (permalink)
Member: 107545
Thanks Meter: 44
Dear SimEmu
I have your last SIM_EMU_6.01_CFG_v2.1.msi, but with some problems. Because in Nokia and Samsung X100 when i am selecting phone number from Sel.phone# then it is switching very well but in other sets is not switching to other number then i am going on other number after switch off/on, enter pin for other number and then number does work.
You are requested to please give me your nice opinion on this problem that how i can solve this problem i.e. how i can switched an other number through Sel.phone# instead of switch off/on.
An early attention is requested.
SATZONE
Old 03-16-2005, 18:54   #77 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 98
That is a problem of some mobile models. The "Sel Phone#" does not work because they don't implement the Refresh command the way as GSM rules dictate.
The only way to change is, as you say, resetting and entering a PIN of another position.
Regards
Old 03-20-2005, 00:25   #78 (permalink)
bad_signal's Avatar
Member: 107069
Thanks Meter: 31
under testing
but i wanna to no that if there is some tool for that prog
and i have some tool for that prog called dr.sim
it can explore the sim card
but it can't read the bad sim and damage card
can i have some sort of prog can read that bad or damage card
Old 03-22-2005, 11:04   #79 (permalink)
Member: 118366
Hi Simemu,
I have downloaded Sim-emu 6.01 v2.1.
I am using 'Infinity Usb Phoenix' with Silver Card.
I have already extracted the Ki with simscan.
But Im having some difficulty when using SimEmu software:
1. When I used my silver card in 'Infinity Usb Phoenix', SimEmu cannot detect my card "No Card Inserted"
2. I have inserted my ki & imsi in 'Configure' and 'write to card' but could not write "Inserted a GSM or SIM-EMU card"
3. When I try to 'write to disk' the msg popup "Load the Sim Emu flash & Eeprom file first"
4. Where should I load the flash & Eeprom?
Please help me. Im really confused. I have gone through all your forum. I have also read your 'help' but without success.
Regards,
Natasha.
Old 03-22-2005, 17:22   #80 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 98
If the Infinity USB Phoenix cannot be configured using a COMx port, the SIM-EMU Configurator cannot be used with this type of Phoenix (The Phoenix PlugIn requires a valid COMx port to communicate with the Phoenix). Read the Infinity USB Phoenix manual.
In this case, I recommend you to use the "First time configuration over an empty GreenCard2 / GreenCard /SilverCard" described in the "Help" tabsheet of SIM-EMU Configurator, but you will need to write EEPROM with the programmer software included with your Phoenix.
Regards
Old 03-23-2005, 03:35   #81 (permalink)
Member: 118366
Hi Simemu,
Thanks for your help.
Well, I have been able to copy my silver card using Simemu 6.01 v2.1 with 'Infinity usb Phoenix'.
Thanks for you and your team for the super software 'Simemu6.01 v2.1'
Regards,
Natasha
Old 05-23-2005, 13:37   #82 (permalink)
Member: 147414
Dear all,
Thank you all for the good knowledge i can find here!
Actually i am new here .. but i need to extract Ki and IMSI from my SIM Card i have.
I want to know the exact requirement needed for that and from where i can get it.
Per example, what is the Reader needed? Is there any special specification? There is a lot of softwares, Which one is more effective? I will be waiting for your reply on my mail: [email protected]
Thanx a lot ... Please i need your help!
Bregards, Sameh
Old 05-25-2005, 00:30   #83 (permalink)
Member: 146373
HI all!
Simemu, i have problem after programing simemu card. When I switch phone on I must enter pin. I tried x combination: 0000, 1111, 2222, 9999, 1234 and is not. Can you help me? What I doo wrong?
Old 05-26-2005, 08:24   #84 (permalink)
Member: 137168
Thanks Meter: 3
Use PUK 12345678 and then change your PIN...
Old 05-27-2005, 09:27   #85 (permalink)
Member: 146373
ThnX, I will try later.
Old 05-28-2005, 08:36   #86 (permalink)
Member: 146373
Wrong, PUK is not 12345678 and is not usual.
CAN SOMEBODY SEND ME FILES (Sim_emu_6.01_Fl.hex & Sim_emu_6.01_ep.hex) WITH PREPROGRAMED PIN & PUK, OR PUK only.
Thanks
Old 05-28-2005, 16:05   #87 (permalink)
simemu's Avatar
Member: 10582
Thanks Meter: 98
In my page www.simemu.cjb.net you will find the original SIM-EMU files with the default PIN's/PUK's as I describe in the page.
Regards
Old 05-31-2005, 16:56   #88 (permalink)
Member: 146373
Thnx simemu for all.
But I'm still without pin for sim_emu card. I programming FL and EP files with card writer 2.0. Should i program with IC Prog or else. I use mastera IV on 6 mhz. I fill the silver card without IMSI and KI's for my cards. I put on the card only files you tell me. Sholud I first put my IMSI and KI's and then program card. Your Sim_emu configurator 6.01 detect my sim_emu card as card 6.01, but i can't write on it because ask mee for pin1. How can i change im or enter the right pin. Your files comes with programed pin. If you can send me files on PM with PIN's please.
Thank you again
Old 05-31-2005, 20:04   #89 (permalink)
CH@IN's Avatar
Location: Getting it to work is easy... making it do the things you want is another thing.
Member: 9824
Thanks Meter: 79
Try it with icprog, maybe you didn't store anything into the Eprom section yet. Follow EXACTLY the instructions as given in the pages of SIM-EMU.
Old 06-02-2005, 15:58   #90 (permalink)
aasifnasim's Avatar
Member: 148720
Thanks Meter: 16
can someone give me idea wat i have to do for sim cloning;
hardware/software both
i have nokia phone and i have to carry two cell phone but i don want that
i want to make clone my two sim.... and use in a single cell phone to plz do help me out from this problem
i m capable to write down some programs in number of languages
Sim-Emu 6.01 Configurator v2.1 sonojee Nokia Multimedia 0 03-26-2009 19:32
problem Sim-Emu 6.01 Configurator v2.1 شاكر Sim Cloning and Scaning 3 05-16-2008 21:34
what shematic for Sim-Emu 6.01 Configurator v2.1 clinic*mobile Sim Cloning and Scaning 9 08-22-2005 06:38
New SIM-EMU 6.01 with Arabic menu language simemu Sim Cloning and Scaning 17 09-03-2003 22:08
New SIM-EMU 6.01 with Slovak menu language simemu Sim Cloning and Scaning 0 08-20-2003 17:15
Page generated in 0.39608 seconds with 9 queries
