08-30-2014, 03:09 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Vodafone 985n (Vodafone Smart 4 Power) Unlocked ..Beta Ver. Code: GBKey 1.70 Beta Insert USB Cable... Detected : PreLoader USB VCOM Port (COM15) IMEI : 3520930615xxxxx Reading Configuration... Reading security info... Connecting... Connected to server Ok Checking GBKey... GBKey Ok Model : V985n (VF Smart 4 Power) IMEI : 3520930615xxxxx NW Lock : OPEN Code : 06225527 NS Lock : OPEN Code : 92996772 SP Lock : OPEN Code : 13268643 CP Lock : OPEN SIM Lock : OPEN Writing Security info... Unlocked Ok Best Regards |
The Following User Says Thank You to boucettay For This Useful Post: |
08-31-2014, 15:07 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Shown codes are incorrect. Update it. Just an friendly advice Br | |
08-31-2014, 15:40 | #3 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | thx for advice, but codes are not wrong, info is read from phone and not calculated... if you r speaking about code length, so Log has been edited and by the end, Codes are not really interesting as we do Direct Unlock, that s just for info !!! Br |
09-01-2014, 14:08 | #4 (permalink) | |
What you show as code is the seed used on the algo. Same as you can see here http://forum.gsmhosting.com/vbb/f702/ . I know what im saying. Just look more carefully and you will understand. And yes codes arent really important but why not to show correct ones if possible br Last edited by boucettay; 09-01-2014 at 17:13. | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
09-01-2014, 17:15 | #5 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Thanks for comment ! seems you r Right , it s seed and not NCk Log will be changed to show only correct data. Best Regards Last edited by boucettay; 09-01-2014 at 21:15. |
