Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Sim Cloning and Scaning
Old 06-23-2003, 23:06   #1 (permalink)
Member: 9056
what is this ERROR help me please
hmmm i have a OTE sim card greeks what can i do if is comp128v2 algorithm Simscan is showing this error why?
Old 06-23-2003, 23:21   #2 (permalink)
Member: 30230
Thanks Meter: 3
Is it comp128v2? If it is, you cannot do anything.
Did you try "no strong Ki"?
Old 06-23-2003, 23:27   #3 (permalink)
Member: 32044
ý think impossible found ki
Old 06-23-2003, 23:28   #4 (permalink)
Member: 32044
are you try to cardical
Old 06-24-2003, 00:55   #5 (permalink)
Member: 9056
yep the same error if i uncheck the a38 limit the programs is giving this message (00) (00) (00) (00) (00) (00) (00) (00) (00)
Old 06-24-2003, 07:42   #6 (permalink)
martina's Avatar
Member: 31073
Hi, sorry, someone could explane to me to what is serves "Strong ki" above all but also the other checkbox?
Thank you!
Old 06-24-2003, 08:10   #7 (permalink)
Member: 30230
Thanks Meter: 3
I don't know how "strong Ki" functioning, but you should use that option ONLY if you cannot find Ki with regular metod.
If your sim is comp128v2 then you cannot find Ki, even with "strong Ki".
SimScan2.00 is the best (and fastest) software for finding Ki, as far as I know, so your shouldn't use different software.
Old 06-24-2003, 21:46   #8 (permalink)
Member: 16493
Thanks Meter: 3
try cardinal to find ki on that card... may be it can work?
Old 06-24-2003, 23:17   #9 (permalink)
Member: 30230
Thanks Meter: 3
Old 06-24-2003, 23:30   #10 (permalink)
Member: 30230
Thanks Meter: 3
JUST READ MANUAL
Why to try cardinal? SimScan working with his SIM, but cannot find Ki. If SimScan cannot find Ki, then Cardinal also will not find Ki (because SimScan have better algoritm for cracking Ki).
But, in that picture, strong Ki option is selected. If that Ki isn't strong Ki, then this option MUST be unselected, or SimScan will not find anything (and will show that message, like on picture)!
I'm wonder why people do not read manual (sim_scan.txt) before use SimScan? In manual you can read this:
If you are not sure that your SIM uses "Strong Ki", try first to
find Ki in normal mode. If first pair of Ki are not found after
60000 cipher text, press "cancel" to exit process, select "Strong Ki" mode
and run it again!. If that gives no result then your SIM card is NOT
COMP128v1.
So, there is no problem on this picture. SimScan did exactly what it should.
People, just read manual before!
Old 06-26-2003, 00:57   #11 (permalink)
Member: 9056
@pisac
i tryed with stronk ki and without and NO SUCCES any help?
Old 06-26-2003, 15:43   #12 (permalink)
Member: 30230
Thanks Meter: 3
COMP128v1.
please help me,What is this error in DreamBox after updating firmware? pordel DreamBox 36 12-24-2009 14:54
what is this problem?????? help me .... chamin Cruiser Suite 10 03-06-2008 04:29
What is my problem? Help me please!! SAPI MT-BOX 1 07-31-2007 22:34
Page generated in 0.17386 seconds with 9 queries
