Ask for help, DNS normal, the network is normal, the same error, 3 days, has not been Connecting... Can't connect with the server !!! (error:8000) Ask for help, DNS normal, the network is normal, the same error, 3 days, has not been able to use |
Yes i try use vpn but same |
Some users say that they solved using VPN...but we know that is not best solution we will need do changes in all client sw, coz seems from china, port used in sw has been bloqued. as soon as is done, we will annonce update. after many tests we know what is cause of problem... From china no possible use port of comunication. we will make changes and inform all users. Hope you understand that problem is not from our side. thanks for understanding |
sir you need know i already try use vpn but still can't connect server. so problem with your server internet connection Plz quick fix it |
[04-05-2017 18:16:34] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [04-05-2017 18:20:58] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... Reading info... MEID : IMEI : 867600025708164 IMEI2 : 867600025708164 SN : Y9K0215806001005 BSN : 022TQV1583003745 BT : 04:02:1F:83:8E:18 WIFI : 04:02:1F:83:84:B7 VENDOR : cmccchannel COUNTRY : cn Finished. [04-05-2017 18:21:40] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... IMEI : 867600025708164 SN : Y9K0215806001005 Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [04-05-2017 18:22:40] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [04-05-2017 18:24:03] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [04-05-2017 18:25:12] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:25:39] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:27:47] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:28:26] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:30:06] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:31:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:44:14] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:44:45] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:45:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:46:34] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:48:09] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:48:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:53:03] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:56:24] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 18:58:41] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:00:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:02:02] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:03:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:39] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:40] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:40] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:40] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:46] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:48] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:48] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:48] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:08:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:19] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:20] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:09:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:34] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:35] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:35] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:35] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:35] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:35] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:36] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:36] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:36] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:36] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:36] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:37] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:37] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:37] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:12:37] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:15:49] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:15:50] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:15:50] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:15:50] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:15:50] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:15:53] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [04-05-2017 19:15:57] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [04-05-2017 19:17:05] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [04-05-2017 19:20:00] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:20:01] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:20:01] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:20:01] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:20:02] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:20:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:20:52] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:21:39] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:21:39] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:22:01] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:23:00] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:23:41] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:24:10] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:24:39] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:28:00] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:28:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:29:02] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:29:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:30:18] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:30:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:43:39] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:45:59] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:46:44] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:51:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:52:35] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [04-05-2017 19:53:53] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:54:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:55:33] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:56:34] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:56:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:57:18] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:58:00] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:58:33] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 19:59:07] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:00:10] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:00:38] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:01:07] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:01:41] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:02:14] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:03:37] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:04:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:05:18] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:05:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:06:17] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:21:19] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:21:40] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:22:28] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:22:51] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:23:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:30:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:32:40] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [04-05-2017 20:33:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:34:32] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:35:02] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:35:32] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:36:01] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:38:36] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:40:24] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:41:02] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:41:43] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:42:13] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:47:02] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:47:25] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:48:55] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:51:08] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:51:34] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:53:07] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:53:38] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:54:14] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:54:37] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:55:52] Connecting... Connected to server Ok Server timeout !!! (error:8001) [04-05-2017 20:57:06] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:58:05] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 20:58:38] Connecting... Connected to server Ok Server timeout !!! (error:8001) [04-05-2017 21:00:03] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:03] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:19] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:20] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:20] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:21] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:22] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:01:23] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:02:30] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:03:46] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:06:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:23:00] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:29:43] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:31:13] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:32:50] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:32:56] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:32:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:32:57] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:32:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:32:58] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:33:28] Connecting... Can't connect with the server !!! (error:8000) [04-05-2017 21:49:38] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:26:16] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:26:43] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:27:34] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:27:57] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:28:49] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:30:36] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 09:37:39] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [05-05-2017 09:37:44] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [05-05-2017 09:37:49] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [05-05-2017 