01-10-2013, 08:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: pakistan
Member: 1724009 Status: Offline Sonork: 100.1611413 Thanks Meter: 31 | can not repair boot i9100[Answered/Solved] Please press Power On key before any Read/Write/Erase operation. Error 6 the definition is not set. PIN1 = VCC PIN2 = TRST PIN3 = TDI PIN4 = TMS PIN5 = TCK PIN7 = TDO PIN8 = SYSRST Setting definition... Set definition done! Activation in progress(Make sure to press Power on key)... CPU ID: 7704A04B. Error 11 phone doesn't respond for a long time,please reconnect! Time: 2:1 >>========================================== |
01-10-2013, 09:22 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | 1st select the brand and model 2nd set default pinout Quote:
what is the history of your phone ? Last edited by jatchaminda; 01-10-2013 at 09:28. | |
01-11-2013, 20:33 | #3 (permalink) |
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | today i try to read SHV E120K[Galaxy S2 HD LTE] 1GB dump first i try this make JTAG connection and connect to power supply and try to read but no success [this error is same as yours] after that i insert usb cable to phone and try to read.and result is succuss make sure your jtag connection is good and use power supply and insert usb cable |
11-20-2013, 16:15 | #5 (permalink) | |
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | Quote:
The Following User Says Thank You to jatchaminda For This Useful Post: |
11-21-2013, 16:28 | #8 (permalink) |
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | bro this link is working why do you need another link ? |
11-24-2013, 17:45 | #13 (permalink) | |
Insane Poster Join Date: Jul 2011 Location: INDONESIA
Member: 1626145 Status: Offline Thanks Meter: 15 | Quote:
My problem solved sir..... just repair boot with file boot e120s and flashing with file flash e120s, no need to flash full dump now my phone worked normal , thank you for respon | |
The Following User Says Thank You to 33phoneshop For This Useful Post: |
