How To Use/Unlock/Flash Using Mutli Unlocker Dongle Alcatel Unlock Code Generation Generating Alcate Codes 1. Launch Software 2. Select "Alcate" Tab 3. Select your Alcatel model from the drop down list 4. Select the Provider ID for your phone (see image below on where to find this information) 5. Click "calculate Code" 6. Your Code Will Now be displayed. Alcatel Entering Codes Model : Method Generic 1 - Switch ON your phone without SIM Card, 2 - Then compose : *#0000*CODE#, 3 - To finish compose : *#0001*CODE#. Model : 531 & 535 1 - Switch ON your phone without SIM Card, 2 - Press * and without release compose 787292, 3 - A new menu "Unlock Network" will appear, then select "YES", 4 - Enter the Code we send to you. Model : All other Alcatel 1 - Switch on your phone with a not allowed SIM Card, 2 - When the message "Enter Network Key" appear enter the Code we send to you ________________________________________ |
Blackberry Code Reader User Guide Reading Code From Blackberry Handset 1. Make sure you have the blackberry drivers installed (blackberry desktop manager) 2. Connect the blackberry phone via USB (phone fully poweredon) 3. The software will now detect the phone 4. Click Get Code 5. The software will now generate the code for you Note. For security features you must be connected to the net during all operations. |
Dell Streak & Aero Unlocking Before you start (requires activation) please check the version of Android running on your Dell Streak. Run the unlock client from “START > Multi Unlock Client > Unlock Client”, you will also need to enter your username and password and click “save login data” and make sure “main Server” is selected under the settings tab, make sure you click “Save Login Data” IMPORTANT: Windows Vista and Windows 7 users. You must run the unlock client as administrator (right click on the shortcut to run the unlock client and select “Run as Administrator”) Once the software is running go to the tab “Dell” tab Unlocking Android V1.6 & V2.1 1. Make sure you have entered your user name and password in the client 2. Make sure if you are using Vista or Win7 that you are running the client as administrator. 3. Select the Android version of your phone 4. Go to the Dell Tab and Click “INSTALL DRIVERS & HELP” (see page 4) 5. The install wizard for the drivers will now start, please follow the instructions. 6. Connect your Dell Streak to your PC (powered on) 7. Make sure that all drivers are installed correctly for your device. 8. Make sure that it is listed under “Android phone” in device manager 9. Go to Settings->Applications->Development and enable USB Debugging. 10. Now click “Unlock” on the client SW. Unlocking Android V2.2 1. Make sure you have entered your user name and password in the client 2. Make sure if you are using Vista or Win7 that you are running the client as administrator. 3. Select the Android version of your phone 4. Go to the Dell Tab and Click “INSTALL DRIVERS & HELP” (see page 4) 5. The install wizard for the drivers will now start, please follow the instructions. 6. Place the phone in “fastboot mode” a. Disconnect the phone and power it OFF b. hold Power ON button for 3 seconds c. and when the phone LEDs lite up press the Camera button fully and release the Power button. Please wait... d. Now press the Fast Boot text on the phone screen e. Connect the cable 7. Now press “Unlock” on the unlock client 8. Wait for Phone to show LOGO, now press ok on the client SW 9. Please wait for prompt from SW to set “Fastboot Mode” again on phone 10. The Client will now display the code Installing Drivers & help The Unlock client helps you to install all drivers that are need to unlock your Dell streak, this is a 4 step process. 1. First install the main driver pack 2. Place the phone in “fast boot mode” 3. Check fastbooot mode drivers are installed. 4. Install AMSS Drivers. |
HP Veer Unlocking Requirements System requirements: Windows XP, Windows Vista (32 bit) (Vista 64bit & Windows 7 untested at present no support, MAC os not supported) HP Veer Unlocking is identical to unlocking the Palm Pre (the following instructions are basically the same as for the Pre) Important:- HP Veer Unlocking Requires Activation On your Dongle Before you start to unlock your HP Veer please ensure:- • Phone must be activated • Phone must be working • Phone must be GSM (this is not for CDMA phones) • Internet connection required • Original Model firmware required (we do not support if you have flashed Firmware from different model) • If possible on a computer your Pre has never seen • Otherwise, remove any and all diag drivers already installed In order to unlock your palm pre, pixi etc, it must first be activated. The best way to do this is the way Palm/HP intended