07-07-2002, 10:21 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: ME
Member: 8400 Status: Offline Thanks Meter: 0 | simscan problem i have a big problem when i run the newest simscan anf try to get ki , if the operation is aborted and the computer halts for some reason like all kind of power off reasons the simscan doesnt saves a temporary file . i dont have an ups ... can anyone tell how to make simscan save the work more frequently ??? regards , NNN |
07-10-2002, 06:37 | #3 (permalink) |
Junior Member Join Date: Jun 2002 Age: 52
Member: 13338 Status: Offline Thanks Meter: 0 | hi may be your sim scan soft not good try to download agen from http://users.net.yu/~dejan/ and make shore the sim scan in the c:\sim scan try ????????? Last edited by cammander71; 07-10-2002 at 06:40. |
07-10-2002, 19:21 | #5 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 49
Member: 6156 Status: Offline Thanks Meter: 3 | sim scan will record it's status every 200 (hex) "attacks". If the file is not written to your hard disk then make sure you have no disk caching software (smartdrive, windows) running Everytime you exit the program (escape or any other key) the status is saved. This is how I handle the problem. Anyway... does your power go away that often? It takes me 3 hours to scan the KI of a card with the new sim_scan. If I press escape once or twice per hour and resume the process it won't be a total loss... |
07-10-2002, 20:23 | #6 (permalink) |
Member: 8400 Status: Offline Thanks Meter: 0 | yep you are right its saved every time i exit . but in my office i have many power downs and computer downs immediatly , and without my interupt and without savings ;-( regards , NNN |
07-10-2002, 20:28 | #7 (permalink) |
Junior Member Join Date: Jul 2002 Location: Italy
Member: 13418 Status: Offline Thanks Meter: 0 | Excuse me.. I need some information: 1) I not use sim scan because this program sais: "Fatal Error: Card don't send Answer To Reset !" There are some settings that don't I know? 2)I use a smartmouse: I need dejan hardware? Thank you |
07-11-2002, 01:42 | #8 (permalink) |
Member: 8400 Status: Offline Thanks Meter: 0 | nope . you dont need dejan harsware . any phoenix programmer will do . the most important is that you have to run the program in windows 9x or under dos with 32 extender . also make sure that your hardware is connected to the serial port that you are using . regards , NNN |
07-12-2002, 23:25 | #10 (permalink) |
Junior Member Join Date: May 2002 Location: Manila, Philippines Age: 45
Member: 12072 Status: Offline Thanks Meter: 0 | My Share of the Problem I bought the SIM master from U-cables. I am trying to clone a SIM using Dejan's SIM-Scan. I tried using 9600 bps but I always get this errors: Send data error card don't send answer to reset card not send correct answer to command The SIM card that I am trying to clone is perfectly normal. Help is needed and any comments are greatly appreciated |
07-14-2002, 22:36 | #14 (permalink) |
Member: 12072 Status: Offline Thanks Meter: 0 | Are there problems with AMDs? Hmm... Hmmm... I guess it doesn't run on win XP right? The port is correct. I tried getting the IMSI and KI from an older SIM card and I didn't encounter any problems. Are new SIMs supported by Sim Scan? What are other softwares that can be used to extract the IMSI and KI? Last edited by cassidy; 07-14-2002 at 22:39. |
07-14-2002, 23:57 | #15 (permalink) |
Junior Member Join Date: Jul 2002 Location: Denmark
Member: 13628 Status: Offline Thanks Meter: 0 | Hi On my 450KII AMD - Win98 SimScan 1.33 doesn´t work, but when I connect my Phoenix to my Laptop, a 450PII it works almost perfekt. Only problem is that i get som com-errors every 30min. Then i just loads the tempfile an restarts. So it looks like SimScan doesn´t run on AMD-proccessors ? Regards SIMcloner |
Simscan problem | acaaca | Sim Cloning and Scaning | 4 | 11-27-2006 11:26 |
simscan F5/F3 problem | foxlfoda | Sim Cloning and Scaning | 1 | 10-16-2002 22:29 |
Problem with simscan | matrix1233 | Sim Cloning and Scaning | 0 | 06-14-2002 19:19 |
Problem When Running Simscan | unlockgod | Sim Cloning and Scaning | 4 | 03-30-2002 17:18 |
Problems w simscan | ferroxcube | Motorola Old Legacy (EMMI) | 2 | 07-13-2000 11:28 |
