07-30-2003, 10:35 | #31 (permalink) |
Junior Member Join Date: Feb 2003 Location: Kidapawan City (Ph) Age: 43
Member: 21151 Status: Offline Thanks Meter: 1 | Thanx [email protected] |
The Following User Says Thank You to rampage200ph For This Useful Post: |
10-27-2003, 15:18 | #35 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Minsk Russia
Member: 5569 Status: Offline Thanks Meter: 10 | pin-puk to simemu i want correct address for pin-puk code in sim and tell me by mail or ... BR own |
The Following User Says Thank You to Own For This Useful Post: |
05-03-2004, 13:21 | #36 (permalink) |
Junior Member Join Date: May 2004 Age: 43
Member: 64469 Status: Offline Thanks Meter: 2 | @Angelex you added ICCID in simemu 6.01 ? How can I do it? Maybe the search of network find and lose connection any second because I din't set ICCID? I use Siemens C55. I can read the string "Vodafone IT" on my cellular display but the reception goes high and low to zero and it isn't able to lock my privider with good signal, so I'm not able to call or receive calls. Thank for any ideas you can tell me |
The Following User Says Thank You to stealthanger For This Useful Post: |
05-03-2004, 13:37 | #37 (permalink) |
Member: 64469 Status: Offline Thanks Meter: 2 | @Angelex How can I write ICCID in simemu? Maybe it's because I didn't wrote it that simemu 6.01 isn't able to connect to my network? I see the "Vodafone IT" operator name on my cellular phone but I can't find a fix signal on the network, so I'm not able to call or receive calls!! Tnx for help |
05-04-2004, 21:08 | #38 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 99 | You can write a unique ICC ID for all the positions using the new Configurator program. Try to write the files again, because I think that is your problem. Regards |
The Following User Says Thank You to simemu For This Useful Post: |
05-06-2004, 20:48 | #39 (permalink) |
No Life Poster Join Date: May 2004 Location: Tours FRANCE
Member: 64391 Status: Offline Thanks Meter: 1,261 | A stupid question, I am totally new in this topic : which hardware is needed to use sim emu ? Thanks |
The Following User Says Thank You to jfl For This Useful Post: |
05-11-2004, 17:51 | #41 (permalink) |
Freak Poster Join Date: May 2002 Location: Roaming
Member: 11950 Status: Offline Thanks Meter: 4 | can someone send me Sim EMU 6.01 on [email protected], I cannot download, my computer has restrictions, on my pc from the ISP |
The Following User Says Thank You to netzon10 For This Useful Post: |
05-11-2004, 20:41 | #42 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | @jfl and @eemz1507 A GreenCard 2 to store the SIM-EMU software, a TE-21 Pic programmer to write the flash in the GreenCard and a Phoenix (TE-21) to extract Ki and to program the external EEPROM of the GreenCard. @netzon10 I will send you the software. Regards |
05-13-2004, 21:14 | #43 (permalink) |
Member: 64391 Status: Offline Thanks Meter: 1,261 | Simemu thanks ! and if I want only read my SIM (Pin's and PUK's codes mainly) is there a more simple way ? Recently I have entered 3 wrong pin codes, I had to ask my provider the PUK code, it costed 7€. And I have lost this PUK code. At home we have several phone and we often exchange SIM, we have a big risk to make a mistake So next time I will be obliged to pay once more in case of mistake THX & BR |
05-14-2004, 17:12 | #44 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | There is no way to read PIN's and PUK's of a SIM. The next time, try to save the PUK's in a safety place. Regards |
05-17-2004, 16:05 | #45 (permalink) |
Junior Member Join Date: May 2004 Age: 69
Member: 65875 Status: Offline Thanks Meter: 2 | @ simemu Got two problems, simemu 6.01 (silver or green, same results) nokia7110 or 6150 1) (small problem) switching between numbers (with reset) sometimes change numbers memory from "phone" to "card", 2) with italian simcards TIM64K the message sent from operator if I receive a call and the phone is switched off is somehow different from the same message received from an 8K SIM. Results:with the emulated 8k all OK, with the emlated 64K I receive a message without the calling number, with an error "message not visible". I'm the first one to notice this problem? If you want I can try to get this message to see if there are strange chars inside... thanks anyway for your wonderful SW G |
The Following User Says Thank You to cyberzar For This Useful Post: |
Revision SIM-EMU 6.02 (AVAILABLE) | simemu | Sim Cloning and Scaning | 101 | 07-22-2023 11:48 |
A question about SIM-EMU 6.01!!! | hazzard | Sim Cloning and Scaning | 4 | 10-09-2021 23:37 |
New SIM-EMU 6.01 with Arabic menu language | simemu | Sim Cloning and Scaning | 17 | 09-03-2003 22:08 |
New SIM-EMU 6.01 with Slovak menu language | simemu | Sim Cloning and Scaning | 0 | 08-20-2003 17:15 |
New revision SIM-EMU 4.01 | simemu | Sim Cloning and Scaning | 54 | 06-20-2002 06:49 |