with a working SIM card with an active data plan. You can activate your phone with the tool given on this page, please read through the entire page carefully http://*******/rpgEc Once you have unlocked and have a sim with active data, use WebOS doctor immediately after to get a fresh install. Download “WebOS” software here: http://ws.palm.com/webosdoctor/sorry.htm Quick guide to using the Bypass Activation Tool You must have the java run time library installed to use the following (normally present on most PCs, if not download from Download Free Java Software ) 1. Download the activation bypass tool from http://*******/Uqw2o and save it to your PC (do not unzip this file or open it if prompted) 2. Get your phone to run in ‘USB Mode’ (recovery mode) a. Method 1: i. Take out the battery ii. Press and hold the phones `Volume Up` button iii. Plug in the USB Cable (connected to your PC) iv. Replace the phones battery, release the `Volume Up` button v. If successful you will see the USB icon on the phones screen b. If that fails then use the following method i. Keep the phone with battery cover on and battery in ii. Press and hold the phones `Volume Up` button iii. Plug in the USB cable (connected to your PC) iv. Release the `Volume Up` button. v. If successful you will see the USB icon on the phones screen c. The final method you can try i. With the phone turned on ii. Enter either *228 Option 1 or *22899 iii. You may need to reset the device 3. From the command line (in the location where you saved the bypass tool) enter java -jar devicetool.jar a. Open the folder you saved the bypass tool to i. Vista, hold the shift key and right click anywhere in the folder and select ‘Open Command Prompt Here’ ii. XP, go to START > RUN type CMD press Enter Key, then TYPE ‘CD ‘ followed by the address of the folder you saved the bypass tool in for example ‘CD C:\bypass\’ b. Enter “java –jar devicetool.jar” press Enter key. The Bypass tool will now detect your phone and run the bypass procedure. |
HP Veer Unlock Instructions. HP Veer Unlocking is identical to unlocking the Palm Pre (the following instructions are basically the same as for the Pre) HP Veer Unlock Instructions Run the unlock client from “START > Multi Unlock Client > Unlock Client”, NOTE: HP Veer Unlocking requires activation on your Dongle (correct at 01 October 2011). 1. On the phone enter “Diag Mode” a. On your HP Veer go to ‘Device Info’, write down the 12 digit serial number (please remember it is case Sensitive) b. Enter the serial number into the calculator “START > Multi Unlock Dongle > Pre Pass Through Keygen” (exactly the same if you have a pixi ot a pre) c. Go to the phone app on your palm pre or pixi d. Start typing #*8727277# and press DIAL as if trying to call this number e. Enter the code from the ‘Pre Pass Through Keygen’ and click ‘validate’ (if requested) f. In the window that appears, select “Configure USB pass-through” g. Set DIAG for USB Port 1 (make sure all other ports are set to none, and 'use USBNet` is set to disabled) h. Connect your Phone to the PC using USB cable. i. If/when prompted by the phone select “Just Charge” 2. You need to install drivers when the new hardware found message dialog appears on your PC (see page4 for more info) a. When asked if you would like windows to search for a driver, select “No not this time”, Then select “Install from a list or specific location”, then click “Next” b. Then select “Search for the best driver in these locations”, then check “Include the following location” c. on the next screen click on “Browse” d. Browse to “C:\Program Files\Multi Unlock Dongle\Palm Pre\Drivers” or “C:\Program Files\Multi Unlock Dongle\Palm Pixi\Drivers” depending on the phone you are unlocking. e. Click “Next” and the wizard will install the drivers f. Once the drivers are installed, Unplug & replug phone, click “OK” on the unlock client dialog box. 3. Unplug Phone 4. Run the unlock client from “START > Multi Unlock Client > Unlock Client” 5. Select Palm Tab, and replug phone. 6. Now to Unlock Your Phone a. When the software tells you that “you may proceed”. b. Click “Unlock” , the software will now unlock your phone c. Where possible the blocked counters will be reset. |
