Revision SIM-EMU 6.02 (AVAILABLE) It is possible to download exclusively from the following page: http://simemu.cjb.net News Added compatibility for iPhone 3G of Movistar Spain Although the iPhone 2G is full compatible with SIM-EMU 6.01, the Movistar Spain iPhone 3G (and perhaps others providers), check the existence of an unavailable record in SIM-EMU . ------------------------------------------------------------------------------------------ Notes For this revision, it is necessary to reprogram the Flash and the external EEPROM, and introduce again all our phone numbers data by using the phone SIM-EMU menu or through the new SIM_EMU_6.02_CFG.exe v2.2 configurator program. Regards |
Great Work - Thank You SIMEMU |
Is this ver can run even on iphone 3g locked on AT&T |
thread sticky ;) I will try this version ;) |
Please advise what this software is used to take advantage of, and will it work for uk networks. Thanking you indeed. |
1 Attachment(s) While trying to use 6.02 configurator, this error appears on opening eeprom file SIM_EMU_EP_6.02.hex: |
same problem here, can anyone explain about it? thanks :) |
plzzz help same problem........ |
help...... same problem.. |
@all Today I have repaired the configurator. Download it again and try it. Sorry for the incovenience. Best regards |
Ok, now work!!! thanks |
here comes another error :( this happens when i click on "write to disk". i just opened the files and removed all entries except the 0 number. http://img367.imageshack.us/img367/2...memucb6.th.jpg |
@atomikramp To solve this problem, before "write to disk", enter a 0 in the Group ID1 field of the deleted positions. I will fix it, sorry. |
@all Second fix is done. Download it again and try it. Sorry for the incovenience. Best regards |
@simemu you are the best thnx a lot :) |
