Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > MultiUnlocker
Old 02-13-2013, 09:07   #1 (permalink)
Member: 1833113
Sonork: 100.1623537
Thanks Meter: 40
Dell streak 5 unlock code received with multidongle
Dell streak 5 unlock code found but how to enter it...if i put unsupported sim and restart phone its simply getting in and showing this message "sim is unusable in this terminal. Please insert usable Usim" on the lock screen instead of asking unlock code.
Dell streak 5 001dl softbank
Android 2.2
Old 02-13-2013, 14:49   #2 (permalink)
Member: 1833113
Sonork: 100.1623537
Thanks Meter: 40
multi unlocking team please update me...
Old 07-15-2013, 14:21   #3 (permalink)
Member: 1979436
Sonork: dik71
same problem here
do u have the solution how to enter the code.. need your favor.. thk u!
Old 07-23-2013, 02:15   #4 (permalink)
Avengers Box's Avatar
Member: 1863458
Sonork: 100.1645487
Thanks Meter: 478
if unlock screen not display update your dell rom OTA2.2 and after flashing the rom it must display unlock code request.
Before you start
please check the version of Android running on your Dell Streak.
Run the unlock software.
IMPORTANT: Windows Vista and Windows 7 users.
You must run the unlock software as administrator (right click on the shortcut to run the unlock SW and select “Run as Administrator”)
Once the software is running go to the tab “Dell” tab
Unlocking Android V1.6 & V2.1
1. Make sure you run the unlock software as administrator.
2. Make sure if you are using Vista or Win7 that you are running the software as administrator.
3. Select the Android version of your phone
4. Go to the Dell Tab and Click “INSTALL DRIVERS & HELP”
5. The install wizard for the drivers will now start, please follow the instructions.
6. Connect your Dell Streak to your PC (powered on)
7. Make sure that all drivers are installed correctly for your device.
8. Make sure that it is listed under “Android phone” in device manager
9. Go to Settings->Applications->Development and enable USB Debugging.
10. Now click “Unlock” on the SW.
Unlocking Android V2.2
1. Make sure if you are using Vista or Win7 that you are running the software as administrator.
2. Select the Android version of your phone
3. Go to the Dell Tab and Click “INSTALL DRIVERS & HELP”
4. The install wizard for the drivers will now start, please follow the instructions.
5. Place the phone in “fastboot mode”
a. Disconnect the phone and power it OFF
b. hold Power ON button for 3 seconds
c. and when the phone LEDs lite up press the Camera button fully and release the Power button. Please wait...
d. Now press the Fast Boot text on the phone screen
e. Connect the cable
7. Now press “Unlock” on the unlock software
8. Wait for Phone to show LOGO, now press ok on the SW
9. Please wait for prompt from SW to set “Fastboot Mode” again on phone
10. The SW will now display the code
Installing Drivers & help
The Unlock SW helps you to install all drivers that are need to unlock your Dell streak, this is a 4 step process.
1. First install the main driver pack
2. Place the phone in “fast boot mode”
3. Check fastbooot mode drivers are installed.
4. Install AMSS Drivers.
Old 08-25-2013, 12:03   #5 (permalink)
Member: 1979436
Sonork: dik71
thk u...
Before you start
thk u so much.. but do u have the unlock software? thx!
Page generated in 0.14556 seconds with 8 queries