HTC CID Unlocking Once a phone has been HARD SPL CID unlocked, you will be able to upgrade or flash a different ROM to your device. Please Note: we do not provide any ROMs for debranding, we do not offer advise or support for flashing ROMS to your device. 1. Connect your device to the PC powered on via USB 2. Sync the handset to the pc using Active Sync (Windows Mobile Device Center if using Vista) 3. Select the correct phone gropu inthe Multi Unlocker "Debranding" drop down list 4. Click "Unlock CID" 5. Check Phone, agree to install application if prompted to do so by phone If your phone refuses to accept the application, your phone will need to be "application unlocked", please use the application unlock tool from http:www.jictechnology.com/support Please Note: we do not provide any ROMs for debranding, we do not offer advise or support for flashing ROMS to your device. The following information is provided for information purposes only After you unlock the CID you must flash the Hard SPL of version regading your model SSPL version (Can see that by entering the FLASH mode). For example - JADE - Press Volume down button and power together, when the device is OFF and the second line will give the info about your SPL version. Like here i have SPL 1.40, so i flash Hard SPL 1.40 and then any firmware for 1.40 SPL. Or i flash Hard SPL 2.xx and any firmware of 2.xx In short - SPL version MUST always be the same as your firmare version. So 1.- Unlock CID 2.- Flash Hard SPL 3.- Flash any firmware HTC Smart Phone Groups FOR CID Unlocking Iolite: • HTC T424X • HTC Touch Cruise • Dopod Touch Cruise • O2 Xda Guide Jade: • HTC T323X • HTC Touch 3G • Dopod Touch Topaz: • HTC T535X • HTC Touch Diamond2 • O2 Xda Diamond 2 • T-Mobile MDA Compact V Rhodium: • HTC T737X • HTC Touch Pro2 • Alltel & HTC Touch Pro2 • Sprint & HTC Touch Pro2 • T-Mobile MDA Vario V • T-Mobile Wing II • AT&T Tilt2 |
HTC Magic Unlocking HTC Magic: IMPORTANT: Turn off your firewall 1 Enter fastboot mode : Phone is OFF, Press and hold the Back key and power on the phone. 2 Install drviers (from the software directory) (C:\Program files\Multi Unlocker Dongle\) 3 Select 'Magic' in the form menu 4 Press Unlock and wait apx 30 seconds. If the waiting time exceeds 1 minute repeat the process. TROUBLE SHOOTING If unlock keeps failing, please goto "windows task manager" (CTRL + ALT + DELETE) Then click on "Processes", and look for "adb.exe" If it's running right click on it, and select "End Process", repeat unlock. |
HTC Smart Phone Unlocking (OMAP Type) HTC Omap Phone Unlocking 1. Sync the handset to the pc using Active Sync (Windows Mobile Device Center if using Vista) 2. Launch Multi Unlocker Software 3. Select the Correct phone group from the "SIM Lock" drop down menu (see list below) 4. Click "Unlock SIM Lock" 5. You will see a pop up box asking you to "connect phone to usb cable" 6. Select OK and then look at the phone. The phone will ask you to accept an application. Select "accept "on the phone. (This will install the code reader application) 7. You will then see on the server client "disable allow usb connections” 8. Leave this open and go to Active Sync on your PC, goto “FILE” > “Connection settings” and then un-tick "Allow usb connections”. After this then click "OK" on the server client to continue. 9. The client will then show you a progress bar. Wait until finished and the code is then displayed on the server client. The phone will reboot which may take a minute. 10. Insert a sim from the other provider (wrong sim) and then power on phone and enter the code. HTC OMAP Phone Groups Artemis: • HTC P3300 • HTC P3301 • Qtek G200 • Dopod P800 • Dopod P800W • Orange SPV M650 • T-Mobile MDA Compact III • O2 Xda Orbit Elf: • HTC P3450 • HTC Touch • HTC Ted Baker Needle • Orange & HTC Touch P3450 • Dopod S1, T-Mobile MDA Touch • O2 Xda Nova • Vodafone VPA Touch Excalibur: • HTC S620 • HTC S621 • Rogers & HTC S621 • Dopod C720W • Dopod C720 • T-Mobile Dash • T-Mobile MDA Mail • O2 Xda Cosmo • Orange SPV E600 Gene: • HTC P3400 • HTC P3400i • HTC P3401 • Dopod D600 • Dopod D600 (Action Version) Herald: • HTC P4350 • HTC P4351 • Dopod C800 • Dopod C858 • O2 Xda Terra • Vodafone VPA Compact IV • T-Mobile Wing Monet: • HTC S320 • Virgin Lobster 700TV Oxygen: • HTC S310 • Dopod 310 • Orange SPV C100 Opal: • HTC T222X • HTC Touch Viva • Dopod Touch Viva • T-Mobile MDA Basic Shadow: Pharos: • HTC P3470 • Dopod P660 Vox: • HTC S710 • HTC S711 • Dopod C500 • Dopod C730 • Vodafone VDA V • Vodafone v1415 • Vodafone v7505 • SFR S710 • Orange SPV E650 • Swisscom XPA v1415 Phoebus: • T-Mobile Shadow • Dopod C750 |
HTC Desire, Legend & Wildfire help: (for Desire HD see below) IMPORTANT: Turn off your firewall 1 Power on the phone 2 Go to Settings->Applications->Development and enable USB Debugging and connect cable to pc 3 Select "charge only" and hit "dont ask" 4 Install drivers from the software directory (C:\Program files\Multi Unlocker Dongle\) 5 Select Your phone model name in the form menu 6 Press unlock and wait apx 2 minutes. If unlock fails leave phone connected and hit unlock again TROUBLE SHOOTING If unlock keeps failing, please goto "windows task manager" (CTRL + ALT + DELETE) Then click on "Processes", and look for "adb.exe" If it's running right click on it, and select "End Process", repeat unlock. HTC Desire HD 1. Power on the phone 2. Go to Settings->Applications->Development and enable USB Debugging and connect cable to pc 3. Select "charge only" and hit "dont ask" 4. Install drivers from the software directory (C:\Program files\Multi Unlocker Dongle\) |
