Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 06-08-2003, 23:43   #1 (permalink)
Member: 30917
sim_scan hardware
I saw people having problems building(using) simscan hardware. I built it yesterday and first it didn't work until i powered the board from an external power supply (actually I hate com powered stuff, and found that normal) Then i decided to optimize schematics and remove the whole bunch of no longer needed transistors but the thing didn't work anymore. I got a lot of "Card don't send Answer To Reset" and "Bad data in Answer To Reset" messages. Finally I found it was a timing problem and you can't make it work without the 470uF capacitor at DTR & RTS lines, discharged exactly by a 10 kOhm resistor. Everything else works just fine. I tried some other ICs like 74HC14 (one from TI worked, and one from Philips didn't work).
Also make sure the oscillator is working at the right frequency. I used 6.1440 MHz. Hope this help someone. Good luck! :-)
Old 06-09-2003, 00:29   #2 (permalink)
Member: 29348
Please Tester_v can you give me the schematics?
Old 06-09-2003, 02:04   #3 (permalink)
Member: 29785
yes, u r right. i also power up with external battery.
but how about the dejan's programmer that write the PIC? have u build it? i fail to run it.
tq
Old 06-09-2003, 19:20   #4 (permalink)
Alf
Alf's Avatar
Member: 6156
Perhaps I should stick a simple phoenix (for KI extraction and external eeprom programming) and a JDM (for programming PIC) schematics...
Old 06-09-2003, 22:12   #5 (permalink)
Member: 26729
images and schematics:
http://www.simprog.narod.ru/
Old 06-09-2003, 22:21   #6 (permalink)
Alf
Alf's Avatar
Member: 6156
Thanks for saving me trouble
Old 06-10-2003, 01:51   #7 (permalink)
Member: 29785
@ all
is there any replacement for IC MAX232? i can't buy it in my country.
i find very hard to get the schematic that no need to use "MAX232" IC.
tq...
Old 07-18-2003, 01:31   #8 (permalink)
Member: 26322
here ,,,,http://carddiy.welcometextiles.com/S...nix%20sch2.gif
it is a phoenxi schematic no MAX232 in it, it work correctly.
Old 07-18-2003, 03:25   #9 (permalink)
Member: 29785
still have someone study old message ya...
tq very much...
Sim_scan ok... tax555 Sim Cloning and Scaning 6 03-26-2002 22:01
Sim_scan 1.21 problems tax555 Sim Cloning and Scaning 2 03-12-2002 20:34
sim_scan and JDM programmer? ginomi Sim Cloning and Scaning 6 03-12-2002 06:29
Sim_Scan tropicalstorm Sim Cloning and Scaning 2 03-08-2002 08:06
I need sim_scan 1.21 Anatoly Hardware Equipments for GSM 2 01-18-2002 13:14
Page generated in 0.33359 seconds with 11 queries
