01-14-2014, 15:56 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | HI for Black reader from GPG use FEITIAN Drivers for Red Reader use CCID... if you use own reader, use Scard reader that support Top cards (Gemalto) here you can get drivers : Index of /updates/drivers/scard reader Install manually if necessary from Device Manager Br |
01-14-2014, 17:03 | #6 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
you can always contact with us (products supporters) on skype to help you remotly get teamviewer ready Br | |
01-29-2014, 12:37 | #10 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | drivers are the correct ones, as you said it worked for you in win XP. win 7 x64 do install manually and you will will get token holder, token device and scard will stay with yellow ! symbol, but this will not affect...it will work if doing this still can not use, so check your PC, or change OS to win 7 x86 Br |