HTC Desire, Legend & Wildfire: (for Desire HD see below) IMPORTANT: Turn off your firewall 1 Power on the phone 2 Go to Settings->Applications->Development and enable USB Debugging and connect cable to pc 3 Select "charge only" and hit "dont ask" 4 Install drivers from the software directory (C:\Program files\Multi Unlocker Dongle\) 5 Select Your phone model name in the form menu 6 Press unlock and wait apx 2 minutes. If unlock fails leave phone connected and hit unlock again TROUBLE SHOOTING If unlock keeps failing, please goto "windows task manager" (CTRL + ALT + DELETE) Then click on "Processes", and look for "adb.exe" If it's running right click on it, and select "End Process", repeat unlock. HTC Desire HD 1. Power on the phone 2. Go to Settings->Applications->Development and enable USB Debugging and connect cable to pc 3. Select "charge only" and hit "dont ask" 4. Install drivers from the software directory (C:\Program files\Multi Unlocker Dongle\) 5. Select Your phone model name in the form menu 6. Press Unlock 7. software will ask you if the phone is rooted already, answer No. It will install Visionary+ application to phone and tell the user what to do. (just need to run it and hit Temproot now. ) 8. Wait for completition and do unlock again, but this time answer Yes. |
Huawei Modem Unlock Code Generation Generating Code 1. Launch Software 2. Select "Codes By IMEI" Tab 3. Select your model from the "Huawei" drop down list 4. Click "calculate Code" 5. Your Code Will Now be displayed. Entering Code Into Dongle You will need the generic software to allow use of your dongle with other networks, as this will allow new APN settings. You can download none branded software for your Huawei dongle from:- Huawei Mobile Partner Connection Manager How to enter your code 1. Insert a SIM card into the dongle that it does not accept 2. Insert the dongle into your PC 3. Attempt to connect to the internet via your dongle 4. Connection manager will ask you to enter the unlock code. if the connection manager does not ask you to enter a code please download our Huawei code tool to enter the code:- Nextgen Server Home of Remote Phone Unlock, Treo, Blackberry Unlock Code Server, Sony Ericsson, Motorola, HTC, Huawei, USB Modem, Unlock your cell phone to any network in real time online. 1. connect your dongle 2. Insure your connection manage is closed (not just minimised to system tray) 2. Run software 3. Sofware will detect your dongle 4. select a port 5. enter unlock code & click "send code" |
Preparing your PC & Iden phone for code reading Before we can read the unlock code from your IDEN phone, you must make sure all the Motorola USB drivers are installed correctly for your phone DISABLE YOUR ANTI-VIRUS !!! Make SURE your phones Battery is fully charged before beginning !!! 1. Download and install software 2. Install Motorola Iden Drivers (START > ALL PROGRAMS > NEXTGEN SERVER > IDEN CODE READER > Iden Drivers) 4. Power on your phone and connect via USB cable (if windows detects new hardware run through all of the new hardware found driver installation wizards that appear) 5. Place Motorola IDEN Into “boot mode” ( Hold * and # key and power on handset) 6. Connect Iden phone to PC via USB cable. 7. Windows will detect new hardware and install drivers. (if windows detects new hardware run through all of the new hardware found driver installation wizards that appear) For i475 the procedure is different. You will need a modified USB cable as detailed on the next page. 1. Place Motorola IDEN Into “boot mode” ( Hold * and # key and power on handset) 2. Connect Iden phone to PC via USB cable. 3. Connect the 9v power to the cable for a few seconds 4. Windows will detect the phone, in device manager you will see “Motorola FLASH Interface. 5. Remove the power from the cable. 