10-15-2005, 03:49 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 190731 Status: Offline Thanks Meter: 0 | PUK code HELP!!! |
10-15-2005, 15:21 | #2 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Getting it to work is easy... making it do the things you want is another thing. Age: 22
Member: 9824 Status: Offline Thanks Meter: 79 | Every PUK code is individual for each sim. There is no default PUK code, neither a default PIN. You should have received the PIN and PUK when you purchased the card, you can ask the network provider to remind you the PUK, but they will need you to authenticate yourself (with ID-card) at their customer support. |
10-23-2005, 22:33 | #3 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 90106 Status: Offline Thanks Meter: 3 | Call up to CS @ +18003310500 and just ask them. They should be able to get it out for you. If you have Cing service, tell them that you originally had planned to use it on your account, and if you don't have service, tell them that you wanted to activate a PAYG line but forgot to do it. They should be able to get it for you. Another way for the PAYG route is to call +18885628662. That's the Cingular To Go line. ~Cheers~ |
06-21-2006, 18:59 | #5 (permalink) | |
Member: 9824 Status: Offline Thanks Meter: 79 | Quote:
Smart radio by grundig Code,Help ! Thanks. | chinesedemtp | CAR Electronics | 1 | 04-30-2008 17:17 |
Need PUK code and unlock code for NEC N343i | dougiedickson | NEC | 1 | 05-02-2006 21:02 |
Can i read Puk code/pin code via Sim Reader ? | the_frightener | GSM Programming & Reverse Engineering | 1 | 12-19-2004 18:32 |
help me some one i need puk code for my lg u8110 urgent | glittergirl69 | LG | 2 | 07-29-2004 13:06 |
pin code and puk code | gsm-lord | Hardware Repair Item Wanted | 1 | 11-30-2001 21:10 |