09:37:53] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [05-05-2017 11:08:41] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [05-05-2017 11:27:20] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Finished. [05-05-2017 11:27:59] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Finished. [05-05-2017 11:28:24] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:28:54] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:29:39] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:30:15] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:31:19] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:32:20] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:34:32] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:35:53] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:36:15] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:36:46] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:37:16] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:37:42] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:42:02] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:42:04] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 11:42:26] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 12:32:09] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 13:15:17] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 13:33:48] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 14:14:33] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 14:32:23] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 17:45:22] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 17:48:50] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 17:49:12] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 17:53:36] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 18:10:37] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 18:27:29] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 18:30:17] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 18:31:41] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 18:40:08] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 19:05:41] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 19:06:06] Connecting... Connected to server Ok Checking GBKey... GBKey error !!! (error:8008) [05-05-2017 19:06:09] Connecting... Connected to server Ok Checking GBKey... GBKey error !!! (error:8008) [05-05-2017 19:07:00] Connecting... Connected to server Ok Checking GBKey... GBKey error !!! (error:8008) [05-05-2017 19:07:13] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [05-05-2017 19:07:55] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... Reading info... MEID : IMEI : 867600025708164 IMEI2 : 867600025708164 SN : Y9K0215806001005 BSN : 022TQV1583003745 BT : 04:02:1F:83:8E:18 WIFI : 04:02:1F:83:84:B7 VENDOR : cmccchannel COUNTRY : cn Finished. [05-05-2017 19:08:30] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [05-05-2017 19:09:13] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [05-05-2017 19:09:55] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [05-05-2017 19:10:32] GBKey Huawei Pack4 1.32 Detecting... Detected : (HiSilicon) Android Adapter PCUI (COM30) Reading Info... Connecting... Can't connect with the server !!! (error:8000) Repair Failed !!! Finished. [05-05-2017 19:11:34] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 19:13:34] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 19:33:13] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 19:49:39] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 19:57:02] Connecting... Can't connect with the server !!! (error:8000) [05-05-2017 20:00:28] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 08:30:20] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 08:30:23] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [06-05-2017 08:30:26] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [06-05-2017 08:43:16] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [06-05-2017 09:01:11] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 09:28:10] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 09:29:51] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 09:31:13] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 09:32:23] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 09:35:35] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 09:36:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 10:24:59] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 10:34:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 17:53:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:16:21] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:18:01] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:37:40] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:38:05] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:38:43] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:39:57] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 18:44:15] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 19:37:57] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 19:50:34] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 19:59:18] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 20:04:04] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 20:06:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 20:17:13] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 20:53:57] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 20:54:28] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 20:55:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:07:14] Connecting... Connected to server Ok Checking GBKey... GBKey error !!! (error:8008) [06-05-2017 21:24:12] Connecting... Connected to server Ok Checking GBKey... GBKey error !!! (error:8008) [06-05-2017 21:24:14] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:15] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:15] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:18] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:18] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:18] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:33] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:33] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:33] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:33] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:33] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:34] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:34] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:34] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:34] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:34] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:35] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:35] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:35] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:35] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:36] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:36] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:36] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:36] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:39] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:39] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:39] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:39] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:39] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:40] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:57] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:58] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:58] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:58] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:24:58] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:51] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:53] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:54] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:54] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:55] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:55] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:25:55] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:00] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:01] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:01] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:01] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:02] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:02] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:02] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:02] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:03] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:15] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:16] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:17] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:28] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:29] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:29] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:30] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:31] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:26:32] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:36] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:37] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 21:50:38] Connecting... Can't connect with the server !!! (error:8000) [06-05-2017 22:13:58] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 08:43:45] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 08:44:08] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 08:44:55] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 08:57:15] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 09:04:19] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 09:24:07] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 10:57:48] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 12:01:19] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 12:32:04] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 12:44:07] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [07-05-2017 12:44:11] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [07-05-2017 12:45:29] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 12:45:52] Connecting... Can't connect with the server !!! (error:8000) |
look [07-05-2017 12:44:07] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [07-05-2017 12:44:11] Connecting... Connected to server Ok Checking GBKey... GBKey Ok Requesting Info... =============================== GBKEY S/N : 00000E62 Credits left : 20 1 Year License Pack4: ACTIVATED Valid Until : 2017-09-24 [07-05-2017 12:45:29] Connecting... Can't connect with the server !!! (error:8000) [07-05-2017 12:45:52] Connecting... Can't connect with the server !!! (error:8000) why??? |
Problem Solved ..Was only happening with users connecting from china Special Tanks to @ystxcll , for spend with us his time and let us use his PC and for being a profesional user. No need to explain him nothing, Just ask him to do someting and he do ;) Is Pleasue to get such users on skype !!! Happy Unlocking to our Chinese Users Br |