6. Proceed to unlock. Alternative Method (i475) if the above method failes try the following:- Phone must be off Connect cable to pc and add battery to cable. Connect cable to phone Press unlock and when the phone is detected remove the 9v supply! i475 USB cable with external power connector Your phone and PC are now ready to proceed. DO NOT install any Motorola P2k Drivers If you have Motorola P2k Drivers Installed on your PC, please make sure you uninstall them before attempting to CNS unlock. only use the Motorola Iden Drivers Removing CNS Unlock From your phone. There are now two services for removing Iden CNS lock from Iden phones:- • Unlock CNS Old • Unlock CNS New “Unlock CNS New” for:- • i296 (new v37 07-02-2010) • All i410 • i465 (v20 and higher) • i855e • i412 (new Jan 2012) • i475 (new Jan 2012, requires USB cable with 9v) “Unlock CNS Old” for:- • i290 • i335 • i425 • i776 • i465 (V19 and older) Launch the unlock client/software START > ALL Programs > Multi Unlock Client > Iden Reader Click on the settings tab, insert your User Name & Password as provided to you. Select Main Server, then Click on “Save login data” Now click on the “Iden Workshop” tab Place Motorola IDEN Into “boot mode” ( Hold * and # key and power on handset) i475 Only (connect power to cable untill windows detects flash interface, then remove power from cable) Click on the correct button for your device “Unlock CNS New” for:- • i296 (new v37 07-02-2010) • All i410 • I465 “Unlock CNS Old” for:- • i290 • i335 • i425 • i776 The client will now remove the CNS unlock (if unlock fails on i465, and your phones firmware version is V19 or lower, please retry with “Unlock CNS Old”) |
Iden Special Code Reading the codes from your phone 1. Launch the unlock client/software START > ALL Programs > Nextgen Server > Iden Reader 2. Conect the Iden phone Powered on fully in normal mode 3. Now Click “Read Codes” The software will now read the codes from the Iden phone If you close the software before noting down the codes or entering them into your phone, the codes are saved to a text file in C:\Program Files\Nextgen Server\Iden reader |
Palm Pre & Pixi Unlock Instructions. Palm Pre2, Palm Pre & Pixi Unlock Instructions Run the unlock client from “START > NEXTGEN SERVER > Multi Unlock Client > Unlock Client”, you will also need to enter your username and password and click “save login data” and make sure “main Server” is selected under the settings tab, make sure you click “Save Login Data”, please make sure if you copy and paste or enter User details manually that you do not inadvertently put a space at the beginning or the end of the user name or the password, this will cause the message “unable to get balance or counter zero”. NOTE: Pixi, pre & Pre2 require different credits; please insure your account has the required service active for the type of phone you are trying to unlock. 1. On the phone enter “Diag Mode” a. On your Palm Pre go to ‘Device Info’, write down the 12 digit serial number (please remember it is case Sensitive) b. Enter the serial number into the calculator “START > Multi Unlock Dongle > Pre Pass Through Keygen” (exactly the same if you have a pixi ot a pre) c. Go to the phone app on your palm pre or pixi d. Start typing #*8727277# and press DIAL as if trying to call this number e. Enter the code from the ‘Pre Pass Through Keygen’ and click ‘validate’ (if requested) f. In the window that appears, select “Configure USB pass-through” g. Set DIAG for USB Port 1 (make sure all other ports are set to none, and 'use USBNet` is set to disabled) h. Connect your Phone to the PC using USB cable. i. If/when prompted by the phone select “Just Charge” 2. You need to install drivers when the new hardware found message dialog appears on your PC (see page4 for more info) a. When asked if you would like windows to search for a driver, select “No not this time”, Then select “Install from a list or specific location”, then click “Next” b. Then select “Search for the best driver in these locations”, then check “Include the following location” c. on the next screen click on “Browse” d. Browse to “C:\Program Files\Multi Unlock Dongle\Palm Pre\Drivers” or “C:\Program Files\Multi Unlock Dongle\Palm Pixi\Drivers” depending on the phone you are unlocking. e. Click “Next” and the wizard will install the drivers f. Once the drivers are installed, Unplug & replug phone, click “OK” on the unlock client dialog box. 3. Unplug Phone 4. Run the unlock client from “START > Multi Unlock Client > Unlock Client” 5. Select Palm Tab, and replug phone. 6. Now to Unlock Your Phone a. When the software tells you that “you may proceed”. b. Click “Unlock” , the software will now unlock your phone c. Where possible the blocked counters will be reset. |
PV 300 Unlock Instructions Launch the multi Unlock Now select the "Sidekick" Tab Follow the instructions on the software If you require drivers they are included in the Multi Unlocker Program Folder. Installing Drivers If you have to install drivers please do the follwoing Select "Install from a list or specific location" click "Next" Select "Include this Location in the search", click "Browse" then browse to the PV300 Driver folder in the multi Unlocker program folder, Click NEXT Windows Will now install the new drivers, click "Continue anyway" when windows warns about driver signing. |
