Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 05-03-2015, 19:37   #1 (permalink)
Member: 2366601
is it possible to clone
is it possible to clone the latest sim cards on the market.I want to clone my sim for use in my tablet aswell and am wondering if its possible anf if it is what do i need to do to accomplish it
thanks
Old 05-08-2015, 15:26   #2 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
ORIGINAL POST FOUND HERE
So What Can You Do When You Clone SIM card ?
Well There are many things to do when you clone a SIM Card, You can secretly spy on the victims calls and data transfers, make him mobile bill go crazy, send messages and make calls from his number, All without touching the victims Cell Phone.
First A Little Knowledge Of SIM Hacking :-
Not every SIM Card is clone-able, There are two types of SIM Card :
COMP128v1: The most popular and clone-able version of SIM Cards, Distributed widely till 2004 in USA (2007 In ASIA Countries), Of the number of victim is older than 2004 in USA or 2007 in Asia, Chances are you can clone it pretty easily.
COMP128v2: The newer SIM's, Capable of better 3G Reception, Video Call Support, New and Secure firmware, Complex Design, Very ( I mean very fu*king very) Hard. If the SIM is bought after 2004, it is probably this version.
Things Required :-
1). Blank SIM Programmable Cards : CLICK HERE
2). A SIM Firmware Writer : CLICK HERE
Or You Can Also Make Your Own Sim Writer
Make your own SIM Writer : CLICK HERE
3). Software For Reading : Woron Scan :- CLICK HERE (MediaFire)
4). The Victim's SIM For 15 minutes to 30 Minutes !
Lets Begin The Work :
The main mission in cloning a SIM Card is to get KI and IMSI codes, these codes are the identifier of the SIM Card, and help you register your mobile to the network.
1). Plug in the SIM Reader, Install the software, get the vic's SIM.
2). Configure the Software as shown in the below pictures :
3). First Run The IMSI Search :
Note Down The IMSI Number !
When the results come, write them down. Then start the ICC Search :
Note This Value Down Too.
Write down the ICC Number too, Now run the KI Search, This may take some time :
After 45 Minutes, IF you don't Get the First Value, The Sim IS Un-cloneable !
Now remove the Vic's SIM And give it back to him.
4). Download SIM-EMU, A software to write settings on Blank SIM Card.
Now insert the blank SIM and wait for it to detect.
5). Run SIM-EMU and click the configure tab,
Enter the ALL the Info Gathered from the Woron Scan Process: IMSI, KI, ICC.
The Setup Menu
For the rest Info :
For ADN/SMS/FDN# (ADN= Abbreviated Dialing No. / SMS = No. of SMSes stored on SIM / FDN = Fixed Dialing No.) Enter: 140 / 10 / 4 OR if the Program has suggested values, let it remain as it is.
The Phone Number should be in International Format, EG: For India +91(the international code) 9999999999 (the number)
6). Let The Writing Begin, Select the Write To Disk button and Name the File: SuperSIM.HEX.
Wait For The Conformation, Then Select OK.
A write EEPROM file window will appear. Name the EEPROM file SuperSIM_EP.HEX and click the Save button.
Now You Have 2 Files, Ready to be Flashed.
7). Now We Flash the files on Blank SIM Card :
Install the card that came with the card writer, cause using any other software will fu*k up your card and your reader.
Our Card Readers Software was Infinity USB Unlimited, The interface can be changed in your software, but the functioning is the same.
Now Put the required files in the appropriate fields :
Flashing The Blank SIM.
8). Now run the writing task, Click on done when it has completed.
Congrats, You Have Cloned A SIM Card !
So here you have it, A Cloned SIM Card, Now when somebody calls the victim, Both of the mobiles will ring, same will happen in the case of SMS, But only one can pick up the call. Also don't do something big that will raise a red flag in Mobile Company. You are responsible for your own ****.
The Following User Says Thank You to BesfortShalaTec For This Useful Post:
Old 05-14-2015, 12:42   #3 (permalink)
Member: 2393835
Sonork: 100.1666700
awesome, but need much money for buy it. maybe i try this trick if i get some more of money
Old 06-06-2015, 11:26   #4 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
link.............................................. .................
Old 06-10-2015, 18:45   #5 (permalink)
Member: 2403068
Hey BesfortShalaTec, can I mail you my SIM, to clone it and send it back to me? What would be the price? Is the latest model.
Thanks.
Page generated in 0.15920 seconds with 8 queries
