Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2008
Member: 675681 Status: Offline Thanks: 0
| SIM Editor v5.11 not working Got a little blue/green USB SIM Editor from 7dayshop.com. Installed the software from the CD Rom and inserted my SIM. When I select Connect I get the message 'The system cannot be connected to the card reader! Ensure the card reader is connected to RS-232 and SIM card is plugged into card reader correctly'. Not sure why there's a ref to RS-232 when it's a USB device, but some of the messages and help are in very strange English! The SIM is inserted the correct way - the only way the pins inside could be in full contact with the SIM. Any ideas what the problem could be? |
| | #2 (permalink) |
| Junior Member Join Date: Nov 2008
Member: 912723 Status: Offline Thanks: 0
| Hi mitchrich, I have exactly the same problem as you do! Did you ever find the answer? I have reposted the query in case anyone can resolve it. As you say - why mention rs 232 with this usb device. Best wishes, Roger ... |
| | #3 (permalink) |
| Junior Member Join Date: Dec 2008
Member: 934087 Status: Offline Thanks: 0
| I too had the same problem. You need to search thru the little installation disc and install the USB drivers from the disc. Until this is done, it wont read. Good luck |
| | #4 (permalink) |
| Junior Member Join Date: Mar 2009
Member: 998518 Status: Offline Thanks: 0
| Same problem for me. A former version of the same program and an old usb device worked well on WIN98. So I tried to install the old device and the old software on WINXP but got the same error message: "The system could not be connected to card reader! Please ensure card reader is connected to RS-232 and SIM card is pluged into card reader correctly" In the cd I found "USB-Driver Installer.exe". I thought it connected usb to RS-232 but nothing than the same error message. I'll try it on my old WIN98. If you want you can write to protopapaatemaildotit |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 179960 Status: Offline Thanks: 8
| Dear, How R U Today? Dont Worry,Dont Connect Ur Reader Before Main & Driver Installed.If Failed Download From Any Respective Server,Such MagicSim USB 2.0 Driver.It Uses Profillic Or A4Mantec, Somthing Like This Kind Of Drivers.Sometime Previously Installed Other Serial Reader Driver Can Be Interfare,So Uninstall All Of Them. Keep I Touch. |
| | #6 (permalink) |
| Junior Member Join Date: Jun 2009
Member: 1045408 Status: Offline Thanks: 0
| i had the same problem, then i installed the below driver: http://www.prolific.com.tw/support/f...aller_1025.zip First install it said it was uninstalled, then second install it seemed to install and the SIM Editor v5.11 seemed to connect to the SIM card after that. |
| | #7 (permalink) |
| Hi, thanks for your replies to my threat. Unfortunately I still have not got this sim reader to work, nomatter which driver I install. Any other software / drivers out there that might work with XP? Thanks. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SIM Editor v5.11 not working | bytimber | Sim Cloning and Scaning | 0 | 11-29-2008 17:00 |
| 3.11 not working with me | flash | NSPRO | 16 | 02-15-2006 06:41 |
| cruiser V 8.11 not working on cid49 | Jamal | Cruiser Suite | 7 | 02-02-2006 16:26 |
| Log reader v5.0 not working for new firmware | hamidtele | Panasonic | 3 | 09-12-2003 15:59 |
| Need MT50 phone code unloker. Ksie v5.1 not worked. any solution ?? | sp-lox | E-Gold Based Phones | 3 | 06-07-2003 08:40 |
