11-10-2002, 03:52 | #1 (permalink) |
Freak Poster Join Date: Sep 2002 Age: 44
Member: 15414 Status: Offline Thanks Meter: 1 | No PIN for your sim8x It may work like this, We choose one position that shouldt have pin, or to make that more simply the position 1 is configured and have no pin. And now everione is asking how to acess other configure cards, simply using the option "sel number". The bad thing when power on the phone, it starts with the same position. And in some phones some times the sel phone option don't work fine. nothing is perfect |
11-10-2002, 15:57 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 98 | See post http://forum.gsmhosting.com/vbb/show...threadid=61691 Another very important problem is the security, if you lost the SIM, anybody can obtains all yours KI's and your operator probably will send you a new SIM with COMP-V2. You decide.... Regards |
01-22-2003, 07:45 | #3 (permalink) |
Freak Poster Join Date: May 2002 Location: Thailand Age: 54
Member: 12438 Status: Offline Thanks Meter: 0 | @simemu i edit SIM-EMU 5.00 ENG hex file follow ur instruction. when i turn on mobile it enter pos#1 as default , but when i use STK menu to select another pos and select back to pos#1 again it don't work , it still stay at last pos. i can change to another pos except pos#1. can u help me to fix this problem, i use nokia 3310. Best Regards. JSompis |
No Software Update is required for your device ((Solution here)) | ::.::RAMJAN::.:: | BlackBerry (RIM) | 212 | 07-12-2015 15:44 |
Cable Compatible for 26 Pin To 26 Pin For Spiderman Box | IPMART | ipmart WebShop | 0 | 03-23-2009 08:10 |
Cable Compatible For 26 Pin To 26 Pin For Infinity Box Finder Adapter | IPMART | ipmart WebShop | 0 | 10-20-2008 05:00 |
check your mail. I sent but no reply for login details !! | preshaust | Redbox | 1 | 08-04-2006 20:37 |
V290 Pin out ?? Thanks for your | leo12345 | Motorola ODM | 0 | 02-13-2005 08:54 |
