05-10-2013, 07:13 | #2 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Open soft select S5380 Solder pinout Set Default Pinout Erase , Select flash file S5380 Boot File : Write |
The Following User Says Thank You to taoujdate For This Useful Post: |
05-10-2013, 17:31 | #4 (permalink) | ||
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | Quote:
Asela | ||
The Following User Says Thank You to jatchaminda For This Useful Post: |
05-16-2013, 18:36 | #8 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Brazil, America
Member: 1508533 Status: Offline Thanks Meter: 45 | I tried to update the boot with versions S5380 and S5380D and nothing to get into download mode. It remains now I try with version S5380B, but do not think anywhere, any solution? |
05-23-2013, 14:59 | #13 (permalink) |
Member: 1508533 Status: Offline Thanks Meter: 45 | Was removing the security code of the phone making a flash with Multiuploader when given an error on my PC and ended the procedure, then the phone is not connected nor in download mode more. |
05-23-2013, 18:44 | #14 (permalink) |
Member: 1508533 Status: Offline Thanks Meter: 45 | The log operations ========================================== Erase operation(Make sure to press Power on key)... CPU ID: 7F61B307. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Erase succeed! Time: 11 s ========================================== Writing in progress(make sure to press Power On key)... CPU ID: 7F61B307. Flash ID: 00EC0050 (512M). Release Power on key now and operation continues... Write succeed! Time: 8 s >>========================================== |
05-25-2013, 08:52 | #15 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Read dump from ok phone and write to your phone.. and if i get phone in my shop i will read and upload for you. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
