10-31-2004, 00:11 | #76 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Vietnam Age: 49
Member: 84390 Status: Offline Thanks Meter: 3 | I'm new in SIM cloning forum, I've download SIM_EMU 6.01configurator v2.1 and setup in PC. But I don't know how it work. I've a siemens SL45, and I use a cable to connect to PC (phone is on), then I run SIM_EMU but it always inform "No card inserted"! I wonder that: - if the program can configurate a SIM using a card reader or can use phone? - I can use my current SIM or have to use a blank SIM? |
The Following User Says Thank You to sl45vietnam For This Useful Post: |
10-31-2004, 18:07 | #78 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 98 | You cannot connect the phone to use the Configurator. You must connect the Simcard to PC using a Phoenix (TE-21). You can use an original SImcard, but only to read some information, like phonebook, SMS, IMSI and other info. To use SIM-EMU you need a GreenCard 2 or GreenCard or SilverCard. Read my official page www.simemu.cjb.net for more info. Regards |
The Following User Says Thank You to simemu For This Useful Post: |
11-15-2004, 21:51 | #79 (permalink) |
Junior Member Join Date: Nov 2004 Age: 45
Member: 91897 Status: Offline Thanks Meter: 4 | USB readers SimEmu, Will USB cards reader with SIM-EMU? such as this one http://www.smart-cardsys.com/products/SCR301USB.htm Other wise, where can I get that phoenix TE-21 from? rgds, |
The Following User Says Thank You to b3herys For This Useful Post: |
11-17-2004, 16:50 | #82 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 98 | I have tested the new SIM-EMU Configurator v2.1 with a USB reader using PC/SC interface with no problem. Regards Last edited by simemu; 11-17-2004 at 19:46. |
11-17-2004, 19:49 | #83 (permalink) |
Member: 91897 Status: Offline Thanks Meter: 4 | I have Sim Emulator 6.01 configurator ver 2.1 installed. And USB READER SCR301 connected with GSM sim card in it. Still it shows no cards inserted. How to setup sim emulator to read the USB reader? please more details. thk's |
11-18-2004, 18:20 | #85 (permalink) |
Member: 84390 Status: Offline Thanks Meter: 3 | I hope Simemu can build another pro can use my phone like a card reader! when??? |
11-21-2004, 19:59 | #86 (permalink) |
Member: 92705 Status: Offline Thanks Meter: 1 | problems: illegal aspects, active numbers, etc hi, how to prevent ppl scanning ur sim and making calls without ur consent? is there any way to prevent this? one can still sims and make illegal calls... after all, is it legal to clone sims??? is it technically possible that different operators support active various cloned numbers? i mean that can i hav active income calls for several numbers on a single cloned sim? another questions. how produces chippest silver/greencards and located closest to russian region??? thanxxxxxx.... |
The Following User Says Thank You to rimauba For This Useful Post: |
11-22-2004, 23:01 | #87 (permalink) |
Freak Poster Join Date: May 1999 Location: Bulgaria
Member: 38 Status: Offline Sonork: 92879:sid Thanks Meter: 82 | PIN code not blocking after 3 wrong attempts ??? Hi SimEmu ! I've tested SIM_EMU_FL_6.01_ENG.hex on silver card on several phones: nokia 6510, 6230, siemens ME45, C62, Motorola D520 - on all these models after entering 3 times wrong PIN - it doesn't blocked, but I had still chance to enter it ? (the counter of left attempts stays 3). On Panasonic A100 - the "left attempt" counter decreases and PIN blocked and asks for entering PUK code, but when powered phone off and on again it asks for a PIN again. I think the counter in the SIM card doesn't decreases ?! Everything else is working just fine for me. BR, [email protected] |
The Following User Says Thank You to sidcho For This Useful Post: |
11-23-2004, 00:20 | #88 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 98 | @sidcho Don't change the configuration bits when programming the flash file. Leave the configuration bits as they come in the SIM-EMU zip file. Regards |
12-04-2004, 16:01 | #89 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | Just one .... question...I program two pc's off Green Card but can't change line names on any of two cards I programed and don't have any idea why. Maybe You can help me? Thank's in advice |
The Following User Says Thank You to hallo For This Useful Post: |
Revision SIM-EMU 6.02 (AVAILABLE) | simemu | Sim Cloning and Scaning | 101 | 07-22-2023 11:48 |
A question about SIM-EMU 6.01!!! | hazzard | Sim Cloning and Scaning | 4 | 10-09-2021 23:37 |
New SIM-EMU 6.01 with Arabic menu language | simemu | Sim Cloning and Scaning | 17 | 09-03-2003 22:08 |
New SIM-EMU 6.01 with Slovak menu language | simemu | Sim Cloning and Scaning | 0 | 08-20-2003 17:15 |
New revision SIM-EMU 4.01 | simemu | Sim Cloning and Scaning | 54 | 06-20-2002 06:49 |
